Old 02-19-2014, 07:41 AM   #113
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by bobaab View Post
Do you have any rubbing issues with your wheels? I'm looking to lower my BRZ and get the same spec wheels as you.
Don't think I saw it anywhere...what tire size are you running?
Thanks! Car is looking nice
Thank you! I'm running 245/40 Direzza ZII tires which run pretty wide and have no clearance issues. The only time I get any rubbing is with the wheels at full lock turning into a parking spot. Even then, the tire barely rubs on the sway. Enjoy your new setup!
fstlane is offline   Reply With Quote
Old 02-19-2014, 08:47 AM   #114
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Nice @fstlane. I have WRB too and I might have to copy you. I'm still torn between bronze or gold though.
flashburn is offline   Reply With Quote
Old 02-19-2014, 01:14 PM   #115
bobaab
Drives: 13 Subaru BRZ Limited
Thanks for the feedback! I'm pretty much sold. Now just gotta wait for winter to go away in Chicago
bobaab is offline   Reply With Quote
Old 02-20-2014, 12:47 AM   #116
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Thank you! In all of these pictures I'm running RCE yellow springs.
What color are those?
Jmonty is offline   Reply With Quote
Old 02-20-2014, 07:39 AM   #117
fstlane
fstlane's Avatar
Drives: BRZ Limited
The wheel finish is Sports Bronze.
http://www.wheeldude.com/catalog/pro...d74eb32fbf3fdc
Old 02-21-2014, 03:34 PM   #118
shattered_memory
Drives: Satin White BRZ Limited
Your car looks awesome with the titans! I'm thinking of getting the same specs only for the track. Do they poke out a lot with stock camber and stock suspension? Also, are you running any negative camber front and rear? ThAnks
shattered_memory is offline   Reply With Quote
Old 02-21-2014, 04:13 PM   #119
jamesm
you can get real weds cheap enough used (i got mine all 4 with tires for $600) that it doesn't make much sense to buy the knock-offs. not that there's anything wrong with them, they're perfectly serviceable. i just doesn't make much sense.
Old 02-21-2014, 07:50 PM   #120
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by jamesm View Post
you can get real weds cheap enough (i got mine all 4 with tires for $600) that it doesn't make much sense to buy the knock-offs. not that there's anything wrong with them, they're perfectly serviceable. i just doesn't make much sense.
A $600 set of Weds TC105N wheels is not a common find. Someone either had no clue what they were selling or they were mangled. I went with the Titans because they were the size, offset and color I desired. They were brand new and at a price point that I won't feel sick to my stomach if one gets damaged.
Old 02-21-2014, 08:04 PM   #121
fstlane
fstlane's Avatar
Drives: BRZ Limited
Thank you!
Here is the rear running @ -1.7°camber lowered 20mm.
And the front @ -2.8° camber (with 10mm spacers).
I don't think I have any pictures on the stock suspension and alignment.
Old 03-01-2014, 10:05 AM   #122
Jmonty
Loving these, can't decide on color for my GBS? Thinking flat black or sport bronze?
Old 03-01-2014, 10:49 AM   #123
bfrank1972
Drives: 2013 FR-S Argento
Weds without tires usually go for at least double that - you got a pretty good deal there.
Old 03-01-2014, 12:18 PM   #124
jamesm
He knew exactly what e had and they were mint. He just didn't need the money that much and wanted them out if his garage. Opportunities arise....
Old 03-01-2014, 05:23 PM   #125
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
I'm running the 17x9 +42 Titans and they weigh in at 17.8lbs each. Great choice, I love mine!
Here's a few pics.
Quick question but were you able to run any camber on stock suspension without spacers? I am getting a set of these and hope to run around -1.5 degrees for autox
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-01-2014, 06:29 PM   #126
fstlane
fstlane's Avatar
Drives: BRZ Limited
Yes, I was running -1.9° front camber on the stock suspension without spacers but I'm using camber plates. If you plan on using just camber bolts you should be pretty close to -1.5°. However, there isn't much spring perch clearance (see pic). It never rubbed with the ZII's but they have pretty stiff sidewalls. A slip on 3mm spacer would probably be the easiest way to get a little more clearance and you should still be able to use the factory studs.
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 12:04 PM
Wheel Directory: Rota Grid 2 17x8.0 +38 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-02-2013 04:08 AM
Rota SDR in Gunmetal? zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-10-2012 12:08 AM
Wheel Directory Rota PWR 18x9.5 +35 gabeg86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-31-2012 01:38 PM
