Old 02-11-2014, 01:11 AM   #1
kaybee123
Drives: Scion FR-S
Tire for 250 whp
So I want to upgrade my summer tires for driving in Canada (not yet.. but it's coming soon!) and I want to know what my best options are.
I'd be installing them on the stock rims and I have about 250 whp.
I want a good ride quality while increasing the performance (and availability is super important!)
With so many to choose from, is there a guide? Recommendations?
(I saw someone was doing a 'warranty type deal' to upgrade the stock tires to something better a while back).
kaybee123 is offline   Reply With Quote
Old 02-11-2014, 01:13 AM   #2
CSG Mike
CSG Mike's Avatar
Are you trying to prevent straightline wheelspin? What rims do you have? What kind of conditions do you drive in?
Old 02-11-2014, 01:29 AM   #3
kaybee123
Drives: Scion FR-S
I want to prevent accidentally losing the backend in fast, sharp turns. (Basically, I'm trying NOT to drift)
Right now it's just too easy to lose the backend of the car while going fast. Better control is what I'm after.
I'll be driving in the dry, in the rain, we have a bunch of potholes here as well.
Stock rims! I like them.
Old 02-11-2014, 01:36 AM   #4
fatoni
what kind of budget? how aggressive of a tire can you run? i feel like the answer is the ra1 if you want that much tire, rs3 if you dont (dont know about canada though) and then maybe an re11 (re11a?) if its really cold
Old 02-11-2014, 01:43 AM   #5
kaybee123
Drives: Scion FR-S
I don't have a fixed budget (I always think it's silly to say I want to spend X amount on things).
I'm not sure what a more aggressive tire does! The temperatures range between 0C and 35C when I drive it! (I'm only driving the car in the spring/summer)
That's 32F to 95F
I'll look up the RA1 and the RS3
Old 02-11-2014, 01:48 AM   #6
CSG Mike
CSG Mike's Avatar
Those tires will NOT tolerate weather under 40F; you're risking cracking the rubber.
I'd recommend using traction control...
86-tundra (02-11-2014), fatoni (02-13-2014)
Old 02-11-2014, 07:57 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Down to 0C? Michelin Pilot Sport A/S 3, and get a stiffer front sway bar (or disconnect rear sway bar).
Big changes in power will affect ideal suspension setup. With more power to the rear wheels, you will generally want relatively more front roll stiffness and/or less rear roll stiffness to effectively put it down.
Old 02-11-2014, 08:36 AM   #8
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Achilles ATR Sport
Im rocking BFG KDW2's, good tire, but they fade in the heat I found.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 02-11-2014, 09:24 AM   #9
frslee
Just drive it
Drives: 13' FR-S
+1 on the Michelin Pilot Sport A/S 3
It's an all season tires, but its made more towards summer tires. These suck in snow, but very good in dry. Of course experts can share better recommendation than me, but from my experience these tires will do fine for your needs. Tread rating is 500!!!
frslee is offline   Reply With Quote
Old 02-11-2014, 10:00 AM   #10
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
Bridgestone potenza re760 sports
Scavanger is offline   Reply With Quote
Old 02-11-2014, 10:07 AM   #11
wparsons
wparsons's Avatar
Pilot Sport AS/3's in a size that fits on the stock wheels are going to be pretty helpless against 250whp.
In all honesty, it sounds like throttle restraint is what you really need. You shouldn't be on the throttle that hard mid corner, regardless of how much (or little) power you have.
If you're cornering at the very limit any power is going to result in the rear tires braking loose and the car wanting to spin. When you want to apply power you need to release some steering angle or you overwhelm the rear tires.
The Pilot Super Sports are a good all around summer tire, great grip and good wear. If you go to something like an RS3/ZII/etc you'll get more grip, but also more noise, faster wear.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (02-11-2014), SkAsphalt (02-14-2014)
Old 02-11-2014, 10:52 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
Not necessarily... AT lower speeds, yeah, but the usual max/extreme summer tires won't be any better in cool conditions on the street.
You should be on the gas pretty soon after mid-corner, and at that still relatively modest power/weight the resulting handling balance should tend more toward UNDERsteer as the fronts are unloaded unless it's a low-speed corner (1st or 2nd). In "fast" corners (which OP specifically mentioned), 250hp shouldn't overwhelm the tires, even A/S 3 all-seasons.
I *STILL* can't believe how many people think that oversteer in these cars is from too much throttle. At medium to higher speeds it is WAY more often the result of too LITTLE throttle (i.e., getting off the gas mid-corner near the limit)!
Yes, good throttle maintenance is required, and more power requires a more sensitive right foot, but still, 250rwhp should easily be put to the ground out of most medium- to higher-speed corners in good conditions in this car even on 215 or 225 Pilot A/S 3 tires. Lower speed corners in lower gears will of course require judicious use of the throttle...
Pilot Super Sports/RS3/ZII/etc are not suitable for temps below ~10C. I was pretty surprised at how little grip the PSS have even at 45F on the street!
You have to get tires based on the worst conditions. For street only usage from 0-35C (32-95F as already noted in the thread), I would definitely go with Pilot Sport A/S 3 over any summer tires.
Old 02-11-2014, 12:26 PM   #13
wparsons
wparsons's Avatar
I'm not talking about maintenance throttle when I say on the gas too hard too soon, I mean trying to add more gas without removing steering angle. Of course it's going to oversteer if you lift while at max cornering load, but if you try to go WOT before unwinding the steering angle you're also going to spin spin spin.
I might be making bad assumptions, but I would bet the OP is driving purely on the street and wants grip in 2nd gear corners like a ~40km/h right hand turn.
flickr
Old 02-11-2014, 02:29 PM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
In any case, for outright grip, the Michelin Pilot Sport A/S 3 all-season is going to do WAY better than any of the usual summer tire suspects (PSS, ZII, RS3, etc) at sub-40F temps, and won't be giving much if anything away at higher ambient temps on the street.
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
Tire Drone? SSchifko Issues | Warranty | Recalls / TSB 9 08-20-2013 09:18 PM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
RTR tire sizing SVThis Tracking / Autocross / HPDE / Drifting 10 02-19-2013 08:10 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
