Old 02-16-2014, 08:15 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Low Torque @ High RPM VS High Torque @ Low RPM
The FRS has
151 ft/lb @ 6400 RPM
How would you compare this if we had a 200 ft/lb @ 3000 RPM
In other words, Low Torque @ High RPM VS High Torque @ Low RPM
Mikeez is offline   Reply With Quote
Old 02-16-2014, 08:19 PM   #2
Luis_GT
HP = (Tq * RPM) / 5252
You'd have 114HP there.
Old 02-16-2014, 08:26 PM   #3
Mikeez
Engineering Student
Then BMW has 241hp
The frs has 200 hp
BMW has 200 Ft-lb @ 3500 rpm
Whereas frs has 151 @ 7000 rpm
I'm confused
Old 02-16-2014, 08:33 PM   #4
Luis_GT
Originally Posted by Mikeez View Post
Then BMW has 241hp
The frs has 200 hp
I'm confused
Those are peak values.
The BMW doesn't produce 241hp at 3500, it produces 133 hp when you hit peak torque at 3500
Old 02-16-2014, 09:02 PM   #5
LSxJunkie
LSxJunkie's Avatar
Drives: Car
High torque at all rpm, thanks.
LSxJunkie is offline   Reply With Quote
The Following 5 Users Say Thank You to LSxJunkie For This Useful Post:
Astroboy (02-19-2014), Guff (02-17-2014), Luis_GT (02-16-2014), n2oinferno (02-18-2014), YukiHachiRoku (02-20-2014)
Old 02-16-2014, 09:14 PM   #6
Luis_GT
and high RPM range
The Following User Says Thank You to Luis_GT For This Useful Post:
Levi (02-18-2014)
Old 02-16-2014, 10:06 PM   #7
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Your FRS only has 200 HP at around 7000 RPM, it has less anywhere else.
Torque is how much rotational force the engine is outputting.
This changes drastically along the RPM range of any engine. Mainly because of how quickly the air can enter the engine and how quick the combustion burns.
If you want to have an engine with high RPM power, you want to try to keep the torque output good near the redline, if you want the engine to have "low end torque", you try to make the torque curve fat in the low RPM (long stroke specs. gives good torque, but limits the high RPM potential due to piston speeds). If you want good torque in the low and the high RPM, that's where you start needing variable cam timing, ignition timing, and everything else that is "variable".
Or you can do it the american way, and just make a very big displacement engine, then you have gobs of torque everywhere even with 2 valves per cylinder.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
Old 02-16-2014, 10:27 PM   #8
DarkSunrise
DarkSunrise's Avatar
Take a look at this stock FR-S dyno:
The solid red line is torque (in lbs-ft) and the dotted line is horsepower to the wheels.
Let's take it in 1000 RPM increments.
At 3000 RPM, you have 140 tq. Using the formula LuisGT posted [HP = (Tq * RPM) / 5252], you have: 140 lbs-ft x 3000 rpm / 5252 = 80 hp.
RPM - TQ - HP
3000 - 140 - 80
4000 - 122 - 93
5000 - 139 - 132
6000 - 140 - 160
7000 - 130 - 173
You can see that peak hp is 173 hp (to the wheels) at 7000 rpm. Assume 13.5% drivetrain loss and you have the manufacturer's rating of 200 hp to the crank (200 hp - [.135 x 200] = 173 whp)
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
DAEMANO (02-18-2014), Luis_GT (02-16-2014)
Old 02-17-2014, 12:28 AM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
High torque at low rpm is for trucks and drag cars.
High revving cars are for twisties.
To each their own.
ineedyourdiddly
Old 02-17-2014, 07:54 PM   #10
LSxJunkie
LSxJunkie's Avatar
Drives: Car
To each their own.
Drag cars spend little time at low RPM. You've got to rev them pretty high to get the most out of those big lift, big overlap cams they put in them.
The Following 3 Users Say Thank You to LSxJunkie For This Useful Post:
Guff (02-17-2014), strat61caster (02-18-2014), ZDan (02-18-2014)
Old 02-17-2014, 09:15 PM   #11
Lo
Drives: Old Saturn
What's the point in having high end torque? Would'nt you rather have low end torque for quicker starts?
Why would one say high revving engines be better for twisties?
Sorry for the noob questions
Lo is offline   Reply With Quote
Old 02-18-2014, 01:27 AM   #12
reni
Nobody beats the B[I|R]Z
reni's Avatar
Drives: shopping cart i stole from walmart
fcuking Newtonian physics, how does it work?
reni is offline   Reply With Quote
The Following User Says Thank You to reni For This Useful Post:
LSxJunkie (02-18-2014)
Old 02-18-2014, 02:44 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Drag racing engines are revvers optimized for max power up top, even more so than roadracing engines which have to be tractable over a broader rpm range.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
LSxJunkie (02-18-2014), strat61caster (02-18-2014)
Old 02-18-2014, 03:43 AM   #14
serialk11r
Drives: '06 AM V8V Coupe
High end torque means more max power lol.
I don't think there's a really good reason for high revving engines in twisties, they tend to have higher power density but for most people I think it's the fact that an engine that can spin faster than the engines in most cars on the road is cooler, and makes it have better noises.
[SYD] Milwaukee M18 1/2" High-Torque Impact Wrench 2663-22 eckoflyte Australia Classifieds 2 08-27-2013 05:19 AM
Torque Dip sierra Scion FR-S / Toyota 86 GT86 General Forum 68 07-22-2013 03:18 PM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 12:48 PM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 09:37 PM
