Old 02-06-2014, 07:54 PM   #225
mike the snake
Crash bar arrived! VERY nice piece. This IMO will easily match the safety of the stock crashbar.
SO, so far to combat the heat, I have;
Installed FB radiator with Spal fans and shroud. Radiator was also moved forward 1.5".
Soon to install FB oil cooler
Cut holes in bumper, and will install crash bar which will allow a LOT more air into the front
Fender garnishes cut and made into vents
Metal engine undertray will be modified, with an upside-down "Gurney Flap" installed to help pull air out of engine bay
I will be installing some custom ducting to help direct the air through the radiator and oil cooler
If all else fails, I'll be getting a vented hood as well
Old 02-06-2014, 08:22 PM   #226
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
To deal with some of the heat problems with the turbo at the track. We did some thermal coating on the turbo piping and heat shield to better protect the fans. Heat rated up to 1800+ degrees.
Evasive Motorsports is offline   Reply With Quote
Old 02-12-2014, 11:07 AM   #227
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Vcmc pulled the wiper cowl and reported a huge improvement. I dont believe its a high pressure zone below the lip of the hood like some say. Other wise there would be wind noise through the hvac vent grate. When my fbm kit shows up I plan on relocating my washer nozzles and pulling or hacking up my cowl. I really believe the problem is letting air out above all else.
Old 02-12-2014, 11:23 AM   #228
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Front mod bumper for air flow (air in)
fender garnishes and vented hood (air out)
sounds about right
Old 02-12-2014, 11:31 AM   #229
Dipstik-sportech
Dipstik-sportech's Avatar
The wiper cowl would be a low pressure area so the hot air would get sucked out of the bay. It's a good idea for a track car but on a daily I can't see a way to make it look nice but still allow venting
The Frozen North
Old 02-12-2014, 11:42 AM   #230
mike the snake
IMO it's both.
The intercooler literally covers almost the entire grill area. Any air making it to the radiator has to first go through the intercooler.
The air that does make it through to the radiator, then has nowhere to go due to the sealed engine bay.
Old 02-12-2014, 10:37 PM   #231
BRZ68
Drives: BRZ m/t
@mike the snake Do you think moving the Robispec radiator 1.5" forward plus having Spal fans with an Aluminum shroud will give enough clearance for front mounted turbo kits?
Do you think you would have had the Robispec rad to work if you moved it 1.5" right from the beginning? I also have the Robispec rad and I'm wondering if I will have clearance issues with my JDL kit come install time
BRZ68 is offline   Reply With Quote
Old 02-13-2014, 04:28 PM   #232
mike the snake
If you moved the radiator forward i think you'd have enough clearance, but the Robispec is thicker. On my car, we only tried things with the thin Robi and FB fans. That didn't work so I switched to the FB radiator, but I still needed to move the radiator forward to obtain the clearance I wanted.
. The Spal fans and shroud are thicker than just the thin FB fans.
You can move the radiator forward a good distance, and move the top a bit as well. If you were to do this I think it would probably work with the Robispec and your turbo kit, but I haven't seen your kit.
The Robispec is a really nice setup. That, with the spal fans and shroud would be THE very best setup I could think of running, as long as there's enough clearance.
Old 02-20-2014, 07:00 PM   #233
Ryan P
Aside from the price being crazy high has anyone had any experience with these heat shields, www.turbosource.com ? If they work as well as claimed you basically get all the benefits of wrapping without limiting the steel's ability to expand and contract.
Sent from my SPH-L710 using Tapatalk
Ryan P is offline   Reply With Quote
Old 02-20-2014, 08:05 PM   #234
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by Pitman View Post
Like this?
Which oil cooler is this?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-20-2014, 08:12 PM   #235
RickyB
Drives: Mazdaspeed 3
Inconel heat shields are worth every penny, IMHO. Just a few minutes on a dyno before and after with an infrared thermometer will convince you. Make sure you use one that is custom made for your application.
RickyB is offline   Reply With Quote
Old 02-20-2014, 08:16 PM   #236
Ryan P
Those are you have to send your parts to them. Thats what I wanted to hear haha. Thanks
Old 02-20-2014, 11:07 PM   #237
Reaper
Reaper's Avatar
Drives: violent
Ive used inconel before with great success. Cant afford it for this application though
Old 02-21-2014, 03:37 AM   #238
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
It is a Setrap Pro Line 619. I made the mounting brackets etc. myself.
Pitman is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
