Old 08-16-2013, 12:26 AM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
PST vs DSS carbon driveshafts, anyone compare?
Curious as these are both out. Both have some interesting differences on how they're made and so fourth. But there is no clear winner from what I can see as just a guy researching. Having never seen or used either of their products it's bit tough to know. PST shafts are everywhere while DSS take a few weeks to make, both are within 150 bones of each other cost wise....
Anyone that has this car have chance to compare these cf shafts to each other?
Reason considering cf over aluminum is the noise reduction of CF which makes seen to me.
Thanks if you can provide info on either or have some experience with both!
The Following User Says Thank You to OICU812 For This Useful Post:
GT86_PRAGUE (12-16-2014)
Old 08-16-2013, 01:35 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Whilst I appreciate the question being asked I doubt there will be too many people who have bought both to do a side by side comparison. I have read elsewhere of issues that have plagued the odd shaft by both PST and DSS.
Old 08-16-2013, 01:38 AM   #3
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Love my DSS cf. If you get me a PST I'll compare them for you.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
charged86 (02-28-2014)
Old 08-16-2013, 01:48 AM   #4
OICU812
Just a dude
OICU812's Avatar
Sincerely I figured no one has but had to ask cause well... Some people here spend a ton and would! Lol maybe just too early for the platform for such questions I suppose.
Old 08-16-2013, 02:16 AM   #5
OrbitalEllipses
Drives: Attitude
Ask me about any of other thousands of dollars of modifications I've done!
CFDS or even an aluminum DS is on the list for "one day" though.
Old 08-16-2013, 02:20 AM   #6
OICU812
Just a dude
OICU812's Avatar
Lol. Thanks for keeping me in check as always Orbital!
Old 08-16-2013, 05:27 AM   #7
OrbitalEllipses
Drives: Attitude
Old 02-28-2014, 08:38 AM   #8
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I want to see weights, materials and close up of flanges and brands of u joint etc before I buy
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 02-28-2014, 08:42 AM   #9
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
PST has better CF weaving
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Jason@DSG (02-28-2014)
Old 02-28-2014, 10:04 AM   #10
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
http://www.ft86club.com/forums/showthread.php?t=59392
FRS-HHH is offline   Reply With Quote
Old 02-28-2014, 11:01 AM   #11
mitosis
mitosis's Avatar
Drives: 2013 FR-S, 2008 Fit
Why do you say that? I'm genuinely curious how you came to that conclusion. Not at all trying to debate what you say there because I have no opinion or evidence of the contrary, but I'd like to see some evidence or whatever your source of such information is because I would like to know the answer about that myself. No offense but the word of some random person on the internet isn't exactly a reliable enough source of information for me to make my decision on.
mitosis is offline   Reply With Quote
The Following 2 Users Say Thank You to mitosis For This Useful Post:
Captain Snooze (02-28-2014), kiichiro (02-28-2014)
Old 02-28-2014, 04:16 PM   #12
Captain Snooze
Drives: Red Herring
Originally Posted by RallySport Direct View Post
Just to start off, this is NOT to start an argument and more to help people understand about carbon fiber and how it is used.
As chrisl stated carbon fiber strands are strong in tension, and weak in every other possible aspect(think of a rope). So to get the most strength from the fibers you want the fibers to be in tension. In any other direction all the loads are being taken up by the Resins that are used to hold the carbon together.
The interaction of the resin, the type of resin, and amount of resin has more to do with how a carbon fiber acts when loaded then just the carbon itself. Resin makes up between 35-50% of the material, and can have not only your basic components but also things like nano-carbon tunes and fillers to make it stronger or flexible. The better the resin for the application the more load the entire matrix(term used to describer carbon and resin sample) can hold in all directions but ultimately it will be the strongest in the direction that puts load on carbon in tension.
Carbon fiber is made in layers, a single layer is thin (1/4" thick piece of carbon fiber is anywhere between 75-150 layers) and each layer can be oriented in a different direction to give you the desired results. The worst way to use carbon fiber is to make it quasi-isotropic (making it the same in all directions), so manufactures will mix layers and put material in different directions depending on what properties they want from the material.
For this application the ideal placement of fiber direction is along the direction of load, which is around the shaft in the perpendicular direction. However due to the weak bond between the resin and fibers the shaft would simply sheer if all fibers were in that direction. Then if you put all fibers in the parallel direction there would be no sheer issues but you have load issues were the shaft is not able to take high loads with out bending. So it comes down to a fine balance of each different aspect.
Last but not least, unless you are the manufacture you do not know what the manufacture has done to the carbon, what carbon they use, what resin they use, and in which direction they have placed the carbon elements. Carbon fiber is typically 8-20 layers deep and each layer plays a critical part in how much load the matrix can take and in what direction. The automotive industry is driven by aesthetics, so everyone makes the outside of parts look shiny and pretty. But with carbon fiber its on the INSIDE that counts. And given that people buy majority of parts on how they look on the outside, many manufactures go out of their way to make outsides of parts look more impressive then 98% of the rest of the product. No carbon manufacture will simply come out and tell you what resin and carbon they use, what manufacturing technique, what carbon lay up, and the curing temperatures/pressure as that is the "secret sauce".
So the moral of the story is simple, you simply cant look at a true carbon fiber part and say if its "good" or "bad" with out running tests on it or getting the manufacture to tell you the recipe to their "sauce" on how they made it and so forth. Its like looking at a cut of raw steak and guessing the age of the cow and where the cow came from with out knowing all the details.
My bold.
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
mitosis (02-28-2014), SirBrass (02-28-2014), Slysdexia (12-19-2014)
Old 02-28-2014, 04:58 PM   #13
mitosis
mitosis's Avatar
My bold.
Yes, exactly. This is where I'm coming from too, and thus why I'd like some EMPIRICAL evidence of said claims. Without testing of some sort (tearing both apart and examining the layup of the fibers, pushing both to the point of failure, measuring twist/bend/etc under load, spinning both and checking for any funny resonances, etc) any claims of one being better than the other is based purely on the grounds of cosmetics (which I don't care about).
Old 02-28-2014, 05:07 PM   #14
Captain Snooze
Drives: Red Herring
Originally Posted by mitosis View Post
Without testing of some sort (tearing both apart and examining the layup of the fibers, pushing both to the point of failure, measuring twist/bend/etc under load, spinning both and checking for any funny resonances, etc) any claims of one being better than the other is based purely on the grounds of opinion,second hand stories and/or rumour.
Fixed.
DSS 1 Piece Carbon Fiber Driveshafts! Pure Automotive Transmission and Driveline 15 12-10-2013 08:44 PM
How does the TRD air filter compare to others BlackyRose Engine, Exhaust, Transmission 0 07-13-2013 06:25 PM
Where are the aluminum driveshafts? post_break Engine, Exhaust, Transmission 22 04-01-2013 05:31 PM
AT Carbon Fiber Driveshafts RallySport Direct Transmission and Driveline 33 12-15-2012 12:35 AM
