Old 02-25-2014, 04:29 PM   #743
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by Sccabrz192 View Post
The few times I ran CS on 245/40 hoosiers I was riding the limiter all the freaking time, without the lateral grip on street tires, we'll see.
Agree with Kido though, everyone just has to pick a starting point and work from there. I chose 235/45, he chose 235/40. I may very well switch as this season gets underway as I learn more. If I had the wallet for it, I'd have a set of everything in every size I can fit on a 16-18" 7" wide wheel, but I don't.
I am going with 215s for a multitude of reasons, the largest being cost.
DylanFRS is offline   Reply With Quote
Old 02-25-2014, 07:43 PM   #744
chucky12012
Drives: 2013 Asphalt Scion FR-S
Not to change the topic of discussion, but I got my Bilstein HD (B6) struts/shocks today! They'll be going on this Saturday so that I can try them out at my local autocross this Sunday.
chucky12012 is offline   Reply With Quote
Old 02-25-2014, 08:47 PM   #745
FastWhite
Drives: Subaru BRZ Limited M/T
And yes, you have a fan club That is eagerly awaiting your review.
FastWhite is offline   Reply With Quote
Old 02-26-2014, 10:23 AM   #746
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Alright, finally pulled the trigger on some ZIIs in the 215s on the new Kosei K4Rs. Come on autocross season!
Edit: Called Tirerack and changed to the K4Rs after remembering to recheck the weights. I was told they would be close in weight before Tirerack actually had the weights for the K6Rs. K4Rs are 14.0lbs and the K6Rs are 16.35lbs... close? Not so much.
Old 02-26-2014, 12:04 PM   #747
vroom4
I wimped out and just bought another set of OEM wheels and 225/45 z2s. Its so scorching hot here all the time, I really wish I could find some RS3s as everyone says they loveeee the heat.
Ill probably got STX next season, as Im already getting the mod bug.
vroom4 is offline   Reply With Quote
Old 02-26-2014, 01:25 PM   #748
itzmik3
DBC Racing
itzmik3's Avatar
i am looking forward to hearing the reviews.
what are you currently running on?
#194 SM
itzmik3 is offline   Reply With Quote
Old 02-26-2014, 01:52 PM   #749
chucky12012
I'll be on some new Dunlop Z2's (225/45), so that will make a difference as well, but hopefully I can get a feel to some extent for improvements from the suspension versus just the new tires.
Old 02-27-2014, 05:32 PM   #750
mla163
Overthinking it
Drives: BRZ in CS
Is there any consensus on diff / tranny fluid for CS. I want to get mine changed before the season get's going.
Motul?
mla163 is offline   Reply With Quote
Old 02-27-2014, 06:15 PM   #751
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I need to do mine before Dixie and Im so torn between Motul, Amsoil and Redline!
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-28-2014, 09:02 AM   #752
piknockout
Drives: 2014 BRZ
I have Motul in the STi, will probably use it in the BRZ. As long as it's a quality brand, just pick one and go with it?
piknockout is offline   Reply With Quote
Old 02-28-2014, 09:54 AM   #753
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Motul?
I use Motul Gear 300 in the transmission and Motul Gear 300LS in the diff.
PoorMansRacing is offline   Reply With Quote
Old 02-28-2014, 11:11 AM   #754
ViperASR
Drives: 2006 Honda s2000
I think you mean I'm doing it before Dixie
ViperASR is offline   Reply With Quote
The Following User Says Thank You to ViperASR For This Useful Post:
Kido1986 (02-28-2014)
Old 02-28-2014, 11:14 AM   #755
Kido1986
Dodging cones
Kido1986's Avatar
Yes, by I need to, I mean I need to buy fluids then stick @ViperASR 's skinny ass underneath my car.
Old 02-28-2014, 12:41 PM   #756
des
des's Avatar
Motul worked for me; nice to not have the gearbox crunch anytime the temp dropped below 60.
Seems as good a place as any. The new ride! Will drop back in on CStreet as necessary to keep the local folks in line
des is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
