Old 02-10-2014, 11:56 PM   #645
EN2_Squirrel
EN2_Squirrel's Avatar
Originally Posted by JerryMichaels7 View Post
So for all you veterans out there... I need help deciding on wheel size / tire size. Right now it is between 17x9 +35 or 17x8 + 45 both rpf1's. If the 8's then will get 245's but if the 9's get 255's? or a smaller tire on a bigger rim?, like 245' on the 9's?
I have 17x9 with 255's. You need coilovers to fit them. Even with a tune i don't see a reason for more tire.
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
The Following User Says Thank You to EN2_Squirrel For This Useful Post:
whataboutbob (02-11-2014)
Old 02-11-2014, 12:47 AM   #646
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I've run both 245 and 255 on 9 and I think I like the 245s better. Just get 17x9s, you should be able to run et35 without coils.
Plus the 9" RPF1s look SOOOOO much better than the 8" version.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Old 02-11-2014, 08:15 AM   #647
JerryMichaels7
Drives: Whiteout FRS
I got coilovers already so offset was never an issue. it was just deciding on rim size...but yeh think i am gonna just get the 9's.
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
The Following User Says Thank You to JerryMichaels7 For This Useful Post:
EN2_Squirrel (02-11-2014)
Old 02-11-2014, 09:07 AM   #648
Wepeel
Drives: '13 BRZ Ltd
What did you like better about the 245?
Wepeel is offline   Reply With Quote
Old 02-11-2014, 09:46 AM   #649
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
245 or 255 of what tire? That makes a difference because some have a stiffer sidewall than others. I was on 255 RS3's and like them a lot, though some prefer the 245. Just got a set of 255 ZII's I will be testing this weekend. They have a stiffer sidewall so they should be more responsive. I will be testing them against a set of Rivals in College station next month. Seems like the street tire classes don't generally try to fit the biggest rubber under the car as possible like we used to do in SP. With the right setup, I feel the more tire the better?
Do the 17X9 +35, if you get more involved in STX you will already have the right setup.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 02-11-2014, 10:26 AM   #650
BlaineWasHere
Grip>Drift
Drives: FRS
I was running 245 RS3s which have soft sidewall so I think the stretch helped the tire a little bit and I run mostly on concrete so I just loved the RS3s personally. I'm on 255 ZIIs now. I have an extra set of 17x9s so I think I'm gonna get a set of 245 Rivals to try as well...
Old 02-11-2014, 10:53 AM   #651
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
My setup: RPF1 17x9 +35 with 245/40R17 Rivals. My best recommendation is to go with 17x9 +35 if you plan on purchasing a BBK in the future.
PoorMansRacing is offline   Reply With Quote
Old 02-11-2014, 10:57 AM   #652
vroom4
I thought the RPF1 in a 9" couldnt fit a BBK no matter what? Isnt that the up side of the Mach V Awesome?
vroom4 is offline   Reply With Quote
Old 02-11-2014, 11:06 AM   #653
SubiePig
Rim width doesn't have an effect on brake clearance as much as offset and spoke design. Essex racing has a list of confirmed wheels that work with their kit on their site.
Enkei RPF1 17x8 45
Enkei RPF1 (very tight fit, but works) 17x9 35
Enkei Fujin 17x7.5 40
Kosei K4R 17x8 36
Mach V Motorsports "Awesome" wheel 17x9 42
OZ Ultraleggera 17x8 +48
Rays CE28N 18x7.5 47
Sparco (designed by OZ) Assetto Gara 17x7.5 48
Subaru OEM STI Wheels (2004) 17x7.5 53
Team Dynamic 1.2 17x7 38
Volk Racing TE37RT 17x9.5 +40
Wedsport TC105n 17x9 35
Wedsport TC105n 17x8 +42
Work Ultimates 18x8.5 47
The Following User Says Thank You to SubiePig For This Useful Post:
vroom4 (02-11-2014)
Old 02-11-2014, 02:39 PM   #654
piknockout
Drives: 2014 BRZ
Danny has a set of 17x9 et35 RPF1s that fit over his AP Racing kit, so he sold me the 17x9 +45's that came with the car from Andrew. Win for me.
Also on the Rivals, a 245 might also be better in that size. They have a softer sidewall as well and I think they liked being stretched a bit. I had my 245's stretched on a 9.5" wheel on the STi, seemed to work pretty well.
piknockout is offline   Reply With Quote
Old 02-13-2014, 02:04 PM   #655
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
Anybody think it's necessary to change trans/diff fluids for autox use to something like Motul? Or is the oem fluid ok? I remember reading somewhere that the rear diff fluid overheated during track use, but what about autox?
Thanks!
Aznsky is offline   Reply With Quote
Old 02-17-2014, 06:33 PM   #656
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
My mods: Eibach Sportline springs, Eibach sway bars front and rear, SPC camber bolts and rear LCAs, 16x7 Volk TE37s with 225/50/16 Hankook RS-3 140UTQ. I should still qualify for STX class if I am correct?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-17-2014, 06:58 PM   #657
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Correct. I'd love those wheels if you ever get bored with them, assuming they are +42 or higher
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-17-2014, 07:14 PM   #658
BRZZZZZZZZZZ
Car Nut
They are +46
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
