Old 03-14-2012, 03:19 AM   #15
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Crazy looking... I wonder how well it'll do on Le Mans
ichitaka05 is online now   Reply With Quote
Old 03-14-2012, 06:54 AM   #16
Levi
Drives: Toyota
Please, bring a new Silvia weighing 1150 kg with this 1.6l I4 making 300 PS!
Levi is offline   Reply With Quote
Old 03-14-2012, 08:04 AM   #17
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by Draco-REX View Post
The thing is, the DeltaWing was designed by coming up with the looks first, and then engineering a solution that would allow it to work. Which, in my opinion, is how you design a production car, but bass-ackwards when designing a racecar.
Do you have any idea who Ben Bowlby is?
Originally Posted by Ben Bowlby
Looking radical was never the objective – the Delta Wing shape is simply the outcome of addressing performance targets... What we have proposed for the car is not a styling exercise. Form has followed function.
Source
old greg is offline   Reply With Quote
Old 03-14-2012, 09:45 AM   #18
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
reminds me of this
only not as funny
[u2b]QQh56geU0X8[/u2b]
Old 03-14-2012, 10:37 AM   #19
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
They have the engine, all they need is a crazy well balanced, light, rigid chassis and suspension like the BRZ/86 has.
Car of the century
Snoopyalien24 is offline   Reply With Quote
Old 03-14-2012, 02:14 PM   #20
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I agree. It would be epic if Nissan got into the game. I just don't have a feeling they will anytime soon.
tranzformer is offline   Reply With Quote
Old 03-14-2012, 02:27 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Source
Part of the Future IndyCar initiative was to design a car that would LOOK unique and give IndyCar an identity among all the other formula series. I'm sure Bowlby had some of the DeltaWing's dynamics already in mind, and this gave him an opportunity to create the car. But you can be sure that looks played a significant part in the car's design.
A three legged chair isn't as stable as a 4 legged chair regardless of how you build it. And those front wheels are narrow enough to effectively be a single "leg" of the platform. I said before that I find some of his ideas interesting. The shifting of almost all weight over the rear axle to compensate for the narrow front track has merit. In theory. But a lot can happen between theory and the reality of a race in the real world with other cars.
I foresee a blow-over in the DeltaWing's future. Going down the Mulsanne straight at nearly 200mph in the dirty air behind another car seems dangerous in a car that depends so much on under-car aero and body-generated downforce.
But we'll see. I'm not hoping it will fail. I'm just very skeptical that it will succeed beyond a moderate level.
Old 03-14-2012, 02:39 PM   #22
tranzformer
Drives: Zoom Zoom
Don't you think they would have already thought of that and tested that in their models and the wind tunnel? This isn't a high school project build.
Old 03-14-2012, 03:12 PM   #23
Dimman
Kuruma Otaku
Dimman's Avatar
It's a controversial design even among professional designers. Aero-wise until recently it was just CFD stuff.
The main concerns among the traditional designers are more to do with mechanical grip/stability in cornering and braking. Apparently it is quite dependent on a computerized torque-vectoring differential, as this is basically a 2 wheeled vehicle in terms of braking, cornering and accelerating.
One major one is how it will perform under wet braking, some feel it will be more likely to for the rear to hydroplane, because it doesn't have the clearing effect of normal front tires, plus it depends on all of its braking force from the rear tires. Could lead to a very unstable condition.
We will see. It's an experiment.
Because titanium.
Old 03-14-2012, 03:17 PM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes but a chair is not a car
at the end of the day what we're after is propelling a tire through space, on pavement. Then there is junk that's attached to the tire that has to be taken into account.. and other tires.
i'm very curious how this will turn out.
Old 03-14-2012, 03:29 PM   #25
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I'm obviously not going to be able to change your mind on this point. Suffice it to say that I disagree.
Blow-overs aren't caused by turbulence. They are caused by the pitch-sensitivity of the large flat underbodies that are required by sanctioning bodies. They occur when the underbody presents a positive angle of attack to the air flow and creates lift. By virtue of the fact that the Deltawing has significantly less underbody surface area in the nose of the car, I would argue that it will be much less likely to suffer such a fate than a more traditional car.
You do realize of course that all LMP cars generate the majority of their downforce with the underbody, right?
Few race cars ever do.
Old 03-14-2012, 03:29 PM   #26
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Would like to see it on a track with other cars around it, but it looks fairly stable in this video.
[u2b]3wlQAvEfmeI[/u2b]
I didn't know they were testing at Buttonwillow! That's one of my favorite tracks besides being tore up. Too bad they didn't go over Phill Hill b/c I would have liked to see how it would handle an off camber dropoff.
Old 03-14-2012, 04:30 PM   #27
Draco-REX
Corner Junkie
Draco-REX's Avatar
Neither were these cars:
Perfectly ok.
But don't forget that with the significantly smaller underbody area, is an equally significant reduction in weight on the front. Additionally there is even less downforce being generated at the nose, which seems to be designed to actually gather air under the car:
I see that long nose as an effective lever to expose the wider rear to more air as well.
While keeping a large aerodynamic device up in cleaner air. And without encouraging lift at a lightweight nose.
And if so, the DeltaWing will be known as another flop that was only notable for its looks.
Old 03-14-2012, 04:43 PM   #28
SkullWorks
Drives: SSM LT MT BRZ
i don't recall the ELF car shown being a flop so much as outlawed...my recollection could be off but....
Remember the Chapparel? they had to come up with new rules to write it out of eligibility because they were using jet engines to create under car suction that allowed ridiculous cornering speeds...
Lots of stuff happens and isn't well accepted by sanctioning bodies and other teams, but calling something short lived a flop is usually wrong, if it didn't work well it would usually evolve for a bit before disappearing, most single showing cars are outlawed, often only because of the potential, before they even work well enough to be advantageous.
