Old 02-20-2014, 07:00 PM   #1191
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by 2point0 View Post
I switched to E85 on Saturday and took it easy for the day. Then on Sunday, I started feeling that extra oomph! Then...at exactly 40 miles from fill up, I got a CEL. I pulled over and read P0351. I reset shortly after and have over 100 miles on this tank now without the CEL coming back up.
When the code was thrown, I had cruise control on and had just started going up a pretty decent incline, then suddenly felt a loss of power as CC was disabled. I have since done several WOT pulls and am not sure if the code was a fluke or what. I've read some posts that others have had this and needed to get their #1 coilpack replaced.
Otherwise, loving the E85! I crunched some numbers and found that I can stand to lose 4mpg without decreasing my $/mile due to E85 being so much cheaper. Win-win!
I've had this CEL come up a couple of more times now, but it's very inconsistent. I've read of guys getting this at the track and it's a faulty coil pack, but I get it when cruising in town. The one time I had it come up while I was logging, I couldn't find that spot in the log to save my life (it was a 40+ min drive or so). That time, I was going up for a mountain drive and got the CEL on the way there and again on the way back...NOT when powering up or down the mountain.
Just happened again this morning on the way to fuel up (yup, still E85). Cleared it and didn't see it again on my way to work (30-ish miles).
I went out on lunch and logged (up an incline...no flat roads here).
3rd-4th gear: http://datazap.me/u/2point0/oftstg2-...log=0&data=1-9
Pretty sure this was 3rd also...http://datazap.me/u/2point0/oftstg2-...log=0&data=1-9
Anyone have thoughts on this? I'm no tuner, and have been learning as I go, so I can't just look at a log and go "yup, looks good!" To my untrained eye, nothing looks terribly disturbing here.
I'm not overly concerned that something will blow up, since the CEL doesn't come back consistently and there are no strange noises. I'm inclined to agree with the guy who said it was likely a rich condition, but how rich does it need to be to throw this code? I thought it was the E85 pump, so I filled up the last two times at the slightly more expensive one nearby and still got it.
Maybe the answer is to just add the OFH...
I'm halfway tempted to switch back to (shudder) 91 octane and see if I get the CEL, but when I see the $4.05+ sign, I cringe. Especially knowing that I'll lose most of the OOMPH.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-20-2014, 07:50 PM   #1192
steve99
Drives: FT86
Probably worth a read here
http://www.ft86club.com/forums/showthread.php?t=36008
http://www.ft86club.com/forums/showthread.php?t=52688
coil pack or DI seal , most likely coil if your not getting any popping sounds with CEL
Old 02-20-2014, 08:27 PM   #1193
yuicebox
Drives: Asphalt FRS
If you're getting CELs that relate to coil pack or DI seal failure, I would HIGHLY recommend testing stock tune and stock ECU flash ASAP.
If you do have DI seal failure, it can probably be covered under warranty, but if they see e85 in your tank or a custom tune on your ecu, your warranty is fucked.
Engines aren't cheap!
yuicebox is offline   Reply With Quote
Old 02-20-2014, 08:36 PM   #1194
2point0
2point0's Avatar
Thanks, I've actually read those already. I'm not revving 7800+ though and no funny noises.
I suspect it's more related to fueling simply because I have over 40k miles and this CEL has only come up recently, and the first time was the day after switching to the Stage 2 E85 map. Like I said, I should probably go back to regular fuel to rule that out, but I don't always get a chance to run it that low with my long commute and no E85 near work.
Old 02-20-2014, 09:37 PM   #1195
steve99
Drives: FT86
I ran that map on E85 and no problems, shouldn't be a fueling issue unless you have modified intake or aftermarket intake that would upset maf scaling.
couple of guys here have had coil packs go and on stock tune
I'll put a $1 on it being a coil pack unless you got a really bad batch of fuel
Old 02-20-2014, 10:54 PM   #1196
2point0
2point0's Avatar
Hehe I can put that $1 to good use, too. It'd have to have been several bad batches of fuel, because this is between a couple of weeks. Nothing modified with the intake other than Perrin drop-in and sound generator delete (obviously makes no difference). And the OFT maps were designed with a replacement filter in mind.
Hopefully I can burn through this latest tank this weekend so I can get back on the stock tune. Figure there's always the chance that the dealer will want to update my ECU for something anyway. I'm not opposed to telling them I was on E85, as long as I can replicate it on the stock map.
Old 02-20-2014, 10:57 PM   #1197
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Yeah I've heard of a few people had coil packs go on them....
On a side note.... What are the chances of an updated cam timing map for either of the two new EL headers.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-21-2014, 01:37 PM   #1198
jflogerzi
jflogerzi's Avatar
Don't run the car on E85 with the stock map. Very bad idea and the dealer will try to void your warranty. My suggestion go back to pump gas. Run through 1-2 tanks and see if you get the CEL. If you do, get your car into the dealer and don't clear the code. Your Ethanol rating at the station you fill up at might be to low for the OFT tunes.
Old 02-21-2014, 01:52 PM   #1199
2point0
2point0's Avatar
This is pretty much what I meant. Maybe I wasn't clear, I have no intention of running E85 without the proper tune. I have a long commute with E85 only on one end of it, so I don't always have an opportunity to run the tank super low. Once I can, I'll switch to 91 and go back to the stock map.
Old 02-21-2014, 02:15 PM   #1200
jeebus
Don't tell them you were on e85. Bad bad bad idea. If you are getting coil pack codes, I'd wager to guess a coil pack is failing. As others have said, get 91 in your tank, flash back to stock, and drive until the code comes back (it probably will), then take it to the dealer.
On a side note, your logs look good.
jeebus is offline   Reply With Quote
Old 02-21-2014, 03:21 PM   #1201
jamesm
or you could just spend a couple bucks on a coil pack, save yourself the trouble, and not commit fraud. to each his own i guess...
Old 02-21-2014, 04:09 PM   #1202
jeebus
I'm 100% a-ok with fraud since many of us are running tunes to PROTECT our cars from damage since Subaru/Toyota will not flash our ECUs with the flash that helps prevent transient knock.
Now, someone that blows up a motor from an aftermarket turbo running eleventy billion pounds of boost @ 14:1 AFR...that I'm not ok with trying to cover up.
Old 02-21-2014, 04:20 PM   #1203
jamesm
why won't they flash the new roms? i've never had to ask them to (i just fixed mine myself), but aren't they obligated to do that when they come out?
fwiw i wouldn't let a dealer even drive my car long enough to take it into the service bay and look it over, so the warranty doesn't mean anything at all to me. i knew it was gone the day i bought the car, wouldn't use it even if i still had it. i've worked at enough dealerships not to trust those idiots with anything.
Old 02-21-2014, 04:28 PM   #1204
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Exclamation
Sadly, no
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
