Old 02-28-2014, 11:43 AM   #813
Racecomp Engineering
Originally Posted by Malt View Post
I wish I would of known that when I ordered my T2's, would of saved me loads of time/money.
We're almost always a phone call away!
Originally Posted by Grip Ronin View Post
so last couple days ive been considering the wrx 4 pots. ive read just about every thread on them but im still undecided. id like braking performance to be a little better then the stocks are with some nice pads. these should give a slightly stronger bite right? do you know the oem frs piston size off hand?
What kind of improvement are you looking for? Feel, shorter distances, fade resistance?
- Andy
Old 02-28-2014, 12:41 PM   #814
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Question about bushing replacement. What is your thoughts on a car outfitted with all the Whiteline bushings they have? Do all the benefits outweigh the issues. Will the car hold the road better. I was eyeing the rear subframe bushings and diff/tran too. Any thoughts?
Thanks
DrDuquette is offline   Reply With Quote
Old 02-28-2014, 12:59 PM   #815
CSG Mike
CSG Mike's Avatar
What's your current setup? What do you want to change?
Will just upgrading pads and fluid not cut it for you?
Old 02-28-2014, 01:13 PM   #816
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
- Andy
well they do fine now with stop techs and dot4, im planning to do ss lines this yr but id like that bite that i get from driving 4 piston cars such as 370 and my boy spoon calipered s2k. plus a little bit for the look. i jus dont want to throw off the brake balance or lose peddle firmness.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-28-2014, 01:29 PM   #817
CSG Mike
CSG Mike's Avatar
What you want is upgraded pads, not upgraded calipers. Stoptech pads are still just street pads. Try a hybrid or race pad.
That Spoon caliper S2k still uses OEM pad sizes with OEM piston sizing. It's a bling item that offers more caliper rigidity, but no true performance gains.
Grip Ronin (02-28-2014)
Old 02-28-2014, 03:01 PM   #818
Agreed with CSG Mike!
I would do the 4 pot swap if I had them laying around, but I don't know if it's something I'd spend much money on. Better pads would make more of a difference.
- Andy
Old 02-28-2014, 03:01 PM   #819
Grip Ronin
The Mechanic
Grip Ronin's Avatar
how important is caliper rigidity? also is gd sti brembo run same rotor size as us?
IG-Joey_Soul
Old 02-28-2014, 03:09 PM   #820
Thanks
I'm a big fan of replacing the front control arm bushings and rear subframe inserts.
- Andy
DrDuquette (02-28-2014)
Old 02-28-2014, 03:11 PM   #821
CSG Mike
CSG Mike's Avatar
It gives you more consistency, but isn't really a concern unless you're overheating your stock caliper.
The GD STI Rotor is larger. It is 326mm or 330mm in diameter (my memory fails me..)
Old 02-28-2014, 03:16 PM   #822
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
RCE & CSG:
What are the best pads currently? (for both DD and track use)
I used to have Porterfield hybrid pads on my S13 14 years ago (I forget exactly which model; but they were the popular ones for both dd & track..I think the R4S). Are there better pads than those these days?
fooddude is offline   Reply With Quote
Old 02-28-2014, 03:54 PM   #823
IMO no such thing as "best"...
For the street, Stoptech pads are DIRT cheap and do the job. Not a track pad though.
Ferodo DS2500 is a good "agressive" street pad meaning it can take a little heat and has nice bite for auto-x but don't expect it to hold up all day at the track.
For the track it will depend on tire choice. A couple of the Pagid pads (RS5 and RS19) are really good...easy on rotors and last forever. Carbone Lorraine has a few options that are similar. Both a little expensive up front.
With our AP kit we used the AP Racing I think 300 pads. They worked fine.
CSG had a thread recently with some pads I'd like to try.
- Andy
Old 02-28-2014, 04:17 PM   #824
ZDan
ZDan's Avatar
Drives: '23 BRZ
For street/track pads, I've run CarboTech XP8s on the street for months on end on the S2000, no problems. Some brown dust but not too bad and cleans up easily. Noise runs from not too bad to nonexistent in my experience. Particularly after they've been tracked.
Also run Carbotech XP10s on the street on the FD RX-7 for extended periods, similar results. Cold bite is actually as good as or better than the street pads I use.
CSG Mike (02-28-2014)
Old 02-28-2014, 04:17 PM   #825
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ok thanx ill find out this season. i didnt push the car hard last yr cause i didnt get good tirea for it so mostly tracked my civic but this is frs yr lol. off topic but i couldnt figure out why csg sounds familiar to me. turns out its on my frs license plate lmao
IG-Joey_Soul
Old 02-28-2014, 04:39 PM   #826
CSG Mike
CSG Mike's Avatar
Originally Posted by fooddude View Post
RCE & CSG:
Best is highly subjective.
I break it down into it either works for you, or doesn't work for you (you exceed the capability of the pad). The rest is all preference; some people prefer a certain type of feel, while others may prefer a different feel.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
