Old 03-01-2014, 09:06 PM   #15
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Good point, but Stance angled LCA unfortunately wont be strong enough for frequent track use but perfectly fine for DD and aesthetic purposes
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 03-01-2014, 09:42 PM   #16
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@h4nh
Any idea on how much (-) camber the front HVT plates give with this setup? Being at your current front height get at least -2 ??
The Following User Says Thank You to OICU812 For This Useful Post:
RehabJeff86 (03-01-2014)
Old 03-01-2014, 09:53 PM   #17
RehabJeff86
Originally Posted by OICU812 View Post
@h4nh
Haha i was wondering the same, official website stating -1.8 degree and more with lower arm camber bolt but now with 2" drop it should be much more, for track purpose i would need at least -2.5 in the front
Old 03-01-2014, 09:59 PM   #18
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
@h4nh
Not sure, haven't aligned it yet but it should max out more than that.
h4nh is offline   Reply With Quote
Old 03-01-2014, 11:11 PM   #19
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Dude... you need way more neg. camber to qualify as herra-frush. lol
Car's look pretty sweet, doe.
Old 03-01-2014, 11:46 PM   #20
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
That's too low
Stock cars can out handle me when I run mine that low
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
diss7 (03-07-2014)
Old 03-02-2014, 12:20 AM   #21
h4nh
h4nh's Avatar
Originally Posted by dwx View Post
Eh if you are looking to spend that much go with the MCS DA shocks without the remote reservoirs.
As to the OP, definitely the reason the Raceseng rears exist is to drop without losing travel. The only issues I've heard from anyone is using shorter length shocks and not having enough droop travel. There are also a couple people making lower control arms that reduce the ride height by lowering the lower attachment point. Stance is one of them.
Originally Posted by kiichiro View Post
That's too low
You're right its probably too low to be fully functional. I don't go to the track often. I just want the ability to adjust the height if I feel like it.
Old 03-02-2014, 12:22 AM   #22
h4nh
h4nh's Avatar
Haha thx! I don't wanna be qualified.
Old 03-02-2014, 12:58 AM   #23
h4nh
h4nh's Avatar
Update. I just lowered the front just to see how low it'll go.
Max low in the front now.
Disregard the ghetto ebay led license plate light that went out. lol
This the max low on the new set up. I'm pretty happy with it now.
Here's some of my other cars so you can see what I usually have the ride height at.
F10 M5 on H&R lowering springs.
E92 M3 on H&R lowering springs.
E90 M3 on kw clubsports coilovers
The Following User Says Thank You to h4nh For This Useful Post:
Surok (03-06-2014)
Old 03-02-2014, 05:56 AM   #24
RehabJeff86
How to hella flush Ohlins coilovers
Ohhh that looks hella good!!
Just noticed u running 19" 57extreme?
Old 03-02-2014, 12:45 PM   #25
h4nh
h4nh's Avatar
Yea that's correct. I have some custom forged wheels on order. 19x12 rear and 19x10 front for wide body later.
RehabJeff86 (03-03-2014)
Old 03-02-2014, 02:57 PM   #26
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
You're currently running 19" 57extremes? I thought they were 18s!
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-02-2014, 03:35 PM   #27
h4nh
h4nh's Avatar
Yeah I like how 19s fit. They probably don't ride as well as 18's.
Old 03-03-2014, 06:42 PM   #28
mike156
Drives: EVO
To anybody willing to go to the work of correcting the geometery for low ride heights but still interested in the Ohlins. I would bet if you set the body height adjustment correctly you could likely get the car plenty low without offset mounts. Set the body height adjustment so the strut runs out of travel shortly after the tire runs into shit, so you maximize strut travel. From there, just get a shorter spring to get the static ride height desired. Up the rate at the same time to correct the downfall of the Ohlins. If you care about noise because the shorter spring wouldn't be preloaded, just add a helper spring. Cheaper and more effective. This method likely just got rid of a bunch of usable droop travel.
mike156 is offline   Reply With Quote
hvt, ohlins, raceseng
>>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins Circuit Motorsports Brakes, Suspension, Chassis 230 02-17-2016 12:01 PM
OHLINS DFV COILOVERS FOR BRZ / FR-S Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 08-28-2014 01:27 PM
Ohlins Road & Track Coilovers for sale h4nh Brakes, Suspension, Chassis 17 02-18-2014 11:35 PM
FS: (VA) OHLINS DFV Coilovers BRZ/ mslerner2002 Brakes, Suspension, Chassis 8 12-08-2013 08:10 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
