Old 02-28-2014, 03:36 PM   #127
MichaelCampos
Drives: Whiteout FRS
Phastek sport has them for $750 shipped. I ordered mine a couple days ago
MichaelCampos is offline   Reply With Quote
The Following User Says Thank You to MichaelCampos For This Useful Post:
chanomatik (02-28-2014)
Old 02-28-2014, 06:41 PM   #128
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
6 pages and no mention of spring rates? They must really be not intended for performance use huh? Are they all show, no go coilovers?
fooddude is offline   Reply With Quote
Old 02-28-2014, 06:51 PM   #129
merino_frs
merino_frs's Avatar
Originally Posted by fooddude View Post
6 pages and no mention of spring rates? They must really be not intended for performance use huh? All show, no go coilovers?
If you're looking for "performance" coilovers, these aren't the ones for you. Simple as that. If you're looking for a softer ride and highth adjustability. You hit the jackpot with these coilovers. Hopefully this helps
merino_frs is offline   Reply With Quote
The Following 2 Users Say Thank You to merino_frs For This Useful Post:
*LongFella (02-28-2014), chanomatik (02-28-2014)
Old 02-28-2014, 06:54 PM   #130
fooddude
Spring rates?
Old 02-28-2014, 07:28 PM   #131
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Spring rates?
Couldn't you just message the manufacturer?
Old 02-28-2014, 07:45 PM   #132
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
http://www.rallysportdirect.com/ST-S...0888-Coilovers
KKaWing is offline   Reply With Quote
The Following User Says Thank You to KKaWing For This Useful Post:
Old 03-01-2014, 01:19 AM   #133
fooddude
Originally Posted by KKaWing View Post
Thanks
F4kg R5kg
Old 03-05-2014, 01:38 PM   #134
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Any ST users getting some "spring pop" noise in the rear when cruising over bumps or inclined driveways? I have HVT camber plates up front with no helper springs, and they are quiet and perform great.
In the rear, I'm using the stock top hats with the helper springs and I get a lot of spring noise. In addition, the plastic dust sleeve on my left rear cracked and separated from the bump stop and has slid down to the threaded portion of the shock body.
I'm dropped a little over 1", so it's not like I'm slammed or anything. But the spring noises and the cracked dust sleeve make me wonder if something wasn't installed right or if I needed something extra to make the stock rear top hats work better. The instructions that came in the box weren't the best ever.
jprice130 is offline   Reply With Quote
Old 03-07-2014, 10:04 PM   #135
THEWAKLER
USMC
THEWAKLER's Avatar
Drives: DGM BRZ LMT
Has anyone sprayed/painted/covered the system with anything to protect the galvanized components from rusting?
THEWAKLER is offline   Reply With Quote
Old 03-07-2014, 10:12 PM   #136
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
They come coated.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 03-11-2014, 06:50 PM   #137
THEWAKLER
USMC
THEWAKLER's Avatar
Drives: DGM BRZ LMT
Originally Posted by Tansey86 View Post
They come coated.
They are galvanized, but are still susceptible to the elements. Was just wondering what other protective measures people have taken.
Old 03-16-2014, 06:39 AM   #138
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
In Europe we have 3 stage of ST coil over and 2 stage are ofered for the GT86
-ST X coilover not adjustable
- ST XTA coilover rebound adjustable and adjustable top mount
those look like KW V2 with adjustable top mount
Do you think the ST X are the same as the one's offered in USA?
http://www.st-suspensions.net/st/inf...t_x_coilovers/
for GT86:
http://www.st-suspensions.net/produktfinder/?typ=25718
Mars2 is offline   Reply With Quote
Old 03-17-2014, 12:58 PM   #139
Ouhei
Ouhei's Avatar
Drives: '14 SWP BRZ Limited
I know the link has already been posted but they share the same rates as KWv1/3 coilovers and are in fact the exact same as a KWv1 with a different shock body material. While not the ideal coilover if you're building a track focused car, they are by no means "all show, no go". They will perform better than the OEM setup for spirited drives and on the track.
Ouhei is offline   Reply With Quote
Old 03-29-2014, 04:52 PM   #140
cortrain
Has anyone encountered any issues with end link length when lowering on their ST's? I haven't read anything regarding it so far. But, I'm about to install mine in two weeks just don't want any surprises. I'll be lowering it around 1.5" or so.
cortrain is offline   Reply With Quote
The Following User Says Thank You to cortrain For This Useful Post:
*LongFella (03-29-2014)
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 04:38 PM
Pics of you!? Pics of your life?! seven Off-Topic Lounge [WARNING: NO POLITICS] 66 12-25-2012 05:49 AM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
