Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > SOUTH AMERICA / CARRIBEANS
Old 02-05-2014, 06:30 AM   #1093
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Size:  181.3 KBName:  ImageUploadedByTapatalk1391599823.881335.jpg
kombatlion is offline   Reply With Quote
The Following 2 Users Say Thank You to kombatlion For This Useful Post:
Draco_PR23 (02-08-2014), Sportsguy83 (02-06-2014)
Old 02-19-2014, 09:34 AM   #1094
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Se fue to el mundo pal grupo en FB y se jodio esto???
The Following User Says Thank You to Sportsguy83 For This Useful Post:
pala (02-19-2014)
Old 02-19-2014, 10:30 AM   #1095
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Naaa estamos aqui tambien, jajajaja
The Following User Says Thank You to kombatlion For This Useful Post:
Sportsguy83 (02-19-2014)
Old 02-19-2014, 10:36 AM   #1096
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Parece q si ... me imagino pq en FB hay mas quorum que en el foro.
Ya que estas por aca, una pregunta:
1. Tienes una foto de donde pusiste tu EBCS? Es para tener una idea, por si tengo q cambiar cosas.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
kombatlion (02-19-2014)
Old 02-19-2014, 10:45 AM   #1097
Luis_GT
Yo me paso en off-topic...
The Following 2 Users Say Thank You to Luis_GT For This Useful Post:
Draco_PR23 (02-19-2014), Sportsguy83 (02-19-2014)
Old 02-19-2014, 01:42 PM   #1098
Sportsguy83
Drives: Limited BRZ
are you gross or clean??? hahaha
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Luis_GT (02-19-2014), Pablitomarrero (02-19-2014)
Old 02-19-2014, 02:44 PM   #1099
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Caballooooo los q piensen poner turbo... Especialmente en PR/ FL... Los dias de tapon especialmente esos dias q la temp esta en 90+ (hoy) eso se pone de que literalmente pdes haver un bbq ahi.... Me costo trabajo hasta levantar el bonete pq el latch estaba de sarten ( exagerando) pero dolia si tocabas el latch por mas de dos segs. Digo el carro lo manejo bn y la aguja de temp no subio de lo normal pero.... Tengo q cool it jaja. Ese compartimiento de motor es sellao! Lo primero q pienso meter es un oil cooler pero tengo q ver que le cae bn al intercooler de greddy. Hay uno de un tipo q se llama stealthqueyo q le metio oil cooler michimoto (es el que quiero) pero el install le quedo feo pq lo angulo medio algaro alfrente del intercooler. Tiene q ser uno q quepa al lado... Sugerencias?
Pablitomarrero is offline   Reply With Quote
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Old 02-19-2014, 02:45 PM   #1100
Pablitomarrero
Originally Posted by Pablitomarrero View Post
Caballooooo los q piensen poner turbo... Especialmente en PR/ FL... Los dias de tapon especialmente esos dias q la temp esta en 90+ (hoy) eso se pone de que literalmente pdes haver un bbq ahi.... Me costo trabajo hasta levantar el bonete pq el latch estaba de sarten ( exagerando) pero dolia si tocabas el latch por mas de dos segs. Digo el carro lo manejo bn y la aguja de temp no subio de lo normal pero.... Tengo q cool it jaja. Ese compartimiento de motor es sellao! Lo primero q pienso meter es un oil cooler pero tengo q ver que le cae bn al intercooler de greddy. Hay uno de un tipo q se llama stealthqueseyo q le metio oil cooler michimoto (es el que quiero) pero el install le quedo feo pq lo angulo medio algaro alfrente del intercooler. Tiene q ser uno q quepa al lado... Sugerencias?
Old 02-19-2014, 02:46 PM   #1101
Sportsguy83
Drives: Limited BRZ
Es un freaking BBQ.. he pasado por lo mismo que el bonete no se puede tocar!
Comprate el Full Blown Motorsports, queda al lado no alfrente del IC.
Mishimoto quality es medio mala, no vale la pena...
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
kombatlion (02-21-2014), Pablitomarrero (02-19-2014)
Old 02-19-2014, 02:48 PM   #1102
Pablitomarrero
Puerto Rico
No lo habia visto el de full blown... Lo voy a buscar. Lo q me gusta de mishi es que tiene thermostato y ayuda a q se caliente el aceite mas rapido.
Old 02-19-2014, 02:52 PM   #1103
Sportsguy83
Drives: Limited BRZ
Los que ayudan a que se caliente el aceite mas rapido son los que son water-to-oil y usan el agua del radiador.
Lo que te benefica el termostato es cuando vives en sitio que la temperatura llega a 30, ahi si te ayuda a que caliente mas rapido, pero en PR jamas viendo temp. por debajo de 60, realmente no importa mucho.
Como quiera, compralo con termostato. FBM tiene termostato.
Old 02-19-2014, 03:24 PM   #1104
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Puerto Rico
Si es obligao el Oil Cooler bro! Yo creo estoy 85% seguro que monto el Kit de Fiebruz corp... Queria el Kraftwerks pero no hay suficiente data pa tomar la decicion... yo queria Kraft por q nadie lo tiene en PR y como tu Greddy seria unico en la isla.
El Fiebruz lo q pasa es q garantizan el trabajo y piezas por un año eso nadie lo hace mano...
Vi el
Missimoto montao alfrente del intercooler y es el q me gusta tambien.
Old 02-19-2014, 03:26 PM   #1105
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Old 02-19-2014, 04:54 PM   #1106
Draco_PR23
Fiebru
Draco_PR23's Avatar
Hasta ahora no he estado en tapón pero he hecho uno q otro "hard pass" y se siente caliente ... El AVO kit trae unos spacers para bajar un poco el skid plate y ayuda a que el aire circule por debajo, las temps eran de 180 (aceite) y 190 (coolant). No hace mucho le elimine los spacers pq a cada rato choco el skid plate con cualquier cosa y vi q las temperaturas subieron, so volví a instalarlos nuevamente. También recuerda q tengo el Robispec radiator / oil cooler combo.
El de FBM es el unico q he visto q queda al lado y esta a la venta .. había visto uno AVO que queda al lado también pero lo tiene alguien de Australia creo y no he visto ningún release de ellos.
Current Cars:
The Following 2 Users Say Thank You to Draco_PR23 For This Useful Post:
kombatlion (02-19-2014), Sportsguy83 (02-19-2014)
boricua, boricua bestialam, meeere pejjjcau, puerto rico, sportsguy83
Puerto Rico Vendors and Suppliers kombatlion Scion FR-S / Toyota 86 GT86 General Forum 0 11-02-2012 10:50 AM
Members in Puerto Rico raul Southeast 12 08-26-2012 12:48 PM
