Sam Strano
Old 02-11-2014, 12:16 PM   #659
chucky12012
Drives: 2013 Asphalt Scion FR-S
Originally Posted by 7thgear View Post
now that the Bilstein HDs are out (B6), would you consider those over Koni?
I'm about to go that route myself, coming soon!
chucky12012 is offline   Reply With Quote
Old 02-11-2014, 12:25 PM   #660
Rexpelagi
Drives: 2013 Subaru BRZ
Originally Posted by Biggins View Post
Can you let us know in which one you are faster? I think the RX-8 will benefit a LOT with the +/-1 allowance.
I'm interested myself. :-)
I've only had the RX-8 for a few months and since we are still frozen up here it will be a bit longer until I know. The car I drove at Nationals is local though so it should be pretty easy to check. I agree that it should be much better on 17's, and I think on paper it has many advantages over the Twins.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 02-11-2014, 01:06 PM   #661
itzmik3
DBC Racing
itzmik3's Avatar
is this a fair hiearchy of stock mods from most to least important?
tires
camber (alignment)
brakes
bar
shocks
wheels
exhaust
i would agree with this ranking.
#194 SM
itzmik3 is offline   Reply With Quote
Old 02-11-2014, 01:07 PM   #662
itzmik3
DBC Racing
itzmik3's Avatar
correct me if im wrong, but these do not have any compression adjustment.
#194 SM
Old 02-11-2014, 01:09 PM   #663
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no, they have no adjustment, but they are considered to be very good for OEM applications.
also Monotube Gas vs Twin Tube Oil... technically speaking they handle bumps differnetly... the question is though does it matter.
also the bilsteins mean you don't have to drill and cut stuff if you've no access to that sort of thing.
Old 02-11-2014, 01:13 PM   #664
itzmik3
DBC Racing
itzmik3's Avatar
no, they have no adjustment, but they are very good otherwise for OEM applications.
http://www.stangtv.com/news/pri-2010...e-shock-shaft/
we were interested in trying to use this, but due to the design of the shock it would not be possible according to our sources.
#194 SM
Old 02-16-2014, 08:30 AM   #665
brianL.
brianL.'s Avatar
Drives: BRZ/1J Supra
What wheels are you guys running!?
I want enkei rpf1's and I want to go up 1" in wheel size but I can't find 18X7. I could only find 18X7.5
Could I fit 215/45/18 on 18X7.5 and still run in c-street?
brianL. is offline   Reply With Quote
Old 02-16-2014, 09:18 AM   #666
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
They aren't made in a 18x7.
If you are looking for a simple blunt answer, no. any diameter wheel with a 7.5" width is illegal for street class, you would immediately be bumped to ST.
Any particular reason you are dead set on a 18" wheel?
My 17x7 RPF1s with ZIIs will be arriving this week.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 02-16-2014, 10:43 AM   #667
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Very few legal options in 18x7, trust me, I looked. Just 1-2 sets of crappy cheap, heaviesh wheels. Except for the very rare RE30 Ecodrive Rays from 2009 in Japan. Extremely rare
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-16-2014, 11:06 AM   #668
brianL.
brianL.'s Avatar
the reason why I want to run 18's is because I want to close my wheel gap up a bit and since I'm not lowering the car this season I'd figured I'd go up 1 inch and since the street class allows to go up one inch I figured that would be a good bet.Looks like I'm going to run 17's........ :/
Old 02-16-2014, 12:56 PM   #669
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Gotcha... so if your plan is to eventually lower the car, which will move you out of C-Street anyway, why not get the wheels you actually want now so you don't re-buy wheels later? That would open your options up to other rim widths up to 9" wide. at a local level, you probably won't see a massive competition difference between C-street and STX, STX will likely be a bigger class anyway.
Old 02-16-2014, 01:34 PM   #670
brianL.
brianL.'s Avatar
Thats definitely the more logical thing to do but this is my first year in auto x and I'm doing things like evo school phase one and just trying to get a lot seat time.I don't want to change the car to much right now because it's a daily that I'm happy with and I'm in the middle of a lager build right now.I do want to modify my brz more but for once I'm keeping it simple.Once my driver skill gets better I will do what I want to the car.
plus I want to run in a class I could be some what competitive in.
Old 02-17-2014, 06:09 AM   #671
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
Originally Posted by AustinTX View Post
2nd event done. First event with a Strano front bar installed (thanks DWX). The car drove much better with the bar on. Finished 13th of 149 in PAX - https://axwaresystems.com/axorm/file...eb2014_pax.htm. Still a bit disappointed with the pace, as I'm getting stomped in X class (in which I have won the championship for the last 2 years).
The course was big power. I was rev limiting at the end of each fast section. Please feel free to critique anything you see. The biggest issue mentioned so far is that I could have went a little wider in the last sweeper and entered the final slalom faster. I was rev limiting for a good bit through the finish.
For that big right hander at about the 27-29 second mark in the video (video time, not in car camera time) could you have adjusted your entry a bit to give you a better exit? It seemed like you were turning the car most of the way to the gate that followed. I'm thinking if you could have adjusted the entry you would have be straighter (and thus faster) out and into the next gate.
mpicher is offline   Reply With Quote
Old 02-17-2014, 10:38 AM   #672
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Thanks for the advice. It was a pin turn, so I kept getting sucked in and turning a bit early.
Autocross nut
AustinTX is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
