go_a_way1
Old 02-24-2014, 09:03 PM   #1401
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Originally Posted by FRSdrive View Post
You will get enough camber in the rear for it to tuck if you get it that low.
The fronts may need some camber plates to look decent.
I've fit 17x9 +25 no problem on my car with 10mm of tire tuck. No poke.
Okay im looking into stance super sport coilovers with camber plates so itll tuck.
My tires if anyone wants to know are 215/45/17
Sent from my SPH-L710 using Tapatalk
Kosmos is offline   Reply With Quote
Old 02-24-2014, 09:22 PM   #1402
FRSdrive
FRSdrive's Avatar
Drives: 2013 FRS, 1985 Corolla GTS (AE86)
Originally Posted by Frs123 View Post
What tire size did you go with because I have 17x10 +22 and I can barely tuck unless I slammed it to the ground. Sorry for being off topic.
Tire sizes were 215/45/17 and 205/50/17. And yes. It needs to be very low.
FRSdrive is offline   Reply With Quote
Old 02-24-2014, 09:57 PM   #1403
Frs123
Frs123's Avatar
Drives: Raven
Yea I'm running 225/35 all around.
Instagram: erik239
Frs123 is offline   Reply With Quote
Old 02-24-2014, 11:45 PM   #1404
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Just a side shot for now. I posted this on my blog to show the drop. Ive been on these wheels for almost a year now but I finally have an aggressive drop so Ill share here finally
Excuse the dirty car :P
Enkei Kojins in 18x9.5 +45 square
Tires are currently 245/40s from when I was higher but I will be getting 225s soon
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
The Following User Says Thank You to Kuzuri For This Useful Post:
IBill4You (06-02-2015)
Old 02-25-2014, 12:13 AM   #1405
REAV3R
Former Boost Junkie
REAV3R's Avatar
Drives: Ultramarine FR-S
That is absolutely beautiful.
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." ~ J.Clarkson
REAV3R is offline   Reply With Quote
The Following User Says Thank You to REAV3R For This Useful Post:
Kuzuri (02-25-2014)
Old 02-25-2014, 01:44 AM   #1406
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Originally Posted by Kosmos View Post
Test fitting my wheels no suspension yet. Any suggestions on what I should get? Wheels poke a little wheels are cosmis racing wheels xt-005r 18x9s 25mm offset. Attachment 67965Attachment 67967Attachment 67968
What's your tire size? Got these on the way already but still debating on what tire size to go with! Thinking about 215/35 or 205/40
Low&Slow is offline   Reply With Quote
Old 02-25-2014, 11:45 AM   #1407
jsu1012
jsu1012's Avatar
Drives: 13 scion frs
F 18x9.5, 34
R 18x9.5, 26
jsu1012 is offline   Reply With Quote
Old 02-25-2014, 01:53 PM   #1408
Kuzuri
__(X)__
Kuzuri's Avatar
Originally Posted by jsu1012 View Post
F 18x9.5, 34
R 18x9.5, 26
Tires? Camber? And do you rub at all at full lock? Im running 18x9.5 +45 with 245/40s. Im going to 225s but im just curious. You arent as low as me either but just want an idea
Old 02-25-2014, 02:10 PM   #1409
Brndn704
Brndn704's Avatar
I can probably help you out. Since you're sitting at a +45 offset I'm assuming your wheels and tires are tucking instead of poking. If you are planning on going 225/40 then you should have very minimal rubbing at full lock. I was running a 235/35 and never had any problems at full lock. I had 18x9.75. I hope this helps somewhat?
Brndn704 is offline   Reply With Quote
Old 02-25-2014, 03:09 PM   #1410
jsu1012
jsu1012's Avatar
225/40/18
fenders just rolled, not pulled.
No rear camber arms,
no camber plates up front. just the camber bolts.
it doesn't rub at full lock
Old 02-25-2014, 04:08 PM   #1411
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Originally Posted by moomoopanda View Post
put on some new SPC 14mm lower camber bolts this morning
-5.8 front and -4.7 rear camber. slowly coming for ya Vic. hahaha.
Lower camber bolts up front? or nah?
Thats amazing man, well done. whats w the hood on the wall? lol
SLICVIC is offline   Reply With Quote
Old 02-25-2014, 07:25 PM   #1412
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
yeah, 16mm uppers and 14mm lowers.
eventually.. i'll just notch the upper.. but I'm good with -5.8.. haha.
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
nab335 (02-25-2014)
Old 02-25-2014, 10:47 PM   #1413
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
Soo i finally cracked my front lip after adding a bit more camber . snapped some photos the other day before taking it off.
btw, are any of you Cali guys going to wekfest? stoked to receive this email!
IG: nabb335
nab335 is offline   Reply With Quote
The Following 4 Users Say Thank You to nab335 For This Useful Post:
636 (02-26-2014), Chokeefrs86 (02-26-2014), moomoopanda (02-26-2014), stancypants (02-27-2014)
Old 02-25-2014, 10:53 PM   #1414
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
*** Aggressive wheels? Post them up! *** Thread
@nab335 a set of chrome winjets and foglights would look epic, also maybe the chrome brz side granish or wtv they are called
Your car is sick man, amazing and you really need an instagram acc :/
Sent from my IBrick
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
