Old 02-20-2014, 03:35 AM   #477
mfbmike
Drives: 2013 FRS, 2008 R32
And another...
mfbmike is offline   Reply With Quote
The Following 2 Users Say Thank You to mfbmike For This Useful Post:
Acree (03-17-2014), Hicklinc (02-05-2018)
Old 02-20-2014, 03:59 AM   #478
shattered_memory
Drives: Satin White BRZ Limited
Originally Posted by mfbmike View Post
I don't think anyone argued that their wide wheel & meaty tire setup was breaking any lap records. lol.
Yes, you will see a slight decrease in overall acceleration and mpg's as a result of the extra rotational mass.
Also, (been a long while since I watched that vid) I think the lap time on the 235's was just slightly slower than the 215's. Lateral grip increased iirc as well. With that being said, yes, 18 inch wheels and 255+ tires ARE unnecessary and probably unreasonable for this car under stock power. Not every mod needs to need an explanation. It's my car. lol.
Still looks awesome. Having grip for days is a blast.
Don't get me wrong, I do love the meaty tire look (Your car looks awesome btw), but I since I do plan on tracking my car, I want to get the most function out of upgrading to the right wheel/tire size. What I notice is that wider tires do improve overall grip, but going bigger than 245/40/17 tires will affect overall acceleration. I basically just wanted some opinion on the matter.
shattered_memory is offline   Reply With Quote
Old 02-20-2014, 04:21 AM   #479
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
My Volk TE37SLs are 18x9 ... They weigh considerably less than the stock wheels, and by running 255/35 ZIIs my tire circumference is almost exactly identical to the stock wheels and tires.
I've had several NASA events both on stock wheels and the Volks ... I would rather drive with the Volks. Yes perhaps I'm biased because I spent so much on the wheels and tires, but having raced the same day on both set of wheels on the same track I was faster on the supposedly slower wheels. I drove with far more confidence deeper into corners at speed and had better braking with the added tread ... i also blew through small corner sections with greater speed and no tail happiness on the Volks.
My point? With all of the combinations of tire and wheel sizes, weights, compounds, etc... it's really difficult to say in my opinion that one set of tires and wheel sizes are the best. So long as you aren't going with an absurd combination I can't see it affecting you so negatively that you ate losing performance. If your driving style is more about swinging the ass end around every corner then maybe you want a smaller width ... If you like to have pure command in a twisty road course then maybe you go with a wider tread.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following 2 Users Say Thank You to TrogDor the Burninator For This Useful Post:
Hicklinc (02-05-2018), mfbmike (02-20-2014)
Old 02-20-2014, 05:15 AM   #480
mfbmike
Fair enough.
If I was going for solely performance it'd probably be something in the 17x9 variety with even stickier (than the PSS I daily on) 225-245 tires.
This chassis behaves pretty damn amazingly with better and (in the case of many of the cars in this thread) wider rubber. I love the handling characteristics of my car as it sits - grimspeed strut bar, -2 degrees of camber.
The Following User Says Thank You to mfbmike For This Useful Post:
Old 02-20-2014, 05:16 AM   #481
mfbmike
Well said. I'm beyond stoked to take my car on the dragon and some of the other amazing driving roads up in NC come april.
Old 02-20-2014, 06:11 PM   #482
shattered_memory
Thanks for your input 255/35/18 tires has about a 1 mph difference in acceleration than stock. I think the extra grip and stability more than make up for that difference. I also like your wheel specs. The +45 offset is closer to stock. A lower offset would increase the leverage on suspension, which decreases the wheel rate (stiffness). I used to have a set of 17X9 +35 wheels on my rsx. The suspension would feel softer and turn in wasn't as sharp. I figured out that it was the offset that contributed to this. However, It did grip well and gave me more stability in corners.
Old 02-20-2014, 06:23 PM   #483
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
A friend did a math for me a while back.
The speedo will be 1.7% faster and if you go with 35r it will be 2.5% slower. Id say 40r
zoth is offline   Reply With Quote
Old 02-20-2014, 06:27 PM   #484
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 02-20-2014, 10:09 PM   #485
BenBrown
Metal up your butt
BenBrown's Avatar
Drives: Subaru BRZ
Originally Posted by yohan04 View Post
Haven't took any new pictures but here's some old pictures from last winter-spring.
Enkei RPF1 18 x 9.5, +35
255-35/265-35 Federal RS-R
[/URL]
[/URL]
Nice set up! Whats the bolt pattern on your RPF1s?
BenBrown is offline   Reply With Quote
The Following User Says Thank You to BenBrown For This Useful Post:
Brianjoy77 (03-22-2014)
Old 02-21-2014, 12:12 AM   #486
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Do you guys think i can fit hankook v12 265s on my 18x10
I love boost!!!!!!
Old 02-21-2014, 12:32 AM   #487
Powersfrs
Drives: Frs
What's the widest tire I can fit on a 18x8.5(front) .....and what's the widest I can fit on a 18x9.5 (back)rim...I got kw for coilovers (57xtreme gram light by the way) can I fit 245 on the front n 275 in the back?
Thanks
Powersfrs is offline   Reply With Quote
Old 02-21-2014, 06:42 PM   #488
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
Thanks
245 should definitely work in the front. 275 is on the aggressive side in the rear, but people on here have done it. Some tires also run wider than others with the same specs, like Michelin PSS, so you should definitely check on that before going with such a wide tire...personally I wouldn't go over 265.
immaculate is offline   Reply With Quote
The Following User Says Thank You to immaculate For This Useful Post:
TrogDor the Burninator (02-21-2014)
Old 02-23-2014, 12:42 AM   #489
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
I love boost!!!!!!
FYI the V12 run smaller than other 265; Their like 255. I took my set off after 3,000 miles and replaced them with the BFGoodrich G-Sport Comp2 275/35/18.
DesertFrs is offline   Reply With Quote
Old 02-23-2014, 01:15 PM   #490
pleong
Drives: 2013 Whiteout FR-S
Anyone running 18x9.5 +38 offset? I have Enkei RPF1s all around with 265/35
A little concerned with rubbing
Camber
-1.5 front
-2 rear
Anyone pull or roll their fenders?
I hear the tire rubbing against something in the front when my wheel is turned all the way to the right or left rolling forward but rolling backwards I get no rubbing.. My caster is at 6.5 degrees
I'm dropped with about .5" gap all around
pleong is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
