Old 02-15-2014, 12:47 AM   #1331
Crazy Drew
Drives: Smells like tires when I drive
Has anyone on here had any problems with differences in tire diameters putting the car in limp mode? I found a couple other threads referencing it however there never seemed to be a solution to it. I'd really like to rock 18/19 stagger but different sidewall heights (same overall diameter) look like s*#%.
Crazy Drew is offline   Reply With Quote
Old 02-15-2014, 01:51 AM   #1332
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
...list all modifications/specs so that I can copy your setup...
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
The Following 2 Users Say Thank You to jedichimp For This Useful Post:
mr. slim (02-15-2014), stancypants (02-18-2014)
Old 02-15-2014, 02:43 AM   #1333
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
haha. thanks guys.
BC Racing coilovers / front camber bolts / PBM Rear LCA's
08STI rear 5x114 hubs, Project Kic's 10mm spacer adapter
MB Battles 17x9.5 +15, 18x9.5 +15.
-5 camber all around.
I've never had any issues with staggered wheels. as long as your rears match, then you should be fine.
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
Old 02-15-2014, 01:27 PM   #1334
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
Originally Posted by moomoopanda View Post
Well...
nice!! I've got a circuit soul sticker I'm planning to place a little lower than yours at the bottom of the window. Seems like we have similar tastes lol.
IG: nabb335
nab335 is offline   Reply With Quote
Old 02-17-2014, 07:31 PM   #1335
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
Speed Element is offline   Reply With Quote
The Following 8 Users Say Thank You to Speed Element For This Useful Post:
FriedRicr (02-18-2014), glorydays (02-20-2014), Kai Uhl (02-18-2014), kvl (02-19-2014), Scaldy (02-21-2014), SkAsphalt (02-18-2014), SLICVIC (02-18-2014), stancypants (02-18-2014)
Old 02-17-2014, 07:33 PM   #1336
suboobaru
Drives:
Originally Posted by larryw View Post
Ill roller's car
18x9.5 +38
Front: 225/40/18
Rear: 255/35/18
any fender mods? camber?
suboobaru is offline   Reply With Quote
Old 02-18-2014, 09:33 AM   #1337
PradiG
Drives: Fr-s
Only pic I got so far
PradiG is offline   Reply With Quote
Old 02-18-2014, 10:11 AM   #1338
jsu1012
jsu1012's Avatar
Drives: 13 scion frs
killer.
jsu1012 is offline   Reply With Quote
Old 02-18-2014, 01:02 PM   #1339
nab335
nab335's Avatar
fuqqqq that camry tho. did you lower your car or add more camber? looks like it
IG: nabb335
Old 02-18-2014, 01:36 PM   #1340
PradiG
Drives: Fr-s
Yeah lol, I got other pics but i can't uploads says file too big ):
Old 02-18-2014, 06:01 PM   #1341
PradiG
Drives: Fr-s
The Following 3 Users Say Thank You to PradiG For This Useful Post:
sal (02-18-2014), Turbo95eg6 (02-19-2014), zenki_levin (02-19-2014)
Old 02-18-2014, 07:06 PM   #1342
phloozy
phloozy's Avatar
Drives: Scion FR-S
What happens when you hit a pothole when your wheels are that close to the fender? I have never had a car that low and am genuinely curious
phloozy is offline   Reply With Quote
Old 02-18-2014, 07:37 PM   #1343
Hachiroku14
Drives: 2014 BRZ World Rally Blue
[IMG]http://www.ft86club.com/forums/data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxQSEhQUExQUFBQWFxgUFBUXFBQXFBcUFhQXFxQXFx QYHCggGBwlHBQVITEhJSksLi4uFx8zODMsNygtLiwBCgoKDg0O Fw8QFywcHBwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLC wsLCwsLCwsLCwsLCwsLCwsLCwsLP/AABEIAK4BIQMBIgACEQEDEQH/xAAcAAACAgMBAQAAAAAAAAAAAAAEBQIDAAEGBwj/xAA8EAABAwIEBAQDBQcEAwEAAAABAAIDBBEFEiExIkFRYQYTcY EykbEUQqHB8AcVI1Jy0eEWYpLxM4KiJP/EABgBAQEBAQEAAAAAAAAAAAAAAAABAgME/8QAHhEBAQADAAIDAQAAAAAAAAAAAAECETEDIRJBUWH/2gAMAwEAAhEDEQA/ANQ7pvTOsEliOqZQv0XPB28nR4crY3Jf5qsjnW3M4iKvDwk4q+ 6w1w6qByJVsVdlzsmJDqh5MU7oOpNb3VMlf3XJyYt3QsmLd0HS 4hjLY2ue42a0XJ7Lw3xLjj6yd0rtBsxvJreXueaf+N8VcWNjv8 RuR2H+VxaoxYsAVzYXHQA/JBSpiO4ujoMLc46iw9bfgmkGC33I0PLos3KNTGknkW35/giBSE27i/v+f+U+iwaxNz***7IwYHcEgjX5ADks/Jr4uUFL6CwB9QVA03yv+rLsG+HtXG/xWt0AGyyo8PHYOAGmvPRPkfFxE8WUkW9+ap2XXVWAOGwv1JPLs Eoq8IeNxrewA/NamTNxdh4QxczRWcbvZoe45FPw5eaeFKgxVTWnTPdhHtcfT8V6 QwrTK4Ld1q60Sg3mW86qcVrMiL8y1nVJco5kBOdazofMtZkBGZ YHobMsDkDfCHcYXoOGHhXm+Dv416NhZ4QgYLFlliqPG4jqjQ6w QEO6KXPDjr5OpF6j5ig4qpzltzSkq7JbV4nZTqiktaVFXuxIla FXfn+KVFy2HqBqJlPzEqEysE6o5/xLNmnI/lAH4XP1SpFYo+8rz3/IIUKhlhkYte2qZBBYfbLojg1c66QRCUypWpbCUyp27LDZhA3X/pMYIQdihaWO4TWnhsEaShiAWpB2RkUOmqx0KBDUC26Fc1Na2JK nmxQcxjtO2KWKRoy8Yv8AMLt436Ll/EkOaI7XbZ1/qntDLmjY7q1p+YXXG+nDOex4eFsuQwKkHLTCwuWKGZbugxaJW1 EhBi0XLSiQUG8y3nUC1ZkQMcHd/EC9Lwj4QvMMIb/EC9Nwf4QgaLFlliqPF4TqpTVNlCM2SLFK7K4hc8eO2c9nYqgVt 0oK5aLEkWyvutbc9GlQUqqgrDVqiSYFAC4KCIeByVZCgpzLDIp PaqnBRXP1Trvcf9x+qqCsqHXe49yqwtobUWjQjGlBQ6ABXseud dDGncjqeTVK4HJhTsusVuOgoJbJrFKEjowRuncMZ7I0OidpoVe bAXKHY2ytO2qIXYg7fokdTvondbttdJ6r0RS2rAcxzeoKMwJv/wCeL+gfOyXPfqmnh2QPgZrqARbnoSFvBxzG5VINVzY1YI10cw+ RSEaIEasbEgFEa35SMbCpiFAv8lbECYCBSECBb5CwwJn5K0YkF GGRcYXomEDhC4mgj4wu6wscKFHLFixVHibDouK8Qu4yuzj5rjv ETeIrlOO+XSZshCvZWEIZaVQxZXK5talCwOIRNHbalT85JGzFW tqU9pqG+dQleALnQDVANqVqrn4D7Js0VTkFziNQSSPc3V1JHfU 8lU+GwB5Iymj4R81q30kntaroY7qDWqiprSNGrDToqCkvZO6Sl 7LiabHJGfduP12Tqi8X23Zr6qXGtzKOxpYNQmsMJ6LnKDxCx9j a2mqfx4g226y0JkadNNBz0Vnl3Cg6pu39eypmxdsTLm2ndVPa2 SjKV19ELE3SPEvHkhJEcVx3Sr971M24a0dzb8k0mxlRCL6a8jZ UeF6Isfc83uFu1ytQwyMcCbWO9jp8kzpoiJWPB0zZSOWtjdWFj oGsVzWKxrFayNdXBU2NWtiV7YwrQAqB/KW/KRC2CERSI1IQq8OCkHBFD+SomFFF4Vbnoiumi4guxw0cK5GCTi C6/DfhUUYsWLFUeIRndcpjo4j+ua6yBc9jMFyVxnHe9cy5qrLUwkp yh3RLSBlpXOYqyEEVqy2sVGgVt5uBfrdYoybIizzQ4FoHL20RU YsEFhzQS70RjSpSNucqGho6epVkrUAYnXtzSFNYXNPM+zSi3YS S3MBJbqYnFvubLn2PeCGguBuABzvfTRezw+F8lOH/AGqeN2W/E5jmg253b+aWErykSvj10I6jYp3QYwXCyjWQh3mCXezi2ZrSGP cNQHAjc9QqPD8Otis3jU67JkzvK7/rmuXxzFCNDuP1su5ZCPK6aLkvEWDCWK7LB7XOc4k20OUN5eqka vCXDqgON3OY3+s3Hy2CbSYgCOB0LrfykfkUv8I4LUMq4Xlpaxr g5ztC1zRu3vdd94qgo5Af4LPMP3g0Nt3vYFasjEtchBWk6WsRy vdPsDAc0k7ixHsUko6VrG8II9TdM8NjLW5uROU/VZbdPmUmzWW5Bp7IOV9l3eYeKlYatJnyoaSpIQdD9sWfbFzJrC tisKDpvtaz7WucFWVIVBQPzV91B1Yknnla8woH1JU3eF3eEuu0 Ly7D3HOF6ZgZ4QgbXWLV1pB4rToKtguSj6YKM7dVjHjpnfbn5a VCy0i6F8KokgV+LPyczJSoZ9Oulkp0LJTLOmtucfCqyxPJKXsh n0qLsqIUsl2m241CLfAVqnj4wLgXOW52Fza5TYDfHlLSBbqiIz oEz8XYKaaSMZg4Oubgc2mx+qWDklIIjbdETYbmbpoeRQ8D9U/w+W9gVm1qQij85hHDcjY21+aaRYhUPsCSAOvEfxTXyQToo/YvkptrRFiMjn2uSel76nqj8Fgy2J1KDxOQBwA5JtgsN9U+iddf SasKBfDleCPfomOH3LdOW6Hrhb6KNA5MDicc8bnwuO4YTlJ/p2+SqHhwA3dI5/a1h7p9R8TAef1VtuxRHP1lIA3RW4DCZGFjWlxF3G3IdSrcTd+v krfCNVLFITGLtc0seDfKNbhwPXsrJtMrr2Y0rCYmk72/6Q81Omkh5Kotuuzz0lkpUNLSLoHQqmSnVRzT6aygIU9lgQzoUA DYlMRosQqQiQChisESvEasZGg1QxcYXomC6NC4eji4gu3w06BA 0WKNlig8ZhWP1W4wtOWcON+TqshQcFaVBbYDuaqXMRTgqiEAj4 VRJTpgWqBCml2US0/ZAVMSfysSysYsVvEskkdKWtcSSOFriSbNHKyqe3UjurYm8Y9/oVXIdR3APzCisanOHybfr9bJNbVH00hClajqaZqsqpGsBJsAld HNbml/iGpcRYc9Flvaujg+0SF+zbkD+66OlZ5YAXH4ZXmJmXZwva+yic enLuKzgOgstaYmUj17wvI05w7pp6rdVAHafJcbgGMOfs15Og+E qzHH1e7C5rhyDM3/ANbD5Kfxr+umjBjNirftQ1SGjmmyDzbZ7a/5WnVZOiiiauS9zsmfhaT+G4dHfULnXuKb+GZLMeervyWsOseTh 68qN0KZlEzLs4C86g910G6oUfPQXyBUlq15qldBHIsDVMLaCGV SYFNrVMNQTg3C6innyj2XMwt1CcSHh9koO/fA6rFy2busWWtOfiaouCmxVuUw4vk60oFTUCtsIOCrcrHKCCsr TmqdlohAO8JZWps8JVXN3XPJ0wKY/jHqhnO+DqDkPsdPwRTGnO22uoP4oCsZaWQd8w+aRaIeLE9jZXw uQ8rrm/XX5oiJqij6d6lO/MboMHXdVunu6w1WdNbOYYwQtxQNLrWHyQ1Mx3PhHdHU0sbTckn 0Giiu3pIi2EBrQCBmGn4IWoc7R40Du/MKyhxiN7QA8NNrWOmgUJ8RiLcozHuBYXVUFMUFMPvBXS2d8Dx6 HRAulLHWeNDpfuoq3NomuDnLF6klJnCwTmmjtG0dvqt4dcvJxO WdUPqVXMChHLo4jDUKTZu6AurYyqGkT1e16AhcimoCAVMKlpVr UFzVMBRY26IbGg1ENQqsfrixlx0RTIlVieH+Y2x6KVY89/1A5Yn3+lmdB+vZYstJMCqeERGFQ5MOHk6rUSFMqJW2ECFWVYQo uCCC0QrGREmwBJ6AXK6HC/BlRLq60Tert/8Aig5byyTYAk9AhsSwuVou5haOrtF7PgHhqOmHJ7ubi0A+3QLj f2w+HXui+0xE2ZpKzXbYPA7c1nKNY15FiGICO7Y9+bj9B0Sx0x cQ477H0VdQ03uVBhSRbfZpBq3uPoioil1JLlP4eyMa/XfY/gsVsS7S56ApYyrczZt+5TR3Q8xdvdRjj0tzCQoOCuLyNCSTbdO IKeTXhAt8voq46aNwBAAdf5J3RR33e7XQ3OilsWSq6WimLtWO2 0P53TmqwKeNmZ8kbNAbHXQoypMuVtpW2tl4SBw91d9mj8vPI/zHjqSfqo1pxVZBLJKGMeMg1c9oIO+wv+SudRERnic43u25JtZM 5573A0B39FU99xlaP7Adyg1QAyuY3vr2A3XVyRInBPBsjKbzQf 4zuLIR9zkOxO6XDEOIseMrhoQdNV0xmnHK7VzQoKaJOS0HZCTQ rTBQWKbFZLHZQAVBESMYg4Qi2BAQxERtQ8QR0DUF8MSKjgVlLC mMUCAOOmWYjwNKbMhQ+JUJe3RLCVxP2w/oLEd/p93Qraxqum4SxjRDvRDDoh3bpjxPJ1ByipOUQFthpkZcQACSdA BujKqOCkAdVOL38qeLik/93bMQ1ZjQpWmOIgznR8g1yD+VvfqVzJeSSSbk6knclYyy03jht 6BgP7QaSKHO+ldC7OW5GNMj8ltHlxAB9LrvMA8Q09awvp5A8D4 m6h7T0cw6t914PGjcPL4pGywO8uVvwuGx1+F7dnNPRSZtXx/j39QmiD2lrgC1wIIOxB3CTeE/ETa2K9skrOGWO+rXdR1YdwfzCeLo5PnLx54SNHO5gBMbrviP+3 +X1Gy4wU5vltc629l9R+McAFbTuZpnHFGejhy9DsvnTHKB0TiH NIex2rTvcHZY5XSe4UsaT6jbupNl5HQjb+yYSUWgfYhjwHtv90 k2tmsAdeQ6rJKMP0OjuTuRRWUlTmGV3+Qeykx5abH2PUJY+N0b rO06FMKSpB0d+vRSwGseDre30R1JXhh+NvzQsUI06FN6WhZpcX Wa1F371a774v2ufor43OfpZxHK+g/uj6JkLPutBRtVktfT2WWyCRh/WyPwJzY5GyvZnhY8Z+lzsSOdt0FVSjWy3hjxkkzP1sLM5HUXLu/RajF/HulPM17Q5pBa4XBHRct428MidvmxC0ren3h/dKfAeO+X/BeeAngJ+6enovQ107HKy414ZRYi6N2V3I2IK6Brg8XCt/aN4e8t32iMcLvjA5O6rncArbHK7mpLq6Wzc2ZTwoYxprMxCujW 2FULESxq1FGiWsQZE1MqSNCRsTWhYgZUkSYxQqujiTNjbKoqjh V1ltYoqvyx0WKxYg8beVWiQRbbkVWXj+ULGPG/J1SUqxTEcvCw68yOSPxKsEbL5bk6D1N9Vy8lUCb5edz/AMbfW591bUxiAcro3IQORVO3muVdoMgaj6cd0Ex4V8UijRpRVz 6WVlTFclmkjL/+SE/E31F7juB3XsmH1rJ4mSxODmPAc0jofoeVl4tC+6e/sxxZ0FU6hN3RSh00W38Nw1kH9J39fVdML9Ofkx+3qi86/aj4TEwFTGOJukoHNvJ3tzXoqi9gIIIuDoRyIK3Ztyl0+bTGGNk aW5mubbkSADc5c2gJtvuqqqlMWZrmudEDbNY8B6F9hraxuF2fj HAW00+VpuwjO0cwCdiqMNx0RM+xvj8wSh1nknM1p2aOlrEacrd Fzn5XS/see4g27deJv3XD8+iUteQulraLLdzTob8J2PtySh1G12reHqOX stSpYuocWto+9uo3CdU+LMto4fNcyyl1sfwRMmHgN0Usiy1037 5ZyNz21+itirnvOgIHf+y4ygdleugpsSuQ226lmll2aka23uun wiSmbQS5muEzydb/AMps30GiQwxbH3V0EDRCHcRe43vfhALjoB7Js1wXR7BepeE8U8 6EAm72cLvyK8wphwhPfCVcYqhu9n8BHrsVMbqtZzcei4hRtmjd G4XDhZeH4pROp53MO7Tp3HIr3hcJ+0vCgWtnGjhwu7jkumU+3L C/RLQziRgPPmpPYkuA1Ba7LyK6MtVl3GbNVTGxXsjW42ItjFUQjj TWhahWMR1KEDyjai0LRopWpGLFixRWWWLFiD//2Q==[/IMG]
Hachiroku14 is offline   Reply With Quote
The Following User Says Thank You to Hachiroku14 For This Useful Post:
Bullschmidt91 (03-02-2014)
Old 02-18-2014, 08:08 PM   #1344
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
You should raise your frs/brz so it'll look better :P
Sent from my SPH-L710 using Tapatalk
Kosmos is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
