Old 02-22-2014, 01:24 PM   #1219
jflogerzi
jflogerzi's Avatar
Originally Posted by jordanrw260 View Post
I have the stock intake box with the sound tube removed by having the perrin tube. HKS drop in instead of stock filter.
Perfect the OFT Maps will work perfectly with that setup. I have the same setup:
Borla UEL
Motiv OP
Stock FP
Perrin 2.5 Resonated CB
Stock Intake box with TRD Filter and Perrin Inlet tube W/ noise generator delete
Car feels great with Shiv's tunes. Run E85 if you can
The Following User Says Thank You to jflogerzi For This Useful Post:
Shiv@Openflash (02-22-2014)
Old 02-22-2014, 05:59 PM   #1220
Mixlplix
For a stock car you use the Stage 1 maps on petrol
If you want to run E85 on a stock car use E85 stage 2 EL Header map.
Changing intakes can upset the MAF (mass air flow) calibration used in any of the maps (they have been optimized for stock intake), especially if the maf sensor housing is changed or the diameter of the intake tube changes. If the TRD intake uses standard intake tube where sensor sits then you may get away without re-scaling the MAF . Its not going to cause a major problem just will not be optimal AFR
You can do it yourself if you read up on it or opt for the e-tune package from Vishnu (OFT).
So i guess i need a response from Shiv concerning the TRD intake.
Mixlplix is offline   Reply With Quote
Old 02-22-2014, 06:01 PM   #1221
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
The TRD intake was designed to run without a tune, the OTS maps should be fine.
- AdrianG
AdrianG is offline   Reply With Quote
Old 02-22-2014, 08:48 PM   #1222
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
- AdrianG
Well my TRD Intake doesn't like the the stock MAF Scaling much. It's turbulent but I think can tame it with a few runs through OLMAFTool. I've also purchased a honeycomb air straightener which I'm hoping will help stabilize the air flow past the MAF sensor. If it doesn't help I will have wasted a whole $11.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 02-22-2014, 10:04 PM   #1223
MstrSHAKE
MstrSHAKE's Avatar
Drives: 2014 SWP BRZ
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread
Edit: no launch control supported in B-series rom :/
MstrSHAKE is offline   Reply With Quote
Old 02-23-2014, 04:45 AM   #1224
steve99
Drives: FT86
He would be the one to ask, I pretty sure he will have tuned a car with a TRD intake and can give you the correct info.
Old 02-23-2014, 02:32 PM   #1225
SliverBrz
Drives: Silver 2013 BRZ limited
What about any other intake ? has anyone ran other intakes with the oft tunes?
SliverBrz is offline   Reply With Quote
Old 02-23-2014, 05:43 PM   #1226
steve99
Drives: FT86
I believe they have but their seems to be very little power increase (if any)obtained by changing intakes and if you do you will most likely need to rescale the MAF . I think @shiv@vishnu and @jamesm will confirm this. Just add a drop in filter and modify snorkel if your after a couple of HP, that about what most after market intakes will provide.
OFT tunes are done on stock intake, with modified snorkel and drop in filter but work fine with standard filter and standard snorkel.
see here
http://www.ft86club.com/forums/showthread.php?p=1297833
I think shiv also shoved in a 20oz soda bottle and heated it to expand the intake of the cut down snorkel.
your better off spending you money on headers than intakes.
If you want more than about 40Hp increase (headers/full exhaust/tune/E85/modified snorkel/drop in filter) you need to go forced induction.
Your better off making that decision at the start to avoid wasting money.
Old 02-23-2014, 07:09 PM   #1227
jamesm
^ yep.
Old 02-24-2014, 12:16 AM   #1228
keen as
keen as's Avatar
Drives: 86 GT MT
Is there support for Flex-fuel? (I apologise if I have missed this info)
keen as is offline   Reply With Quote
Old 02-24-2014, 02:27 AM   #1229
steve99
Drives: FT86
With the OFT you get petrol mapping or E85 mapping, according to shiv the E85 map will work with variations between E60 and E90.
However there is no true flex fuel support ie no fuel sensor feeding info to ECU to adjust tune. So you have to run petrol or E85 and their is no failsafe if you fuel up with wrong fuel.
however this may change in the future
keen as (02-25-2014)
Old 02-24-2014, 03:03 AM   #1230
steve99
Drives: FT86
Originally Posted by troek View Post
this is on my stock tune, Shiv is still working on the files for the japanese ECUs. so i was messing around the data log trying to see how all this stuff works. is the advance multiplier supposed to be zero on the OEM tune?
IAM monitoring only works on USA rom at present, hopefully early next week new update will be released ans it will work for all rom types, I am waiting on this also
troek (02-24-2014)
Old 02-24-2014, 09:45 AM   #1231
troek
troek's Avatar
Drives: 2012 Toyota 86
oh cool thanks for the good info.
troek is offline   Reply With Quote
Old 02-24-2014, 02:25 PM   #1232
Tiremonkey0824
Drives: 2013 Argento 6mt
When i first loaded my stage 2 e85 tune my AFR was reading 14.7 while cruising and on idle. As of yesterday i had to re-write the tune and its been 14.3 while cruising and idle and 11.8-12.3 during WOT. Is this something i should worry about?
Tiremonkey0824 is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
