Old 01-21-2014, 12:26 PM   #127
Racecomp Engineering
T0 with 350 lb springs is going to be a little more sporty. The Bilsteins are good but more street oriented and soft with their progressive springs.
T0 with the 280 lb standard springs would be a closer comparison.
Rear LCA would be recommended for both to get the alignment perfect. Not required but good to have. Some go without the rear LCA and have around -2.0 camber in the rear but it depends how low you go.
T0 you do not need front camber bolts because the front struts are slotted. I think you would want the camber bolts with the Bilsteins.
- Andy
Racecomp Engineering is offline
Old 02-09-2014, 05:14 AM   #128
zzang
Drives: s2k
Just in case, i'm no suspension expert, but this is just my opinion...
Got a set of the B14's, installed a few weeks ago. Couldn't be happier. Ride for the first few days was pretty bouncy (attributable to the progressive rates) on small imperfections in the road, but less "crashy" as someone else had mentioned. After about a week, the ride is awesome. Bounciness subsided a lot, definitely feels better than stock over imperfections, much more solid feeling. bigger imperfections such as crevices in the road or manholes, etc. are infact harsher than stock, but that was expected. overall is still a better ride than stock.
After experiencing the progressive rates, I would think I'd enjoy linear spring rates more (less bouncy, although most of the bounciness is now gone after it's settled in a bit). Might be something to consider if you're looking at these. I kept the spring perch at the height that was recommended in the booklet that came with the coilovers. dropped to about two finger gaps between tire and fender.
With regards to handling, the rear is tighter than the front, so it feels a bit more tail-happy, but I haven't pushed it hard enough to have the rear-end kick out (except in the rain for fun haha). So, for example, taking off/on ramps with "spirit", the car feels less like it wants to push, which is really good IMO. The car just feels more confident.
Not sure how useful this will be, but I just wanted to share my $.02 on this set-up, since it doesn't seem like too many people have it yet/written about it.
I also want to give a shoutout (completely unsolicited) to @FT-86 SpeedFactory for the awesome deal!
zzang is offline
The Following 2 Users Say Thank You to zzang For This Useful Post:
dirtbike250x (02-10-2014), FT-86 SpeedFactory (02-15-2014)
Old 02-15-2014, 05:51 PM   #129
MrH
Drives: 20 Outback XT, 23 BRZ on order
Originally Posted by Panman View Post
Good point, however, I'm in Australia - I've left a message for Bilstein Australia, just thought that FT-86 Speedfactory as a seller may be able to get an answer sooner.
I'm looking at potentially buying @Fizz set off him.
I have a set of B16s on my BRZ. Just confirming what others pointed out: you reuse the stock bump stops in the rear. No need to cut them down. The fronts have an internal bump stop.
MrH is offline
Old 02-24-2014, 12:31 PM   #130
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Are these coilovers trackable, i am worried that people are describing the ride quality bouncy. I don't really want coilvers with adjustment, rather want a coilover that is set up properly from the factory. I am a fan of the kw but not inclined to it because of the adjustments. Would the b14 be as good as the kw v3, if i wanted a coilover without damping adjustment.?
vignesh is offline
Old 02-24-2014, 08:43 PM   #131
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
You should be comparing the KW V1 and B14 as they're both non-adjustable (apart from ride height). I have the B14 and they're not bouncy at all. Firmer than stock yes, but not bouncy.
The V3 would be better than both simply because it has damping and rebound adjustments...but they're also dearer.
Fizz is offline
Old 02-25-2014, 11:17 PM   #132
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
how are these compared to the FA500? I'm not too picky on having a super comfortable car ride since this is a sports car. So for Auto-X, Track, spirited street driving, which will do the job better?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline
Old 02-26-2014, 04:32 PM   #133
Alamexico
K9 FTW
Alamexico's Avatar
Drives: 2013 Scion UMB FRS
So These B14's will there be any fitment issue with 17x9 +35 wheels on 255/40 R17 DZ01 tires lowered enough to have about to have no gap? Im trying to run the last amount of camber.
Alamexico is offline
Old 02-26-2014, 04:58 PM   #134
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You should be good to go.
FT-86 SpeedFactory is offline
Old 02-27-2014, 05:13 PM   #135
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
Can anyone give me a comparison between the B14 and B16s on our cars? I've heard on previous cars that the difference isn't too drastic to justify B16s in place of B14s. I forgot which chassis but word has been that the extra adjustments were basically useless.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline
Old 03-07-2014, 12:38 AM   #136
zzang
Drives: s2k
I may have over done my description above. The ride isn't bouncy at all anymore. It honestly was pretty bouncy the first few days, they aren't bouncy at all anymore. I don't know why, but it just was like that for me haha.
zzang is offline
Old 03-07-2014, 11:04 AM   #137
RYU
RYU's Avatar
Drives: really slow...
What wheel/tire combo are you on btw?
RYU is offline
Old 03-07-2014, 11:33 AM   #138
zzang
Drives: s2k
I'm on 18x8.5 +33 and 225/40 tires all around.
zzang is offline
Old 03-07-2014, 11:35 AM   #139
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
i just ordered these bilstein pss b14s and this is my set up
Rims: gram light 57 dr 18x8.5+38 & 18x9.5+38
tires: Falken ZE-912 235/40ZR18 95W & Falken ZE-912 265/35ZR18 97W
im just trying to lower it about an inch or less. do you think i need camber bolts? or what do you suggest?
FRS-HHH is offline
Old 03-14-2014, 12:35 PM   #140
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
So B16s with 18x9.5 +43 255 rub on the front?
GirlRepellent is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
