Old 02-14-2014, 02:35 PM   #1
Victor Draken
Drives: Toyota Gt86
Mid-Entry Level Suspension Setup
So guys I have narrowed down a possible Mid-Entry level setup for spirited driving/track/DD use.
B8 shocks
Tarmac Springs (RCE)
Whiteline Camber bolt 16mm
Grimm Speed Strut tower Brace
Now I need to know IF there is anything else that I srsly need to have to permit all of these little mods to work well together.
I have a TOYOTA GT86 (I think it's like the frs, more tail happy then BRZ).
What I'm Searching is to reduce oversteer and have a car that behave in a more neutral way.I just think that the frs/gt86 is to much tail happy especially around here with crap road surface and not very sticky tires.
Victor Draken is offline   Reply With Quote
Old 02-14-2014, 02:44 PM   #2
Racecomp Engineering
I like it. That with a good alignment and the right tires would be a great set-up.
- Andy
Victor Draken (02-14-2014)
Old 02-14-2014, 03:13 PM   #3
Victor Draken
Drives: Toyota Gt86
- Andy
So no need of upgrade bushing and sway bar? Do you think that this setup will make the GT less tail happy and more like a brz (neutral handling?) or I will need a stiffer front swaybar?
I want the simplest setup to start learning this car on spirited driving/track without worrying to much about different settings.
I planned this setup with the idea of reducing oversteer and increasing handling/grip
tyres will be 215/45/17 PSS on Enkei RPF1 17x7.5
Old 02-14-2014, 03:32 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Honestly I don't think you need the rear LCA. I have Ohlins RT on my car, and with the minimal rear drop I have zero need for a LCA at this time.
-alex
Old 02-14-2014, 04:14 PM   #5
Victor Draken
Drives: Toyota Gt86
-alex
what camber do you have in the rear and what is your drop?
toe 0 everywhere? -2 camber around?
@Racecomp Engineering @CSG David @CSG Mike
Is it possible to have 0 toe like factory spec (I think...) without LCA using the Tarmac + B8? I know you didn't test the b8 but probably your knowledge can help you making good guess about it.
Old 02-14-2014, 04:22 PM   #6
mav1178
mav1178's Avatar
I'm around -2.25 front and -1.5 rear, toe is virtually zero.
Car is lowered around 25mm front and 20mm rear.
-alex
Old 02-14-2014, 05:11 PM   #7
Victor Draken
Drives: Toyota Gt86
-alex
That's quite good. Higher camber in front, less camber rear and toe 0.
I would say is quite good. Will try without LCA then, I can always buy them if needed.
Old 02-14-2014, 05:33 PM   #8
I do like the effects certain bushings make, but to keep it simple you don't need them. They're just a little bonus.
- Andy
Old 02-15-2014, 12:26 AM   #9
CSG Mike
CSG Mike's Avatar
What spring rates are the RCE Springs?
Old 02-15-2014, 12:46 AM   #10
Victor Draken
Drives: Toyota Gt86
5K?
not sure need to check out
Old 02-15-2014, 01:27 AM   #11
5K?
285 for the TARMACS and 250 for the Yellows.
Myles
Old 02-15-2014, 10:09 AM   #12
Victor Draken
Drives: Toyota Gt86
Myles
@CSG Mike
answered.
Old 02-15-2014, 05:54 PM   #13
Keep in mind that the Bilsteins historically have run a LOT of gas pressure in their shocks and Koni does not. Most refer to that gas pressure as "platform" which equates to a very flat car in corners. Add in a decent spring rate (250-285) and you have something that feels more like a 340lb spring ......in the corners. I dont say that knocking the Koni's as they are adjustable. I say it so people have a better idea about the role gas pressure plays in the performance.
A responsive monotube, non adjustable damper with a solid amount of spring rate is a budget minded autocrossers nitrogen filled dream !
Myles
Old 02-15-2014, 06:43 PM   #14
MrH
Drives: 20 Outback XT, 23 BRZ on order
Keep in mind that the Bilsteins historically have run a LOT of gas pressure in their shocks and Koni does not. Most refer to that gas pressure as "platform" which equates to a very flat car in corners. Add in a decent spring rate (2550-285) and you have something that feels more like a 340lb spring ......in the corners. I dont say that knocking the Koni's as they are adjustable. I say it so people have a better idea about the role gas pressure plays in the performance.
Myles
Koni yellows are twin tubes and the Bilstein B8s are monotubes. Of course there's a huge difference in gas pressure.
MrH is offline   Reply With Quote
Different Suspension setup on BRZ? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-13-2013 09:36 PM
entry level tune mrnibbs Engine, Exhaust, Transmission 10 06-13-2013 04:41 PM
Subaru BRZ STi to be £2k higher than the £24,995 Entry level BRZ LeeMaster BRZ First-Gen (2012+) — General Topics 71 12-11-2012 02:53 AM
setup of suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-21-2012 04:03 PM
An entry level FR revival? aliphian Other Vehicles & General Automotive Discussions 9 11-14-2011 09:09 PM
