Old 02-16-2014, 10:08 PM   #5937
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
A PRE Stepped diameter 4 to 1 double slip collector Header
[/LIST]
Stock baseline Dyno was 173WHP.
For Those who were interested.
We picked up a little power top end with the tune alone which is typical but you can see that with the equal length header it opens up the power band not only up top but lower in the rev range as well. OE intake, muffler, resonator.
Temperature was about 57F in the dyno room, 29.66inHg, 90-100% humidity.
[URL=http://s88.photobucket.com/user/superlacrosseguy/media/IMG_0255_zps980128fb.jpg.html][/URL
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
chanomatik (02-17-2014)
Old 02-16-2014, 10:12 PM   #5938
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
What are the little springs for?
Evil Jesus is offline   Reply With Quote
Old 02-17-2014, 01:06 AM   #5939
Darkrune
Darkrune's Avatar
Drives: 2017 86
Torque curve looks meh.
Darkrune is offline   Reply With Quote
The Following User Says Thank You to Darkrune For This Useful Post:
SirBrass (02-17-2014)
Old 02-17-2014, 01:08 AM   #5940
CoupedUpSubie
Drives: 2013 BRZ Limited
Instead of having a flex joint like the borla's have they made a slip joint and use the springs to keep the pipes together. I know snowmobiles and other 2-strokes use the same setup, first time seeing it on a car though.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Evil Jesus (02-17-2014)
Old 02-17-2014, 01:12 AM   #5941
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Agreed. If there's still an identical torque dip, just with higher numbers, then either the tune is inadequate or the headers have the same problem that the OEM ones do.
I'm on my phone so if I make mistakes, blame Sportsguy83
^GT5 Replay Photo Mode^
Old 02-17-2014, 04:18 AM   #5942
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by thedarkgreyKnight View Post
Best Tint! located in Stanton. They are very friendly there.
Is this 30%?
Old 02-17-2014, 05:41 AM   #5943
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
Originally Posted by JS + BRZ View Post
I need these. So much better deal than JDM tips.
Sent from my SCH-I605 using Tapatalk
i struggled with exhaust tips for many MANY days.
but ended up not going with DC sport or other aftermarket tips, because of quality issue.
that specific model tend to rust at the connecting part, you can do some search to find people having problem with it.
I've looked into other brands, checking out every local auto parts shops.
most of them are too long... this doesn't work because if you try to push in to make it look good, the tip won't be installed straight because of OEM exhaust pipe is too short and you hit the curb/turn as soon as you start pushing in
I pretty much made up my mind that quality and fit takes money.
If I didn't get such a good deal on JDM tips, I probably saved up few hundreds to get a used axel back.
if you have any more questions about exhaust tips, msg on fb. you know who i am. lol
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
The Following 2 Users Say Thank You to wrb For This Useful Post:
AznBRZer (02-17-2014), chanomatik (02-17-2014)
Old 02-17-2014, 05:47 AM   #5944
wrb
frank
wrb's Avatar
Originally Posted by NCItaly View Post
Tinted my tail lights red. Very happy with the results even though I didnt have a choice but to do it outside so there are some dirt particles between the layers... but you can only tell from up close thanks to 5 layers of lacquer! Very easy but it was 9 hours total of watching paint dry...
this looks great.
do you have any tips?
I feel like I can do this myself, but I've never done anything like this before.
Los Angeles, CA
Old 02-17-2014, 09:07 AM   #5945
JS + BRZ
Drives: 2010 MS3
Modena's look good though!
Old 02-17-2014, 01:06 PM   #5946
NCItaly
this looks great.
I was nervous, myself. It was the first time I had spray painted anything. Hahaha. But some tips from me would be:
-PATIENCE!
-Light coats, dont try to make it perfect on the first coat, nor the second. I did 6 coats of red and 4 coats of lacquer.
-if you have the space, do it inside! The more steryl the better. I had to do mine outside and got some tiny dirt particals caught in the layers. And the spray seemed to act like a gnat attraction.
-do the awkward side angles first, then do long smooth sprays along the long axis of the lights, overlaping of coarse
-and again, patience patience PATIENCE!
That's all I can think of really, good luck and enjoy your new look!
NCItaly is offline   Reply With Quote
The Following User Says Thank You to NCItaly For This Useful Post:
Old 02-17-2014, 01:07 PM   #5947
dbrandt01
Drives: none
Decal
dbrandt01 is offline   Reply With Quote
The Following 2 Users Say Thank You to dbrandt01 For This Useful Post:
chanomatik (02-17-2014), Husker BRZ (02-17-2014)
Old 02-17-2014, 02:07 PM   #5948
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Installed a set of RKs. I need to swap the tires for winter tires instead of all seasons though.
Old 02-17-2014, 03:59 PM   #5949
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
Wedsport TC105Ns installed
BlueSTaR is offline   Reply With Quote
The Following User Says Thank You to BlueSTaR For This Useful Post:
Old 02-17-2014, 04:00 PM   #5950
deliroast
Drives: 2014 SSM BRZ
What wheels are those?
Sent from my SCH-I545 using Tapatalk
M3 > BRZ
deliroast is offline   Reply With Quote
