Old 02-23-2014, 10:41 AM   #15
philstar
philstar's Avatar
Drives: Argento FR-S
I prefer pulling out the ABS fuse for drifting.
philstar is offline   Reply With Quote
Old 02-23-2014, 01:05 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
do you notice the loss of the brake force distribution at all? just curious..
Old 02-23-2014, 03:17 PM   #17
Akari
Drives: 2013 DGM BRZ
Honestly one of the best things you can do is hit up a local skidpad and give them all a try for yourself.
After a good amount of time on the skidpad my determination was to run #4 all the time, street and track(unless I'm tired, hungover, in a bad mood, etc).
Akari is offline   Reply With Quote
Old 02-24-2014, 11:48 AM   #18
RICEBOY_86
RICEBOY_86's Avatar
Drives: whiteout FR-S
I'm sorry but what is " pedal dance" please explain....
RICEBOY_86 is offline   Reply With Quote
Old 02-24-2014, 12:45 PM   #19
chc36
Drives: 2013 FR-S Ultramarine
http://www.ft86club.com/forums/showthread.php?t=25494
basically it turns of all the TC etc, puts it into a diagnostic mode usually recommended if you're on a track. Doesn't disable ABS though
chc36 is offline   Reply With Quote
The Following User Says Thank You to chc36 For This Useful Post:
RICEBOY_86 (02-24-2014)
Old 02-24-2014, 03:31 PM   #20
kevman_101
Drives: 2013 Scion FRS
Everything off will let you drift to full potential. I`ve spun out and had no TC or anything kick in. Trying to drift in normal, or sport mode is not going to go good. You will get jerked around real good hehehe. But when pushing the limit, sport mode will let the tail slide a bit more before it get`s it back in line. Just chucking it in to slide it, the system is going to made the car vibrate like hell and pointed in the right direction pretty quick. I tried that too, and it was not pleasent hehehe.
kevman_101 is offline   Reply With Quote
Old 02-24-2014, 07:56 PM   #21
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
For autocrossing I use option 4 full off. I don't do the pedal dance. Haven't tried it but most reports from autocrossers is that it messes with the brakes.
Ocala FR-S is offline   Reply With Quote
Old 03-02-2014, 02:26 PM   #22
root
Drives: Raven FR-S
Looks like I'll have to try the pedal dance next auto X. I've been running with TRAC and VSC off, but have been experiencing when I spun out can feel/hear the brake system trying to do things. Since I'm spinning out that doesn't really bother me since I goofed and the run is ruined, but what I've been encountering is it kills the engine and doesn't restart immediately. Which is a hazard to the next car on course, I want to get going as soon as possible to clear the course.
root is offline   Reply With Quote
Old 03-02-2014, 03:59 PM   #23
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Assuming you have a manual, this should never happen if you react correctly to the spin -- "both feet in and come to a complete stop".
Besides, the corner workers should be dealing with the cars behind you while you compose yourself and turn the wipers off...
993Fan is offline   Reply With Quote
Old 03-02-2014, 06:47 PM   #24
Shawnofthedead
Shawnofthedead's Avatar
Drives: Black on black with so much class
I turned my abs off completely by off ye be warned tho you'll end up in a ditch if you're not careful.
Shawnofthedead is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Traction Control Question Canehda Issues | Warranty | Recalls / TSB 30 10-22-2013 07:19 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
