#575 |
Negative Mass
Drives: Orange Metallic AVO Turbo GT86 6MT
With my open filter I can hear intake hiss like crazy but the turbo itself doesn't really make much noise. Nothing like GT3xxx jet turbine noises.
Build thread for my Lovely Lady.
#576 | |
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
The Perrin CAI on the other hand, being a long tube intake, doesn't muffle the sound, but has a different resonance being metal instead of ABS and that the intake end is more of a snorkel. Any of the various other intakes with cone filters that lie within the engine bay of the car unimpeded would accentuate the sound of the turbo spooling. Bob @ Drift-Office, LLC |
#577 | |
I Love custom Turbo kits
Drives: Limited BRZ
It was pretty noticeable and accentuated inside the cabin, outside, etc. and going back to my initial post, moreso than stock airbox.... Maybe we are both saying the same thing and that's why I got confused on what you meant ![]() [ame="http://www.youtube.com/watch?v=W7uqfy6ZAJI"]Subaru BRZ with AVO Kit drive by video - YouTube[/ame]
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Skorov (03-02-2014) |
#578 | |
1) Not louder with the stock airbox? 2) Louder with the stock airbox than compared with a Perrin CAI or 3) Louder with an aftermarket intake? Bob @ Drift-Office, LLC |
#579 |
Drives: Limited BRZ
It's louder with Perrin CAI when compared to stock airbox and there is not much performance to be had from an aftermarket intake when compared to the stock airbox. Nothing more, nothing less.
#580 |
Drives: 4-Runner Sport - 13' BRZ SportTech
I haven't put my car on the street yet so I cant attest to its reliability , however I feel compelled to add that these flange issues are limited to a 4 or 5 incidents on a kit that has been sold to a couple of hundred customers globally.
For a failiure rate as a % of volume, I'm sure it's nowhere near as bad as some people make it out to be. Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
| The Following 2 Users Say Thank You to protpibe For This Useful Post: | Drift-Office (03-01-2014), SkAsphalt (03-02-2014) |
#581 | |||||
I have also done 3 Vortechs / 2 KWs / 1 JR / 1 Innovate / 2 ESCs & 1 custom top mounted turbo kit with a total of about 74 dyno tunes on GT86s / FRS / BRZs of assorted configurations. I confess, this does not make me an expert on all things GT86, but it does give me some leverage as to the experience my company has in this matter. And based on my experience, AVO has got my vote. Having been doing R&D on other things with AVO (and other companies), has also given me a clear look into their inner workings, and if I felt otherwise, I wouldn't be working with them if I felt that their stuff was not up to snuff. Obviously, if I had as many problems as you and others might want to lead people to believe, it would be easier for me to drop the entire line and just do SC kits and get paid more, with less hassle. This obviously isn't the case. Course, I suppose you're beyond suspicion, but I digress. ![]() Quote:
![]() Quote:
![]() Lastly ~ Quote:
TO MY CUSTOMERS : PLEASE CHIME IN ABOUT ALL YOUR PROBLEMS YOU'RE HAVING WITH THE AVO KIT. Regards, Bob @ Drift-Office, LLC |
| The Following User Says Thank You to Drift-Office For This Useful Post: | SkAsphalt (03-02-2014) |
#582 |
Sending rods to their doo
Drives: 700HP STi
Bob from @Drift-Office tuned AND INSTALLED my AVO kit and realistically I have ZERO PROBLEMS!! Quality is amazing to the point of it looking OEM.
| The Following 2 Users Say Thank You to Touge_ninja For This Useful Post: | Drift-Office (03-02-2014), SkAsphalt (03-02-2014) |
#583 |
The Based God
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
I personally haven't had any issue with the kit. That being said it was installed/tuned by Drift Office. So as far as the flange issue is concerned, I don't have one. I can say I only have exhaust leaks from my catback (shitty slip couplings). Usually you should use flange gaskets when installing an aftermarket exhaust, I wouldn't think any different for a manifold... For the few that have an issue with the manifold, I'd say ask for a replacement.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
| The Following User Says Thank You to InvalidJohnny5 For This Useful Post: | Drift-Office (03-02-2014) |
#584 | |
People that have actual problems with the flanges themselves being significantly warped, that will get down to me dealing with them on a warranty basis if they arrive like that. If they are like that after a significant usage period, then it will get down to how much boost they were running, how much timing they were (or were not) running, and how high their EGT's were when this happened. Unfortunately, not many tuners log EGT's when tuning out to high boost, so probably don't know if they overheated the exhaust manifolds. Metal is metal, if exposed to a high enough heat, it'll start warping. |
| The Following User Says Thank You to AVOturboworld For This Useful Post: | SkAsphalt (03-02-2014) |
#585 | |
Drives: Subaru BRZ Limited
It does sound much nicer with the Perrin. |
| The Following User Says Thank You to gdrider77 For This Useful Post: | Sportsguy83 (03-01-2014) |
#586 |
The Based God
Also I have about 20k on the kit, and am in rather rough conditions....hot exhaust temps in -20 weather should cause warping, but thankfully none have occurred.
| The Following 3 Users Say Thank You to InvalidJohnny5 For This Useful Post: |
#587 |
The Based God
I was thinking of getting the Perrin CAI, does the induction sound fairly naice?
#588 |
Drives: Limited BRZ
See above.. REALLY nice i'd say.
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 05:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
