Old 02-26-2014, 01:06 AM   #1
toeout
Clunking in rear suspension
I've been chasing clunking from rear suspension. Discovered today that both rear shocks make contact with the lower control arms (SPC). Could this be loud enough to be heard inside the car?
toeout is offline   Reply With Quote
Old 02-26-2014, 01:24 AM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Easy way to tell: sit in car, have someone lightly tap rear LCA with a hammer.
Or trust my word: yes you'll hear it. That's the cause of the noise.
-alex
toeout (02-26-2014)
Old 02-26-2014, 01:35 AM   #3
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Its like the manufacturer didn't even test fit...
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 02-26-2014, 01:49 AM   #4
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Dr. Dremel would fix those LCA right up.
Old 02-26-2014, 06:04 AM   #5
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Did you have the control arms first or the coilovers? At first glance the bottom of the coilover seems very wide.
Jeff@Racer X Fab is offline   Reply With Quote
Old 02-26-2014, 10:21 AM   #6
toeout
That's what I thought. I just wanted a second opinion in case I'm making stuff up from desperation.
As far as the fix goes, at first I thought flattening that corner on the shock, but the problem is that the sway bar end link rubber bushing twists the control arm forward, till the shock makes contact. All the other bushings are either pillowball or spherical bearing ( on the shock ). So even if I file some of that corner off, it will still make contact, due to the endlink bushing twisting it.
On stock control arms, the inner bushing is rubber and won't allow the arm to twist. SPC arms have the pillow ball type inner bushing.
I got the shocks and the arms at the same time. The bottom of the shock is big and of course the corner of that hex is exactly at the narrowest spot.
I was actually perusing your website yesterday, because I think the heim joint endlinks would keep the arm from twisting forward like that. Do you have the rear endlinks in stock?
The Following User Says Thank You to toeout For This Useful Post:
AZOOZ_95 (01-21-2015)
Old 02-27-2014, 06:13 AM   #7
Jeff@Racer X Fab
Yes, we keep stock of all our suspension parts. I think I saw your order come across yesterday.
Old 02-27-2014, 12:19 PM   #8
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
They were designed to be used with the stock arms.
supramkivtt2jz is offline   Reply With Quote
Old 02-27-2014, 01:19 PM   #9
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Ah you're right, I overlooked the fact he was on SPC since they look stock.
φφκα
Old 01-21-2015, 02:47 PM   #10
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
So what was the fix for the issue?
I'm having similar problems
AZOOZ_95 is offline   Reply With Quote
Old 01-21-2015, 04:11 PM   #11
toeout
The problem turned out to be shocks themselves. I spent ridiculous amount of time and effort installing the suspension pieces and taking them off again. Putting rubber sheets between various pieces trying to isolate the cause.
In the end it was the shocks and even knowing that ,we couldn't get the non-remote version to be quiet. My final solution was to have the shocks rebuilt to remote reservoir version and my suspension has been quiet from that point on. 7 months and 12K miles.
The Following 2 Users Say Thank You to toeout For This Useful Post:
e1_griego (12-26-2015), mav1178 (01-21-2015)
rear suspension clunk Gen Issues | Warranty | Recalls / TSB 67 04-03-2015 08:52 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
PTUNING SPL Rear Suspension Arms Now Available! Ken@PTuning Brakes, Suspension, Chassis 16 12-16-2013 02:36 PM
New Cusco Rear Suspension Arms RallySport Direct Brakes, Suspension, Chassis 1 02-18-2013 12:20 PM
Clunk sound from rear suspension. j-tan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-05-2013 12:39 PM
