Old 02-16-2014, 05:06 PM   #1
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
The benefits of a aftermarket catted front pipe
So, I thought I had it all sorted out. K.I.S.S. Header+ catback+ OFT tunes. But after installing my catback and seeing the silly little lunch box in the front pipe, and just installing OFT. How much is there to be gained in getting a after market catted front pipe?
skye67 is offline   Reply With Quote
Old 02-16-2014, 05:07 PM   #2
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
More than a catback.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 02-16-2014, 05:15 PM   #3
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Closer you get to the engine, more restriction. So freeing up the restriction with a higher diameter pipe and high flow cat will help power, and also increase sound throughout the entire powerband. It keeps drone, rasp, emissions, and smell down too rather than going catless.
husker741 is offline   Reply With Quote
Old 02-16-2014, 05:29 PM   #4
jflogerzi
jflogerzi's Avatar
It will help a bit, but you will most limey get drone/rasp. Keep the stock FP.
Old 02-16-2014, 07:23 PM   #5
skye67
skye67's Avatar
Thanks for the input. But a catback makes alot of sense as the stock muffler is only a rat trap at best. The front pipe, is what 2.25" as aftermacket is 2.5", at $200+?. Anyone got dyno numbers? Next you will tell me your $250 airintake got you 10 to 15 more hp.
Old 02-16-2014, 07:30 PM   #6
husker741
Who are you responding to? The catback has proven to show the least amount of gains in comparison to front pipe, overpipe, or header. And no, the intake won't do much over a different air filter.
And yes, a lot of people have dyno numbers.
Old 02-16-2014, 07:38 PM   #7
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
@jflogerzi Rasp depends on what you have for cats, resonators and muffler. I have a resonated catback, catted front pipe and overpipe from Perrin. With a catted header from P&L the car was a bit louder but sounded good with no rasp or drone. I'm very picky about noise level, loud to me is mild to most.
Mobius357 is offline   Reply With Quote
Old 02-16-2014, 07:56 PM   #8
jflogerzi
jflogerzi's Avatar
Most ppl who have headers are using non catted headers
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 02-16-2014, 09:05 PM   #9
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Once you take off the stock overpipe you'll understand why it's a restriction.....
Rasp and noise is almost all about the CBE....
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-16-2014, 09:06 PM   #10
skye67
skye67's Avatar
Ok..after a two hours of searching. Found nothing more than fabled dyno numbers for catbacks and front pipes. Any help here??
Old 02-16-2014, 09:10 PM   #11
StormTrooper
Personally I'd look at the nameless catted DP... Combines both front and overpipe into one for $500
Leave the catback until you get headers as it may be loud enough by then.....
GR86 MT premium
Old 02-16-2014, 09:12 PM   #12
StormTrooper
The closer you are to the engine the more velocity you have and the more head loss from restrictions....
So even if the catback is the same as the front pipe it won't be as bad since it's at the end.
GR86 MT premium
Old 02-16-2014, 09:17 PM   #13
FrsDuke
Fanboy
FrsDuke's Avatar
Try asking for exactly what you want to know. Do you want exact numbers? Those will change brand to brand. Do you want to be told which one to get? Nameless fp/op combo. It replaces the overpipe and front pipe with a better route than any two piece option. It will gain more power than your cat back ever could hope to gain.
It will not be a big number. But neither is a catback.
TL;DR:
-Duke
Old 02-16-2014, 10:33 PM   #14
FR-S Matt
Why don't you start with the header since that is hands down the most restrictive part. Work your way back from there. The Nameless DP/OP is probably the best bang for the buck. I went with JDL's overpipe ceramic coated and an Invidia catted front pipe.
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
(wish to buy) space converters. Turbo UEL please. radium catch can Mr. Want-To-Buy Requests 9 10-21-2014 12:24 AM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 02:42 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 01:29 PM
Benefits of a front pipe? Osiris Engine, Exhaust, Transmission 19 04-08-2013 10:41 PM
