Old 02-26-2014, 12:48 PM   #57
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by Foobar View Post
Just so you know, it'll get "easier" to open once you have oil in there to lubricate it. That said, it's still pretty impossible for something to accidentally move the valve into the open position while it's on our car. The clip is a nice safety measure, but really not needed unless you've got it on some kind of off-road vehicle and you're crawling around the Rubicon Trail, IMHO.
Not sure how you can fit a torque wrench over the Fumoto anyway, I had to use a crescent on it.
Anyway, I went with tighten by hand, then tighten with crescent for another quarter. Done. Oil pans and the Fumoto are pretty strong - it'll take plenty of abuse, so just get it on tight and watch for leaks over the next few days. If it leaks, tighten it some more. If it doesn't, call it a day.
you have the fumotive valve on for how long now? any leaks?
Old 02-26-2014, 12:50 PM   #58
Moletheus
Moletheus's Avatar
Drives: Raven 2014 FR-S
I've had mine for about 3000 miles now and not a single leak at all.
Sent from my Nexus 4 using Tapatalk
Moletheus is offline   Reply With Quote
Old 02-26-2014, 01:09 PM   #59
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
good to know. my fumoto valve just arrive today. going to install it in my next oil change. how is the installtion takes? easy? anything i need to beware of during install it?
Old 02-26-2014, 01:30 PM   #60
Moletheus
Moletheus's Avatar
It's kinda hard to initially get it to thread but once you get it, it screws in nice and smooth. Make sure you give it plenty of torque when you tighten it. There is a crush washer on the new valve that must be crushed. Remember, you will probably never have to remove it again. Other than that, its a pretty straight forward oil change.
Old 02-26-2014, 02:13 PM   #61
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Yes, sir!
Old 02-26-2014, 03:09 PM   #62
Foobar
SLO NO MO
Foobar's Avatar
Had it on since last spring. No leaks.
Old 02-26-2014, 03:37 PM   #63
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I have had mine on for just a few months, but no issues.....F108S
If you signup on the quickvalve.com webstie for the mailing list, they send out coupon codes pretty regularly for 5% off..
here is one.
FMT14
good till the 27th.
gdrider77 is offline   Reply With Quote
Old 02-26-2014, 03:55 PM   #64
chas3wba0
chas3wba0's Avatar
Drives: Yes
here is one.
FMT14
good till the 27th.
You're lucky yours ended up with the lever on top lol. I torqued mine down and the lever ended up kind of diagonal/downward :T
Not really a clearance issue but just makes more sense to have it away from the ground
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-26-2014, 03:58 PM   #65
Moletheus
Moletheus's Avatar
Yea, mine ended up pointing down too but it's no biggie. I've got no plans on going off road with the FRS..
Old 02-26-2014, 04:00 PM   #66
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
here is one.
FMT14
good till the 27th.
thanks so much for the coupone code, my fumoto valve already arrvie this morning. maybe give it to other 86er fellow. Good man.
Old 03-09-2014, 10:44 PM   #67
reeves
Originally Posted by Xauterus View Post
It seems to be well designed, that is why I questioned the extra hose clamps etc. Its not like an 86 will be used for offroad racing.
Speaking off-roading in an 86, I actually have to drive on all types of uneven & unpaved rural roads.. rocky, dirty, muddy, & grassy. Just a consequence of having too many friends/family that live out in rural areas. I've even has to swerve off a 2-lane road one time to avoid some debris at a pretty high speed.. ended up landing pretty hard in a flat grassy ditch but luckily there was an incline that came up back to the road & I managed to get back on the road with just a few scratches on my bumper. All of this while never slowing below 40mph.
It was something I wouldn't want to do again of course, but just making a point.. I've had mines for about 30K miles, and my [nipple-less] Fumoto valve has yet to get loose, open, or even scratched.
Old 03-11-2014, 02:23 PM   #68
wheelhaus
wheelhaus's Avatar
The lever is sprung, so when the valve is in the closed position it's pushed into a 90° channel that locks the rotation. It would have to be lifted from the channel and then turned to open the valve. The lock ring clip simply prevents it from leaving the lock channel. I was paranoid about this at first, but after using the valve I believe it's unnecessary for 99% of users.
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
mav1178 (03-11-2014), ProjectD (05-13-2014)
Old 03-11-2014, 02:29 PM   #69
Moletheus
Moletheus's Avatar
I agree, I just did my first oil change after installing the valve and I don't forsee it ever opening up on the road or off..
Old 03-12-2014, 12:35 PM   #70
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I did this on Sunday, and my fumoto valve did not open. So I would rest assured that it shouldn't be a problem. I am NOT using the locking ring either.
Fast forward to about 1:00.... Ended up something like 200 ft out in the mud.
[ame="https://www.youtube.com/watch?v=XGNncX0lxco"]Spokes #2 3/9/2014 - STX - BRZ Offroad Excursion - YouTube[/ame]
Ranatsu is offline   Reply With Quote
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 11:02 AM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 09:53 PM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 10:42 PM
