Old 02-25-2014, 01:07 PM   #1
bjun
bjun's Avatar
Drives: white premium brz M/T
kwv3 settings
Just wondering what other owners of kwv3 are using for their compression and rebound settings for street use?
Even though I use these mainly for street, I still like to take very aggressive turns and go to back roads often with lots of curvy roads at high speeds
I currently have front/rear rebound at 3 and front compression at 5 and rear at 6
bjun is offline   Reply With Quote
Old 02-25-2014, 01:15 PM   #2
ModBargains.com
ModBargains.com's Avatar
When starting off with new coilovers, there's one of two ways to do it. There's the easy way which is the easiest to explain to customers, which would be just to set everything at the middle, and then adjust softer or stiffer depending on the feel you want.
The alternative way to get compression and rebound set is the way I set up a car for the track, in which I follow Koni's guide:
Adjusting the Compression (Bump) Damping Control
Bump damping controls the unsprung weight of the vehicle (wheels, axles, etc.). It controls the upward movement of the suspension such as hitting a bump in the track. It should not be used to control the downward movement of the vehicle when it encounters dips. Also, it should not be used to control roll or bottoming.
Depending on the vehicle, the ideal bump setting can occur at any point within the adjustment range. This setting will be reached when "side-hop" or "walking" in a bumpy turn is minimal and the ride is not uncomfortably harsh. At any point other than this ideal setting, the "side-hopping" condition will be more pronounced and the ride may be too harsh.
1. Set all four dampers on minimum bump and minimum rebound settings.
2. Drive one or two laps to get the feel of the car.
NOTE: When driving the car during the bump adjustment phase, disregard body lean or roll and concentrate solely on how the car feels over bumps. Also, try to notice if the car "walks" or "side-hops" on a rough turn.
3. Increase bump adjustment clockwise 3 clicks on all four dampers.
Drive the car one or two laps. Repeat this step until a point is reached where the car starts to feel hard over bumpy surfaces.
4. Back off the bump adjustment two clicks. The bump control is now set.
NOTE: The back off point will likely be reached sooner on one end of the vehicle than the other. If this occurs, keep increasing the bump on the soft end until it too feels too hard. Then back that side off two clicks. The bump control is now set.
Adjusting the Rebound Damping Control
Once you have found what you feel to be the best bump setting on all four wheels, you are now ready to proceed with adjusting the rebound damping. The rebound damping controls the transitional roll (lean) as when entering a turn. It does not limit the total amount of roll; it does limit how fast this total roll angle is achieved. How much the vehicle actually leans is determined by other things such as spring rate, sway bars, roll center heights, etc.
It should be noted that too much rebound damping on either end of the vehicle will cause an initial loss of lateral acceleration (cornering power) at that end which will cause the vehicle to oversteer or understeer excessively when entering a turn. Too much rebound control in relation to spring rate will cause a condition known as "jacking down." This is a condition where, after hitting a bump and compressing the spring, the damper does not allow the spring to return to a neutral position before the next bump is encountered. This repeats with each subsequent bump until the car is actually lowered onto the bump stops. Contact with the bump stops causes a drastic increase in roll stiffness. If this condition occurs on the front, the car will understeer; if it occurs on the rear, the car will oversteer.
1. With the rebound set on full soft and the bump control set from your testing, drive the car one or two laps, paying attention to how the car rolls when entering a turn.
2. Increase rebound damping three sweeps or 3/4 of a turn on all four dampers and drive the car one or two laps. Repeat this step until the car enters the turns smoothly (no drastic attitude changes) and without leaning excessively. Any increase in the rebound stiffness beyond this point is unnecessary and may in fact be detrimental.
EXCEPTION: It may be desirable to have a car that assumes an oversteering or understeering attitude when entering a turn. This preference, of course, will vary from one driver to another depending on the individual driving style.
ModBargains.com is offline   Reply With Quote
The Following 8 Users Say Thank You to ModBargains.com For This Useful Post:
bjun (02-25-2014), brybot (12-02-2018), Decay107 (02-28-2014), normancw (02-25-2014), Pitman (02-25-2014), SirBrass (02-25-2014), sittinSideways (02-28-2014), sklimo (02-25-2014)
Old 02-25-2014, 03:21 PM   #3
CSG Mike
CSG Mike's Avatar
Would be nice if you credited the original information from the Koni damper tuning guide. The guide you plagiarized is for Koni damoers, is NOT a good way to dial in KW V3/CS dampers.
Old 02-25-2014, 03:22 PM   #4
ModBargains.com
Would be nice if you credited the original information from the Koni damper tuning guide. This isn't the best way to dial in KW V3/CS dampers either.
I did credit Koni, re-read it. Thank you
Old 02-25-2014, 03:38 PM   #5
CSG Mike
CSG Mike's Avatar
How does your car feel now, and what do you want to change it to feel like? What do you like and dislike about it?
What camber plates and alignment are you running? Also, what spring rates and sways are you using?
Old 02-25-2014, 05:39 PM   #6
bjun
bjun's Avatar
I have yet to add sway bar, going to do that in 2 weeks.
My car feels good for daily drive, it feels slightly harder(stiffer) than stock.
I dont mind if it was a little stiffer either if it increases performance
I can turn at high speeds but sometimes I would fishtail a bit
I just want max performance out of these coils, even if it's sacrificing comfort
Old 02-28-2014, 04:08 PM   #7
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Out of curiosity, why does the way you adjust certain dampers differ? I would have thought you would use the same method for both, as both products are dampers but by different manufacturers. What's different about them?
sittinSideways is offline   Reply With Quote
Old 02-28-2014, 04:38 PM   #8
CSG Mike
CSG Mike's Avatar
The amount of change per "click" is different with different models of dampers, even within the same line. For example, some dampers have 40 "clicks" for a given adjustment, while other dampers may only have 7 "clicks".
In the case of the KW V3, there are 14 compression clicks, and no clicks at all for rebound, only sweeps (although some newer models use clicks).
Old 02-28-2014, 04:46 PM   #9
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
What's the difference between a sweep and a click? Both are pre-determined set ranges movement, correct?
^GT5 Replay Photo Mode^
Old 02-28-2014, 10:23 PM   #10
CSG Mike
CSG Mike's Avatar
Well, a sweep isn't pre-determined... it's basically an adjustment without clicks.
KWV3 owners, did anyone remove the helper springs? YDNA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 04-19-2018 03:52 PM
2013 BRZ Limited Satin White Pearl (BBS, KWV3, etc) slates74 Cars for Sale/Trade 86 09-23-2014 05:47 PM
KWV3 | Vossen 19" CV3 | Subaru BRZ danielle@vossen Wheels and Tires 12 03-03-2014 01:17 AM
kwv3 coils bjun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-27-2013 01:17 PM
WTB: KWV3 Coilovers wahsaihin Canada Classifieds 2 10-28-2013 02:37 PM
