#29 |
Drives: Smells like tires when I drive
My opinion is probably a bit skewed being an "experienced" RWD owner however I still choose rwd over fwd any day unless I need leg room in the back.
IMO, if you can't drive a rwd car in the conditions you're attempting to drive in, you probably shouldn't be driving. Yeah, you might be able to get the car moving easier if it's FWD but does that really do you any good? Guess what? Everyone has 4 wheel stop regardless of being fwd, rwd or awd. Just because you can get a car moving in the snow/ice doesn't mean you can control it. If you can get a rwd car moving in slick conditions you're probably fully in control of the car the entire time. In early December we had quite possibly the worst ice stom I've seen in my life. 2-3" accumulation of ice in a matter of hours. Never once did I get stuck or feel as though I lost control of the vehicle. Yeah, I slid around quite a bit but no biggie, just correct for it. Meanwhile I saw plenty of FWD cars with massive weight biases getting stuck all over (newer impalas, northstar powered cadillacs, acuras, you name it) |
#30 |
Drives: None
Fwd are better in the snow for normal driving. But a rwd in an abandoned parking lot is the best thing ever
Sent from my LG-D800 using Tapatalk |
#31 |
Drives: Asphalt FRS
I was under the impression that FWD was solely created to combat adverse weather induced road conditions! Why the hell else would anyone drive a FWD vehicle? My '98 S14 got around better than my '09 civic Si sedan did in the snow! WTF?
#32 |
Drives: 2013 FRS
I've always figured front drive vehicles are cheaper to manufacture because the entire driveline is one assembly. From a manufacturer standpoint you just drop the car on the front subframe and it's done.
Sent from my SGH-T999 using Tapatalk 2 |
| The Following User Says Thank You to Slash For This Useful Post: | jarviz (02-18-2014) |
#33 |
Thanks
I'm in Canada right now and this guy was showing me where to go on a snow packed/covered road in his BMW wagon. I was driving my FWD accord. I was able to keep up no problem but I felt my car was quite close to its limit. I didn't even see him get sideways once. Both of us on snow tires.
So I think it comes down to 1. driver skill 2. size of your testicles 3. IMO RWD might be a little better than FWD as far as correcting slides since you can use your throttle as opposed to a hand brake in certain situations. |
#34 | |
I would never even think of doing this in the FR-S.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#35 |
Drives: Raven FRS MT
yup. not every person needs a RWD to buy groceries.
| The Following User Says Thank You to jarviz For This Useful Post: | SkAsphalt (03-25-2014) |
#36 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
From what I understand from WRC history, the first rally cars were RWD but as they raced in severe conditions, FWD really started showing its merits when designed properly compared to a similar RWD. In fact, FWD was actually gaining ground until Audi smashed everything with their AWD Quattro and pretty much shamed everyone.
So technically, FWD should be better for the same driver than RWD in adverse weather conditions. Then again, very difficult to truly test since no car manufacturer truly makes RWD and FWD on the same car as options.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#37 |
Drives: Whiteout FR-S
The only issue I have is hills and the fact that the traction control makes it harder to drive in the snow 50% of the time.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#38 |
I have found that the single most important factor is TIRES, then tires and then tires.
As far as drive wheels go the tires with more weight over them get better traction. Thus a front heavy front wheel drive will get you moving in the direction you want best. I had a pontiac fiero RWD mid engine car, in the snow I could move but not steer. My old 10 ton 69 buick skylark with 200lb of weight in the back and beefy snow tires would go anywhere I dared drive. |
#39 |
Drives: Nevermorange FRS
Snow?
AWD>FWD>RWD /Thread
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | bedabi (03-25-2014) |
#41 | |
Drives: 2014 Whiteout FR-S
biggest factors imo regardless of awd, rwd, 4x4, fwd is the Tires and the driver's experience & skill level. Winter tires make a night and day difference in winter. even the cheaper winters are still better then the best all seasons on snow & ice. |
#42 |
| snow....starting to like snow! | brzr | CANADA | 19 | 01-23-2014 12:10 PM |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 01:12 PM |
| Snow! | Jo-P | NY / NJ / CT / PA | 4 | 03-09-2013 11:51 AM |
| Fun in the Snow | Tdot | CANADA | 4 | 02-08-2013 09:22 PM |
| SNOW!!! | Tanuki | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 65 | 01-01-2013 11:42 PM |
