Old 02-21-2014, 08:13 PM   #113
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
I keep getting a wheel speed sensor CEL when im goofing off, i forgot the code, but i will go pull it tomorrow and post it!
I love this tune.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 02-22-2014, 07:16 PM   #114
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
@DeliciousTuning any update on the Innovate map that can run both 70mm and 75mm pulleys??
Sent from my SM-N900V using Tapatalk
Area86 is offline   Reply With Quote
Old 02-23-2014, 11:04 PM   #115
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Not quite done yet. I have been refining the 75mm pulley tune with and with out the intercooler on 91,92,93, 94 and E85 tunes now.
Also the 91,92,93 and 94 octane, Kraftwerks tunes have been dramatically updated and the STG1 Vortech tune has been added into the mix. The E85 tune for the Kraftwerks is still in development but very close to complete. So far it is about a 50hp increase over the 91 octane tune.
All the tunes are just about done, and after I have completed those updates I will get working on the 70mm update that works with these tunes, so you can switch between pulleys with no issues.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
Area86 (02-23-2014), Lawnik (02-26-2014), Ryan86 (02-24-2014), whataboutbob (02-27-2014)
Old 02-25-2014, 03:24 AM   #116
pmccut
Drives: Blue Subarus
For the FullBlown kit you mention a 10 psi MAP sensor is required. Does that limit the tuning to 10/11psi? What are the options for running more boost?
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 02-26-2014, 01:52 PM   #117
pmccut
@DeliciousTuning can you confirm?
Old 02-26-2014, 04:16 PM   #118
sw20kosh
Drives: 2013 Black FR-S
Are there any dyno graphs of DeliciousTuning's Fullblown turbo maps? Does it make more power than the supercharger maps?
Old 02-26-2014, 04:17 PM   #119
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Oh look, 276whp, supercharged, and 33mpg highway? Now that's delicious
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
The Following User Says Thank You to Zach3794 For This Useful Post:
Old 02-26-2014, 04:23 PM   #120
pmccut
They have a few on this thread http://www.ft86club.com/forums/showthread.php?t=37736
Originally Posted by Infamous Performance View Post
I'm worried that I'll be limited to 11psi of boost and will make less power than I am now (running 9:1 c/r), albeit hopefully with better low speed drivability.
Old 02-26-2014, 04:54 PM   #121
Deadspool
Much title. Wow.
Deadspool's Avatar
He is working on finding a sensor to go above 10psi.
The Following User Says Thank You to Deadspool For This Useful Post:
DeliciousTuning (02-27-2014)
Old 02-26-2014, 05:06 PM   #122
JerryMichaels7
Drives: Whiteout FRS
whats wrong with omni 3 or 4 bar?
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-26-2014, 05:13 PM   #123
mhiscott
Drives: 2013 FRS
I've got an Omni 4 bar left over from my Evo build... Would be nice to be able to use it on the FRS.
mhiscott is offline   Reply With Quote
Old 02-26-2014, 06:38 PM   #124
sw20kosh
Anyone know why the torque curve dies at 6k rpm? I don't believe that is typical of the kit is it?
Here is Fullblown's 91 oct graph:
Old 02-26-2014, 07:18 PM   #125
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
A MAP sensor bigger than stock (2,3,4 BAR etc) is not REQUIRED. It is a great benefit to install a boost cut in the tune, and it IS required if the tune will be suing speed density. But is the tune is using MAF, the MAP sensor upgrade is not absolutely required.
OMNI MAP sensors are kind of PoS...
It might not fit, they vary in shape and form. The 06+ S2K is the charm...
A GTX28 or similar sized turbo usually tapers a wee little bit up top. That curve looks ok to me.
Old 02-26-2014, 07:29 PM   #126
mhiscott
Drives: 2013 FRS
The Omnipower one is much larger than stock and would have to surface mount in the engine bay a plumb into a vac source. A straight swap definitely sounds easier/cleaner. I'll be getting a Honda one too I suspect.
The Following User Says Thank You to mhiscott For This Useful Post:
Sportsguy83 (02-26-2014)
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
