Old 02-16-2014, 10:08 PM   #113
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
17x9 +35 will clear stock suspension perfectly and not rub. It's the offset we recommend plus it clears most BBK set ups. +45 is just not ideal on a 17x9 . We also stock the 17x9 +35 in silver and black.
FT-86 SpeedFactory is offline   Reply With Quote
Old 02-16-2014, 10:29 PM   #114
Cards2323
Drives: 2014 BRZ Limited-SWP
Sounds good, I just didnt want too much poke on the front, I guess i'll try to find someone local so I can see it in person.
Cards2323 is offline   Reply With Quote
Old 02-17-2014, 06:04 PM   #115
shattered_memory
Drives: Satin White BRZ Limited
I've always learned to stay close to OEM offset when upgrading wheels because a lower offset would affect suspension geometry and handling. Has the +35 negatively affected steering response or handling at all? Have you guys tested a +45 in comparison?
shattered_memory is offline   Reply With Quote
The Following User Says Thank You to shattered_memory For This Useful Post:
fast_dude (08-23-2014)
Old 02-17-2014, 08:05 PM   #116
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Don't be silly! No one does that. It's just slam and poke.
I went the 45s. The above thinking contributed to the the decision. That and the +35 being illegal here and poking out a bit too much for my liking.
86•BRZ is offline   Reply With Quote
Old 02-17-2014, 08:12 PM   #117
FT-86 SpeedFactory
The only reason we state that the +35 is a better option is because the +45 sits extremely close to the spring perch, which won't allow you to run a larger tire or negative camber from camber bolts. Also, the BBK clearance is better.
+45 will be just fine if you run coilovers that give you more inner clearance and if you don't want to upgrade to a BBK.
+35 Allows for the use of MEAT. No slam or poke....
17x9 +35
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Avo1789 (03-03-2014)
Old 02-17-2014, 10:43 PM   #118
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
I am by no means a pro when it comes to cars, but recently I did have my prokit springs and 17x9 +35 rpf1s with 245/40 tires installed the same day and I noticed that it did affect streering response. Before it felt quick and sharp now it feels like I have to turn the wheel a bit more. I'm assuming that's normal when you go wider up front, but like I said, I'm not the most experienced person. Idk if the +45s would feel different.
eSOLOR is offline   Reply With Quote
Old 02-17-2014, 11:33 PM   #119
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
17x9 +35
There's no debating the +35s work. But just by definition they do poke when viewed from above, and sadly that is illegal here. You can see that in the shot above. That and you need a fair amount of camber to run them.
I think +40 would be ideal.
Old 02-18-2014, 06:58 PM   #120
shattered_memory
That's interesting. Tires may affect this. What tires are you running? Usually a tire with stiff side walls may give you back that steering feel. I remember upgrading a set of rpf1 17X9 +35 on my Rsx with a set of 255/40/17 kumho XS tires. I remember the steering feeling numb, which made the car feel heavy. Turn in also didn't feel as sharp, but it did grip amazingly out of the corner. I personally prefer the car to feel sharp and nimble on turn in.
Old 02-18-2014, 07:13 PM   #121
shattered_memory
Has the steering and handling become more vague with the 17X9 +45?
Old 02-18-2014, 08:14 PM   #122
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Honestly hard to pick. Only drove for 1000ks on std tyres. Didn't like lack of bite or braking grip. 235 Michelin pilot sport 2s feel direct, grippy and a bit heavier. I should put the other wheels back on for a while to see the difference... I couldn't say it feels vague but the std tyres may be better??
The Following User Says Thank You to 86•BRZ For This Useful Post:
shattered_memory (02-19-2014)
Old 02-18-2014, 10:14 PM   #123
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
I'm running Michelin PSS in 245/40/17. I'm not saying its a bad thing. I don't regret changing wheels. It just feels different but I do love the grip as well
The Following User Says Thank You to eSOLOR For This Useful Post:
Old 02-18-2014, 11:42 PM   #124
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I bought 17x9 +35's
I also bought an Eibach Pro kit and some camber bolts. With a 25mm drop (legal as it brings overall height to just on 100mm) and 1.5 degrees of neg camber, the wheels don't poke.
Wise is offline   Reply With Quote
Old 02-18-2014, 11:48 PM   #125
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by Wise View Post
I bought 17x9 +35's
The top of the wheel will be pretty much flush and the bottom will protrude a lot from the guard when viewed from directly above. Even the +45s stick out from the car. It's not a big deal. Just illegal where we are
Old 02-18-2014, 11:53 PM   #126
Wise
Circle Work Clerk
Not sure what QLD's legality is but in VIC i've heard it's fine as long as the top doesn't poke out past the wheel arch.
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 04:18 PM
