Old 02-22-2014, 06:00 AM   #15
troek
troek's Avatar
Drives: 2012 Toyota 86
so on the NA FA20 you would see no benefit of the AFR being closer to 13?
troek is offline   Reply With Quote
Old 02-22-2014, 11:37 AM   #16
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by jamesm View Post
i think you mean shoot for 12.5:1 then add 5-10%.. right? i've never done it that way.. interesting idea. so you dial the whole maf (or ve map) in @ 12.5 and then just go through and add the correction globally? i might have to try that next time .
Yeah that's it. Disclaimer here is that don't do this with overly advanced timing and don't do it in tall gears. A run in 2nd or maybe 3rd under watchful eyes should be safe for a time or two, it is a short run in those gears. Then watch the learning trims to make sure that it didn't change stuff on you.
Every car is a little different, but generally more often than not we make more power at 12.5 than 13 NA. That varies with RPM though.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
jamesm (02-22-2014), troek (02-22-2014)
Old 02-23-2014, 01:54 PM   #17
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Hhhhmmm I had always thought that corn needed to be a point rich not a point lean from pump gas.
My wrx was tuned 11.2-11.0 on pump since I had a top mount always thought a good front mount would allow half a point leaner and make more power.
Learn news things everyday.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-23-2014, 02:02 PM   #18
arghx7
Drives: car
You have to be careful here. Ethanol is always going to be "richer" in the literal sense of air to fuel ratio than gasoline because its stoichiometric point is richer. However, it can require less "enrichment" (in terms of lambda) because it has a cooling effect and less tendency to knock.
The Following 2 Users Say Thank You to arghx7 For This Useful Post:
jamesm (02-23-2014), Sportsguy83 (02-23-2014)
Old 02-23-2014, 03:04 PM   #19
StormTrooper
Ahhh makes sense....
GR86 MT premium
Old 02-24-2014, 07:00 PM   #20
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Good stuff. I really need to upgrade to the racerom and tie my wideband in, then get a proper tune...man i need to find a good tuner......killing me.
gdrider77 is offline   Reply With Quote
Old 02-24-2014, 07:14 PM   #21
stugray
Drives: 2013 GBS BRZ Limited
Just for the hell of it.
Here is my first log from my car:
Red & Orange are EGTs and blue is innovate WB AFR.
You can even see where I shifted.
It isnt a BRZ, but it IS a 4-cyl, 2.0L boxer engine (aircooled vintage 71)...
Subaru BRZ - Dual Zone Climate Temperature - Wrong? Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 21 03-22-2015 02:11 PM
Typhoon buffets Tokyo, heads into tsunami zone Marrk Off-Topic Lounge [WARNING: NO POLITICS] 1 09-21-2011 03:23 PM
