Old 02-11-2014, 06:42 PM   #3319
Deathreaper
Drives: 2013 Scion FRS
Loving these results, forgot to ask - do these come with all the gaskets required?
Deathreaper is offline   Reply With Quote
Old 02-11-2014, 06:51 PM   #3320
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by tennisfreak View Post
Nice consistent torque across the range, good hp but nothing earth shattering. Actually the file says with ecutek tune and I was hoping/expecting closer to 200hp.
Notice the odd dip in both torque and hp at 3200 rpm, wonder whats up with that?
probably needs a touch more exhaust cam retard there at 3200.. hard to say till i get on the dyno with mine. It is possible that is it just the one are that they could not get the nth order resonances to line up in a way that would boost output in that range. I know lots of folks still want to believe the factory torque dip is 100% tuning or the cat but it isn't, it's the design of the factory header.
Also note, these resutls are with the rest of the exhaust stock
The Following 4 Users Say Thank You to mad_sb For This Useful Post:
Dimman (02-11-2014), FrsDuke (02-11-2014), Sportsguy83 (02-12-2014), toeout (02-11-2014)
Old 02-11-2014, 06:55 PM   #3321
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Exactly.......hitting over 200 on 93 shouldn't be an issue with a full exhaust.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
cjd (02-21-2015)
Old 02-11-2014, 07:00 PM   #3322
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Looks really good for a daily or short autoX courses like I have....
Wanting to see the 2.5inch exhaust results...
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-11-2014, 07:06 PM   #3323
mad_sb
depending on the dyno
The Following User Says Thank You to mad_sb For This Useful Post:
wparsons (02-11-2014)
Old 02-11-2014, 07:08 PM   #3324
Dustin
Twin Screw You
Dustin's Avatar
Touche
mad_sb (02-11-2014)
Old 02-11-2014, 07:15 PM   #3325
mad_sb
The bit i circled in green is the part that impresses me... that is the toughest place to find gains on the dyno for me. Unfortunately, it looks like the best gains there were on the Motec, not the stock ecu but at least it collects data that we can use to figure out what we need to do on the stock ecu to get those same gains there.... could be injection timing, knock sensor sensitivity, some unknown limiters etc.
Old 02-11-2014, 07:21 PM   #3326
mad_sb
I hope, and expect, that we are seeing muted gains up top due to the remainder of the exhaust being stock. I'm sure 3" header back will own the dyno sheet crown but I really want to see with it does with 2.5 catted nameless over / front and 2.5" catback (I do think the stock midpipe becomes a restriction once you do the header).
Old 02-11-2014, 07:23 PM   #3327
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
It's doable on 91 with a proper tune with just headers and a fp/op, so it's definitely doable on 93 with a full exhaust.
^GT5 Replay Photo Mode^
Old 02-11-2014, 07:25 PM   #3328
Dustin
Twin Screw You
Dustin's Avatar
If I weren't going supercharged I'd see what kind of gains this would put out when the rest of my 3" exhaust gets here. Don't want to buy a separate tune though just for results I don't care about. I think @Shneegle is getting a full 3" though with this header. Hopefully once his arrives he can post some before and after numbers. I think he is staying NA for a while.
Old 02-11-2014, 07:28 PM   #3329
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
Now the header is out (Congrats the charts look great!)... when the project was started you mentioned the goal of power but barely louder than stock package of header + exhaust (can't remember if it was on the forum, facebook or your webpage).
Everything I have read or heard of the nameless other exhaust components say they are very loud. So is a new stealth quiet headerback exhaust being designed as well to pair up with the headers?
MysteryMachine is offline   Reply With Quote
The Following User Says Thank You to MysteryMachine For This Useful Post:
Sonolin (02-11-2014)
Old 02-11-2014, 07:41 PM   #3330
Sonolin
I second this notion. Depending on price would purchase.
Sonolin is offline   Reply With Quote
Old 02-11-2014, 07:42 PM   #3331
Dimman
Kuruma Otaku
Dimman's Avatar
150 lb-ft in a damn near flat line for 4000 rpm range.
This is spectacular. A driver's setup. Great job guys!
Because titanium.
The Following 2 Users Say Thank You to Dimman For This Useful Post:
Sonolin (02-11-2014), wparsons (02-11-2014)
Old 02-11-2014, 07:44 PM   #3332
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
What SC are you coupling this header with? Interested in respect to clearances overall. Thx
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
