Old 02-26-2014, 08:53 PM   #127
sw20kosh
Drives: 2013 Black FR-S
A GTX28 or similar sized turbo usually tapers a wee little bit up top. That curve looks ok to me.
I was referring to the dyno above my post, not the dyno in my post. =) If that is still what you meant then disregard this.
The Following User Says Thank You to sw20kosh For This Useful Post:
Sportsguy83 (02-26-2014)
Old 02-26-2014, 08:57 PM   #128
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Oh! I see what you mean now. Yeah, curious about it too. Usually it can hold better than that up top.
Old 02-26-2014, 09:31 PM   #129
sw20kosh
I have noticed that Dyno Dynamics and Mustang dyno's exhibit this top end torque tapper much more prominently than dynojets but this one example is very extreme.
I read that clutch slipping was an issue on the Full blown kit on e85 but surely not at these 91 oct levels of power?
Old 02-27-2014, 01:09 AM   #130
Cal3000
Drives: Panda FR-S
Originally Posted by Zach3794 View Post
Attachment 68502
Oh look, 276whp, supercharged, and 33mpg highway? Now that's delicious
What kit are you running and mods?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 02-27-2014, 01:11 AM   #131
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Kraftwerks, most everything is stock power wise aside from catback and front pipe.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 02-27-2014, 01:46 AM   #132
pmccut
Drives: Blue Subarus
A MAP sensor bigger than stock (2,3,4 BAR etc) is not REQUIRED. It is a great benefit to install a boost cut in the tune, and it IS required if the tune will be suing speed density. But is the tune is using MAF, the MAP sensor upgrade is not absolutely required.
Of course. I have the stock MAP on mine now as that is what FullBlown prefers to tune with, but I had the 3bar OMNI when I was on a Visconti tune. DeliciousTuning does SD for their tunes so the 11psi MAP sensor would be the limiting factor as far as I know. I'm at 15psi on 91 now..hoping I don't end up making less power is all..but drivability...decisions.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
The Following User Says Thank You to pmccut For This Useful Post:
Sportsguy83 (02-27-2014)
Old 02-27-2014, 01:50 AM   #133
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
when are you coming down to bill ?
I might be tuning my car in a week ( next weekend or somewhere around that time frame )
Old 02-27-2014, 01:51 AM   #134
pmccut
Next week I'll be at Infamous on Thursday to swap to the GTX3076R, Friday is the tune. I am excited
Old 02-27-2014, 01:52 AM   #135
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I am excited
I am excited too.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 02-27-2014, 01:52 AM   #136
SmsAlSuwaidi
Boosted
Omg im aiming for friday/sat im doing a gtx3076 .63 too !!!
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
pmccut (02-27-2014)
Old 02-27-2014, 02:30 PM   #137
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
They have a few on this thread http://www.ft86club.com/forums/showthread.php?t=37736
I'm worried that I'll be limited to 11psi of boost and will make less power than I am now (running 9:1 c/r), albeit hopefully with better low speed drivability.
It is the way the dyno reads, intertia dyno's read a little differently then eddy current dyno's. I am sure if you dropped this car on a dynojet you would see different numbers and curves.
In regards to boost control. I do currently use speed density but if the MAP sensor does get near maxed out I can use a hybrid mode and use the MAF sensor for additional control above that limit.
I am also sourcing another replacement MAP sensor (OEM part) that are found to be very reliable.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
pmccut (02-27-2014)
Old 02-27-2014, 05:27 PM   #138
sw20kosh
Do you have a dynojet plot? I want to see the kraftwerks kit generate ~270 whp on CA91 octane.
Old 02-27-2014, 06:11 PM   #139
Zach3794
I'd be more than happy to go dyno on a dynojet if I was reimbursed Right now the dyno we've been testing and tuning on is a Mustang, and that's been free to us so far since Bill is on good terms with Infamous. To please the crowd, however, I'm more than willing to do a dynojet run in the coming month or two to show numbers for both 91 and E85 once that is finished.
Old 02-27-2014, 06:14 PM   #140
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Is this something that is, or can be done in the Fullblown tune? I would like to creep back up to 12-13 psi again.
Thanks!
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
