Old 02-27-2014, 11:28 AM   #799
Racecomp Engineering
Originally Posted by normancw View Post
What drop would you recommend for RCE Tarmac 2 coilovers for tracking? How is the ride height setting out of the box? I don't care how it looks.
I'm running 245/40R17 Direzza DIIs. Here's the alignment settings I'll be using:
Damper settings, clicks from full stiff (from the RCE Facebook page):
Front Rebound: 10 clicks
Front Bump: 10-11 clicks
Rear Rebound: 13 clicks
Rear Bumpf=: 7-8 clicks
Camber (recommended by Mike):
Front -3.3
Rear -2.1
Thanks!
We can preset the ride height out of the box for you to Myles' final setting. I think we were right around -1.4 inches or so, but he was playing with rake a little and I'm not sure exactly where he ended up front and rear. He has a ton of notes...
Damper and camber sounds good!
- Andy
Old 02-27-2014, 11:30 AM   #800
Originally Posted by Lee358 View Post
alright so here is my problem. I bought 17x9 +45 RPF1s they rub on the inside edge of the wheel. So my idea is to buy coil overs to push them out a little and also be able to add a little negative camber. I will be going to at least one track event this summer and maybe a autox here and there. I have been looking at the KW v3s but I'm not sure i need something that crazy and adjustable but i do want something i can DD and Track.
KW V1 or RCE T0. Better handling with the RCE T0 but slightly nicer ride with KW V1. Both great.
The speed by design coilovers sound interesting, but from the dynos and their own admission they're not really a performance coilover.
- Andy
Old 02-27-2014, 11:31 AM   #801
Need some coilover suggestions.
I'm looking for a subtle drop of 1.1 to 1.6", but I want a ride that feels as plush as OEM, at this point, I may never hit the track, or if I do start, it might be once every two or 3 months.
I do go to the drag strip since it's cheap.
I already tried the GC coilover kit, but it just bottomed out the shocks with 5/8" drop on 440lb springs.
See above post.
Bilstein coilovers may be an option for you too if they fit your tires.
- Andy
Old 02-27-2014, 11:42 AM   #802
Luis_GT
See above post.
- Andy
I'm on stockers, won't upgrade the tires till I can afford a nice set of wheels, to put some Ventus V12 or Nitto Invos on.
I was looking at the Bilstein B14, but since it doesn't have a threaded body to keep as much shock travel available, I fear it might ride the bumpstops if I drop it 1.5"
I was looking at the Function/Form, since there's a local distributor that can repair them if anything happened or the new set from Speed by design, but the latter is new and I don't know if they're good or not.
Old 02-27-2014, 12:02 PM   #803
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
- Andy
So I should save my money and not even Consider the v3s? With the V1 and t0 I have no adjustment correct? So I drive from the road to the track and just go?
Lee358 is offline   Reply With Quote
Old 02-27-2014, 01:10 PM   #804
CSG Mike
CSG Mike's Avatar
RCE T0 or Tein Street Flex are good candidates.
Luis_GT (02-27-2014), Racecomp Engineering (02-27-2014)
Old 02-27-2014, 01:10 PM   #805
CSG Mike
CSG Mike's Avatar
I'd say damper valving and compression/bump travel are the top two things that affect ride quality. Spring rate is important but not as important as those two. I will say that a firm spring rate requires excellent valving in order to have a good ride, whereas lower spring rates and only adequate valving will still be okay.
Intended application is important when picking a coilover. There are "street" coilovers, hardcore track coilovers, and some that are a mix of both...road & track Ohlins for example.
Most good coilovers, regardless of how they started, can be revalved or custom sprung to suit any application. But that may just be a waste of money and you'd be better off starting with something else.
Spring rates usually are an indicator of a coilovers intended application, but not always. Most good ones are customizable anyway.
- Andy
I love this post.
Old 02-27-2014, 01:19 PM   #806
Thanks! BTW, I already have the Tarmac 2s (through CSG).
Awesome!
Getting some info from Myles on ride heights (it's a madhouse here today).
I wrote a set-up guide a while ago but it looks like we never uploaded it. It's a rough guide, you're probably a little farther ahead already/
- Andy
normancw (02-27-2014)
Old 02-27-2014, 01:21 PM   #807
The Bilstein coilovers are designed for lowered ride heights....they're already shortened. 1.5 inches shouldn't be much trouble. Adjustable lower mounts is not a requirement for me.
I don't know much about Function/Form coilovers.
- Andy
Old 02-27-2014, 01:23 PM   #808
Only ride height adjustment with V1 and T0. It makes things easy if you don't want to fiddle with things.
V3s are flexible and a good quality coilover...you would gain a few things with careful adjustment but it's just a question of whether that extra tuning potential is worth it to you.
- Andy
Old 02-27-2014, 01:49 PM   #809
Looks like he settled on 35mm.
- Andy
Old 02-27-2014, 11:00 PM   #810
FR-S Matt
I went with the V3's now. Hoping to improve my ride quality as I'm lower, but not slammed. The ability to adjust damping for group driving events and tracking is awesome. Can't wait to put them on and learn how to adjust them.
Old 02-28-2014, 09:45 AM   #811
Malt
Drives: 2015 WRX
- Andy
I wish I would of known that when I ordered my T2's, would of saved me loads of time/money.
Malt is offline   Reply With Quote
Old 02-28-2014, 10:36 AM   #812
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
so last couple days ive been considering the wrx 4 pots. ive read just about every thread on them but im still undecided. id like braking performance to be a little better then the stocks are with some nice pads. these should give a slightly stronger bite right? do you know the oem frs piston size off hand?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
