Old 02-24-2014, 08:37 AM   #785
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Love this track. Can't wait to break in the new shoes.
Old 02-24-2014, 10:08 AM   #786
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
Looking forward to your thoughts on the new setup. I was planning on wearing out my stock tires but with the brake upgrade they are even more ridiculous.
GTHachiRoku is offline   Reply With Quote
Old 02-24-2014, 10:08 AM   #787
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Basket Case View Post
I did this to my last few cars. I am glad you tried it on this one. Living in the south I have no need for a self warming throttle body, lol.
What's the benefit of doing this?
I'm on my phone so if I make mistakes, blame Sportsguy83
^GT5 Replay Photo Mode^
Old 02-24-2014, 10:32 AM   #788
M1K3
M1K3's Avatar
Drives: vrooom...
Originally Posted by ATL BRZ View Post
My Whiteline top mounts gave me enough clearance by pulling the whole front strut assemblies back for negative camber.
Just a little FYI, I too have Awesomes with -2.00 camber up front and I get a little bit of rub. To remedy this I run a 3mm spacer up front.
M1K3 is offline   Reply With Quote
Old 02-24-2014, 11:07 AM   #789
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
holy hell that looks good.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 02-24-2014, 03:52 PM   #790
2pt5RS
Berz
http://www.ebay.com/itm/Autoart-SUBA...item27de4b4f2e
You might want to contact this person and let them know that's YOUR car and YOUR picture...
2pt5RS is offline   Reply With Quote
Old 02-24-2014, 05:42 PM   #791
ATL BRZ
ATL BRZ's Avatar
WTF
Old 02-24-2014, 07:01 PM   #792
ATL BRZ
ATL BRZ's Avatar
Epic day. Front tires never touched the spring perches, but just barely rubbed the fender liners under full compression. No big deal.
Ran great on Sunoco 98. No issues at all other than not being able to keep up with Jack Baldwin in his Pirelli World Challenge GTS champion Cayman... :LOL:
GoPro footage awaits upload. Wheel and tire feedback will come with it.
Old 02-24-2014, 10:25 PM   #793
ATL BRZ
ATL BRZ's Avatar
I took off the front wheels today in the paddock and checked the inside sidewalls and they were perfect, so I'm pretty sure the outsides are rubbing on the fender liners but only with really high cornering loads and full compression which was only at one spot on track at Barber. I think spacers might make it worse.
It's probably happening because I'm running a relatively soft spring (250 lbs) on the stock struts and my while my bigger RCE sway bars help a lot, I think adjustable coilovers may be the only true remedy. I doubt rolling the fenders would help much since the 245's aren't that wide.
Old 02-24-2014, 11:00 PM   #794
Caboose
Drives: WRB BRZ Premium
Is that the Jon Motoring front lip? Can you comment on the quality?
Thanks
Caboose is offline   Reply With Quote
Old 02-24-2014, 11:47 PM   #795
ATL BRZ
ATL BRZ's Avatar
Thanks
No its from eBay: http://m.ebay.com/itm/281239336892
Quality isn't that great but it fits well and looks nice. I wasn't trying to spend more than $100 on some polyurethane that will get scraped up eventually. If this one gets messed up I won't lose any sleep at night over it.
Old 02-25-2014, 12:02 AM   #796
smbstyle
smbstyle's Avatar
how does it install? require any drilling?
2013 SWP BRZ
Old 02-25-2014, 12:11 AM   #797
ATL BRZ
ATL BRZ's Avatar
Yep pretty easy install. Just mock it up with a buddy and some masking tape, drill smaller holes in the pre-marked holes, then use the provided screws to secure it to the bottom of the bumper cover. I did it in my garage myself with some random boxes to hold it up and tape it down to fit it. Used a creeper to make it easier.
Old 02-25-2014, 07:43 AM   #798
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
New shoes look great! How do they compare to Enkei's? You can be honest, I already sent the money ;-)
Bg8780 is offline   Reply With Quote
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
