Old 03-12-2012, 10:55 PM   #1
Pakjk89
Drives: 2010 VW GTI
BRZ/FR-S Vs. Civic SI
More than the driving dynamics, I am thinking the engines were somewhat comparable. Besides the obvious (vtec vs NA) Power figures are almost spot on (last gen civic si). Anyone car to speculate if the engine will act similarly because of this?
Pakjk89 is offline   Reply With Quote
Old 03-12-2012, 11:14 PM   #2
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
uhh, vtec is na...
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 03-12-2012, 11:22 PM   #3
Pakjk89
Drives: 2010 VW GTI
Originally Posted by NESW20 View Post
uhh, vtec is na...
Yeah but aren't their slight differences between vtec and a normal NA?
Old 03-12-2012, 11:31 PM   #4
serialk11r
Drives: '06 AM V8V Coupe
I don't think there's a such thing as a "normal" NA...VTEC is just a particular variable valve actuation system.
Anyways, the Civic is probably a bit stronger below 3000rpm because of VTEC, the FA20 has pretty crappy low end torque because it only has cam phasing, but the Civic weighs more and has FWD.
Old 03-12-2012, 11:32 PM   #5
TheBoogieBot
Drives: SWP 6 Spd Limited
VTEC is just the way the valves work. Toyota and pretty much every auto maker these days makes their own version of VTEC. They do use VTEC on turbo cars also though.
As for your other question I'd say the Civic SI would be slightly slower then the FRS because the weight of the scion is less.
TheBoogieBot is offline   Reply With Quote
Old 03-12-2012, 11:33 PM   #6
NESW20
2.1L 3SGTE
different cam profile. not enough to warrant a new category of n/a.
back to topic, i think both cars will be a lot of fun and drive quite well. the civic is going to be more practical for carrying people (especially if you get the sedan) and the K20 responds very well to mods. IMO, you can't go wrong with either car.
2008 Civic Si Sedan
Old 03-12-2012, 11:34 PM   #7
GT
GT's Avatar
Drives: N/A
vtec stands for Variable Valve Timing Engine Control. Its the timing for the cams of the engine which can can SOHC or DOHC (single or double).
EDIT: replied too late lol
GT is offline   Reply With Quote
Old 03-13-2012, 12:14 AM   #8
Dark
Elite Padawan
Dark's Avatar
Last generation Si has 197hp and 140lb.ft of torque, and it does 6.7sec about the same as FR-S/BRZ 0-62 in 6.9sec. The new generation is 200hp and 170lb.ft of torque. It's faster than the last gen and FR-S/BRZ straight-line( if that's all you care). It will probably be faster than FR-S at the track with summer tire package.
Dark
Dark is offline   Reply With Quote
Old 03-13-2012, 12:16 AM   #9
serialk11r
Dark I think you should hold off on that conclusion until independent tests are done, there are quite a few factors in the BRZ/FRS's favor such as ~6% less weight, RWD, not to mention that the gears seem too short to hit 60, which means the acceleration under 60 will actually feel stronger...The ft-lb number doesn't mean squat, what's important is that the Hondas don't have a torque dead zone below 3000 while the BRZ does, but a mild launch will take care of that disadvantage.
Old 03-13-2012, 12:22 AM   #10
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
uhh, vtec is na...
"Yo VTEC just kicked in!"
tranzformer is offline   Reply With Quote
Old 03-13-2012, 12:24 AM   #11
Dark
Elite Padawan
Dark's Avatar
That's why I said "probably". However, this generation Si really produces more power than the old one. It has grown a bit though.
Dark
Old 03-13-2012, 12:32 AM   #12
serialk11r
Oh snap I just realized the Si loses breath pretty fast at the top of its rev range (200hp at 7000...wtf?), so its off the line acceleration is very high. I guess it's probably a close call then.
Old 03-13-2012, 01:19 AM   #13
Maxim
Drives: 2010 GTI 2dr Tornado Red
Based on the nearly 200lb weight difference between the cars, and the fact that the BRZ/FR-S is RWD and will actually put the power down in 1st gear, I'd say no contest. BRZ/FR-S will probably be marginally faster in every respect except maybe top-gear acceleration. It will certainly be faster on a track, especially if you put the same tires on both cars.
On a prepared drag-strip, they'll likely be very close, but in real world conditions, where traction is more limited and road conditions aren't perfect, the RWD layout is going to give a massive advantage to the BRZ/FR-S off the line. I've got a high-powered FWD car....launching it is a huge pain in the ass.
Maxim is offline   Reply With Quote
Old 03-13-2012, 01:26 AM   #14
Capt Canuck
Drives: BMW E36 323is
I guess we'll see in 2013 Lightning Laps how it does in comparison:
http://www.caranddriver.com/features...1-class-page-3
Obviously different weather and drivers skewer any real direct comparison, but be interesting to see nevertheless.
Capt Canuck is offline   Reply With Quote
civic, civic si, honda
Why are Civic owners such tools? LexusFman Other Vehicles & General Automotive Discussions 29 11-28-2011 06:20 PM
AutoExpressUK: Honda Civic Type R is back quik1987 Other Vehicles & General Automotive Discussions 36 10-18-2011 01:15 PM
CR says Civic is a loser. 1660 Other Vehicles & General Automotive Discussions 9 08-02-2011 12:44 PM
2012 Honda civic VenomRush Other Vehicles & General Automotive Discussions 38 05-17-2011 04:26 PM
1995 Honda Civic DX - Brake Lights Siriusly.Andrew Other Vehicles & General Automotive Discussions 7 02-18-2011 07:14 PM
