Old 02-24-2014, 04:52 AM   #1
happytimetom
happytimetom's Avatar
Drives: 2013 Black 86 GTS
Spacers? Springs? Help.
Hey guys,
After much deliberation I have decided that my first proper mod to my 86 will be to try and achieve a proper flush look with my current wheels. I'm certainly not a suspension or wheel guru and would like some help working out how to get a nice setup, preferably without it costing a mint, though there is money available to spend.
So I currently have 18x8.5 rims with 235/40 tires on all 4 wheels.
As you can see the back tucks a lot more than the front and the end goal is to have them both flush...ish. I'd also like to lower the car somewhat, though after buying a "pre lowered" car in the past I definately DO NOT want to have it scrub on every crack in the road, while also maintaining the stock feel and ride.
Any suggestions on how to calculate correct spacer size, whether to buy coilovers or are springs good enough to achieve what I want?
Also might Add I'm Australian, if anyone can suggest places to buy things that would be tops And yes, I'm blacking out those annoying stripes on the inside of the rim, I didn't pick them blame Toyota.
Name:  DSC_0423 small.jpg
Name:  DSC_0426 small.jpg
happytimetom is offline   Reply With Quote
Old 02-24-2014, 05:34 AM   #2
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
I think the ring or stripe adds contrast to the car. The "Batman" look is played out. The wheel stripe will help to accentuate your ride once your car is lowered!
As for your dimension question, there's a calculator here someone was kind enough to create and share. Try looking by the search feature. God speed!
**Update**
I think this is it! Posted by ITDANSHARPE!
Auto Fitment Calculator
http://www.frsproject.com/tire_size.php
Wolfking is offline   Reply With Quote
Old 02-24-2014, 05:53 AM   #3
happytimetom
**Update**
So... Total noob speaking here but if I calculate offset using that calculator that should be roughly the size in mm of the spacers I need? Will this change much once lowered?
Old 02-24-2014, 07:38 AM   #4
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
In theory, I believe that is correct...if you mean adding for example a 5mm spacer, that would make your wheel then become an even 9mm according to the calculator! **I think!** You may want to PM Mr. Sharpe! Your goal is flush or very close ti it. From the pic it appears that you are flushish...
**REMEMBER**
You don't want to go too wide unless you don't mind rolling your fenders!
spacer, springs, wheels
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 08:52 AM
Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels Calin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 12-12-2014 02:25 PM
Wanted to show off my Christmas gifts (RS*R springs + B2autodesigns spacers) Dvst8or FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 01-11-2014 11:53 AM
Black Friday Sale! Berk, V3 Spacers, Swift Springs, Greddy, ARK peformance Corner3garage Announcements, Contests, Giveaways 19 12-06-2013 08:39 PM
WTB: Spacers abutterman Wheels and Tires 3 05-12-2013 06:11 PM
