Old 02-28-2014, 07:48 PM   #813
supra2nv
supra2nv's Avatar
Drives: 10 Series TRD
love the diffuser and lip. looks great overall
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality
supra2nv is offline   Reply With Quote
Old 03-01-2014, 10:19 AM   #814
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Thanks! I still need to take some good pictures in the sun. The glossy gunmetal finish on the wheels is darker than my Enkeis, but I am loving the subtle aggression and contrast they give.
I'm considering getting a set of spoke decals to really make them pop.
I think red decals would best match the red tail lights.
Old 03-01-2014, 10:50 AM   #815
supra2nv
supra2nv's Avatar
Bro the clean look no decals is the way id leave them but that's just me .
Old 03-01-2014, 11:55 AM   #816
supra2nv
supra2nv's Avatar
sharkfin antenna? that would look so good on this car...would flow well with the lines of the spoiler diffuser et al
Old 03-01-2014, 06:08 PM   #817
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Don't do it, but that is coming from a guy with Volk TE37SLs and red decals. I just feel it makes the wheels try to be something they are not.
Old 03-03-2014, 09:11 AM   #818
ATL BRZ
ATL BRZ's Avatar
Would prefer to keep my low-profile shorty antenna and get either the garnish that fills the aero gap between the rear window and the trunk lid (can't remember what it's called, but you just put one on your FR-S), or get the APR front canards.
Old 03-03-2014, 11:13 AM   #819
supra2nv
supra2nv's Avatar
TRD Rear window garnish and grrrr it's not here yet:-/. The shorty is cool tho I almost went that route myself.
Old 03-03-2014, 03:36 PM   #820
gramicci101
Off Topic
What about a front splitter?
http://ft86speedfactory.com/apr-fron...r-brz-432.html
Old 03-03-2014, 03:56 PM   #821
ATL BRZ
ATL BRZ's Avatar
Originally Posted by gramicci101 View Post
I just installed a STi style front lip a couple weeks ago and I'm happy with it, especially knowing I won't mind at all when it inevitably scrapes something. I am extremely careful but it still happens even before I installed the lip. The APR splitter is over 3 times the cost of my STi lip... I'd rather spend that extra money on other things... like a flex fuel kit
Old 03-04-2014, 06:45 PM   #822
Caboose
Drives: WRB BRZ Premium
Yep pretty easy install. Just mock it up with a buddy and some masking tape, drill smaller holes in the pre-marked holes, then use the provided screws to secure it to the bottom of the bumper cover. I did it in my garage myself with some random boxes to hold it up and tape it down to fit it. Used a creeper to make it easier.
I just bought the same lip. Did you have to remove the front under trays like in this install video (different lip), or is it as simple as positioning the lip, drilling the holes and screwing all the screws in? Did you reuse any of the OEM clips?
[ame="http://www.youtube.com/watch?v=EEOCncqEdp4"]HT Autos Front Lip Spoiler - Unboxing, Install and Review - 2013 Subaru BRZ - YouTube[/ame]
Thanks,
Jon
Caboose is offline   Reply With Quote
Old 03-04-2014, 07:10 PM   #823
ATL BRZ
ATL BRZ's Avatar
It's that simple
Nope only used the supplied mounting screws. Measure twice, drill once.
Old 03-04-2014, 07:30 PM   #824
Caboose
Thanks, your post made me pull the trigger. Looks great!
Old 03-04-2014, 07:37 PM   #825
ATL BRZ
ATL BRZ's Avatar
My Moto-East Flex Fuel kit arrived!
It includes everything needed for a plug and play flex-fuel setup to allow precise on-the-fly tuning adjustments based on actual ethanol content for maximum safety and power with no map switching or tank draining hassles.
I'm very happy with the quality of the kit. The fact that it comes pre-assembled and pressure tested gives me extra security. Thanks @moto-mike ! Hoping to install it this weekend.
Old 03-08-2014, 02:34 AM   #826
ATL BRZ
ATL BRZ's Avatar
Installed my Flex Fuel kit earlier this evening. Got everything installed, up and running in a few hours, taking my time. Followed the instructions exactly and everything came together perfectly. Removing the connectors on the ECU to get the harness connected was a pain. Running the wires was easy, took my time connecting the crimps together. I had to really lay into the crimping tool to get it to bite the wires and secure them. A lighter worked fine to melt the heatshrinks on the crimps.
I got everything in the cabin zip tied out of sight and away from hazards and was able to mount the sensor gauge and tuck the wire away neatly into the dash panel.
The fuel lines came together quite easily. The quick disconnect tool worked well and the FF assembly installed securely and made all my apprehensions go away. Overall the instructions were extremely thorough and detailed and that made me much more comfortable with the kit.
It all came together cleanly and without any issues. I flashed the Flex Fuel tune provided and started the car. Checked and rechecked for leaks and headed to the E85 pump. Filled up with Ethanol and the sensor reacted after a couple minutes and I proceeded to make a few logs for Moto-East to review. The power was all there and it's running great so far.
Very happy with this kit and the Flex Fuel tune!
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
