Old 03-01-2014, 07:04 PM   #1
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Talking How to hella flush Ohlins coilovers
Okay so not exactly hella flush, but most people have had issues with the ride height being so high with the Ohlins on maxed out low.
After installing the Ohlins suspension I was disappointed with the ride height and almost sold it off. I really liked the ride quality of it so I tried to figure out a solution to make it lower. The gap in the rear was so bad it looked almost like factory springs. I wasn't looking to slam my car or anything but for the price of these coils they should have at least come with more adjust-ability on height.
Anyways I did my research and didn't find anything. I looked around for different camber plates and top hats and ended up with the HVT front adjustable camber plates / Raceseng rear top hats. After playing around with the bearing configurations I got it to work! Without running it into the bump stop or anything.
This was after the Ohlins was installed.
Another shot of the rear to show how high it really was.
Max low on the front.
Trying to figure out how this is going to go together. I ended up not using the bearing and silver hat piece from the HVT set up.
I ended up using the bearing that came with the ohlins on top of the ohlins hat instead.
Final set up for the front.
Ohlins rear piece.
I used the thicker bearing from the top portion and brought it down here. Then the spacer from the Raceseng set up placed above that.
This is how much lower it went with the Raceseng rear top hat.
I move the thinner bearing that was on the bottom to the top. Then the black nut above that.
Installed. The front has more room the go lower. Maybe another 1/2 inch to an inch. The rear is maxed out here.
Here's a shot in the day light. I still need to either raise the back up or lower the front a lil more.
Max low in the front now.
Disregard the ghetto ebay led license plate light that went out. lol
This the max low on the new set up. I'm pretty happy with it now.
h4nh is offline   Reply With Quote
The Following 9 Users Say Thank You to h4nh For This Useful Post:
DocWalt (02-16-2016), Dustin (03-12-2014), fooddude (03-01-2014), Guff (03-02-2014), hamzam (03-04-2014), kanundrum (03-02-2014), rcm47 (03-02-2014), RehabJeff86 (03-01-2014), Wes (03-01-2014)
Old 03-01-2014, 07:16 PM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Looks great. Glad we were able to help out.
FT-86 SpeedFactory is offline   Reply With Quote
Old 03-01-2014, 07:18 PM   #3
h4nh
h4nh's Avatar
Thanks for the parts!
Old 03-01-2014, 07:22 PM   #4
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I say lower the front! The back looks pretty nice
Old 03-01-2014, 07:24 PM   #5
h4nh
h4nh's Avatar
I'll try.. but if it starts scraping on turns I'm gonna raise it back up lol.
Old 03-01-2014, 07:25 PM   #6
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Very nice! You couldn't have picked a better suspension.
Old 03-01-2014, 08:14 PM   #7
h4nh
h4nh's Avatar
I see you ride too so you know what's up
The Following User Says Thank You to h4nh For This Useful Post:
RRnold (03-04-2014)
Old 03-01-2014, 08:18 PM   #8
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
You can even go lower by removing a lock nut or 2, since it's already maxed out
Super nice setup btw. Double btw: how much are those front and rear mounts?
fooddude is offline   Reply With Quote
Old 03-01-2014, 08:42 PM   #9
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Awesome!! Ya i say drop the front a lil more if possible, the rear is perfect now!
Quick Q: by using HVT and RaceSeng top mounts, u were able to maintain Ohlins rec bump travel and ride quality??
Quick Rec: i would consider front lower arm to correct roll center imho
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 03-01-2014, 08:48 PM   #10
h4nh
h4nh's Avatar
I don't need it any lower than the rear is lol. But you're right.
They were 700 for front and rear. So total set up is around 3900
Old 03-01-2014, 08:50 PM   #11
h4nh
h4nh's Avatar
Yeah quality is same and the bump travel is the same.
I haven't drove it hard yet. Just got it on last night but I'll test it at the track at the end of the month.
Old 03-01-2014, 08:52 PM   #12
RehabJeff86
I may hv to follow ur foot step, i hv been waiting for CSG Spec Tein SRC for over a year now and still in testing phase..... Or bite the bullet and go JRZ Pro....
Old 03-01-2014, 08:58 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I thought about doing this as well... was originally considering Stance LCA in rear.
But for my purposes, I'm okay with the "barely lowered" look.
-alex
Old 03-01-2014, 08:58 PM   #14
xwd
Eh if you are looking to spend that much go with the MCS DA shocks without the remote reservoirs.
As to the OP, definitely the reason the Raceseng rears exist is to drop without losing travel. The only issues I've heard from anyone is using shorter length shocks and not having enough droop travel. There are also a couple people making lower control arms that reduce the ride height by lowering the lower attachment point. Stance is one of them.
hvt, ohlins, raceseng
>>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins Circuit Motorsports Brakes, Suspension, Chassis 230 02-17-2016 12:01 PM
OHLINS DFV COILOVERS FOR BRZ / FR-S Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 08-28-2014 01:27 PM
Ohlins Road & Track Coilovers for sale h4nh Brakes, Suspension, Chassis 17 02-18-2014 11:35 PM
FS: (VA) OHLINS DFV Coilovers BRZ/ mslerner2002 Brakes, Suspension, Chassis 8 12-08-2013 08:10 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
