Old 02-10-2014, 02:05 PM   #771
jamesm
Most of the custom maps @jamesm is refrencing are to get around limitations of the Subaru BRZ ECU logic or to add features to the ECU that it was not intended to do such as FlexFuel, boost control, and wideband O2 readings. I would expect Hydra to be able to do all those things very easily.
there's a lot more to it than that, but yes those are the common use cases. i use them to make even mundane things like correcting di fueling error easier and more straightforward as well.
i agree that a lot of the stuff can probably be done with the standalones, but being able to implement new things on your own is something i'm not sure they support. i could totally be wrong on that, it's just not immediately apparent from using the hydra years ago on miatas. i wasn't actually tuning the thing at the time either, just using it as an end user.
what impresses me about custom maps isn't the ability to solve a known problem. it's the ability to solve nearly any problem, if that makes sense. if they provide that, then that's awesome.
Old 02-10-2014, 08:43 PM   #772
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Delivered.
Good evening passengers, this is your captain speaking.
[ame]http://youtu.be/oLP5s8A6umY[/ame]
Ironsquid is offline   Reply With Quote
The Following 5 Users Say Thank You to Ironsquid For This Useful Post:
Dipstik-sportech (02-10-2014), FullBlown (02-10-2014), johnb831 (02-10-2014), Sportsguy83 (02-10-2014), Turbo95eg6 (02-10-2014)
Old 02-10-2014, 08:47 PM   #773
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Jay, how much boost are you running?
FullBlown is offline   Reply With Quote
Old 02-10-2014, 08:50 PM   #774
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
That's only wastegate pressure baby, 10psi.
Old 02-10-2014, 09:07 PM   #775
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Ironsquid View Post
Delivered.
WOW..... LOVE IT!!
Mine sounds maybe half of that... Sounds really badass!!
Old 02-10-2014, 09:14 PM   #776
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
WOW..... LOVE IT!!
alot of wind noise also, I might video a pull from the engine bay
The Following User Says Thank You to Ironsquid For This Useful Post:
Old 02-10-2014, 09:15 PM   #777
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Love it
Old 02-11-2014, 03:57 PM   #778
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Some recent results from our dyno testing/tuning.
2013 FR-S FBM turbo kit. Base Map provided by FBM.
2013 FR-S FBM turbo kit. CAN91 map by Delicious Tuning.
2013 FR-S FBM turbo kit. E-85 map by Delicious Tuning.
Then an overlay of the three maps.
Infamous Performance is offline   Reply With Quote
Old 02-11-2014, 04:04 PM   #779
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Interesting that @DeliciousTuning only went up to 9.5 PSI even on E85.
Old 02-11-2014, 04:04 PM   #780
More results.
2013 FR-S. FBM Stage2 Turbo kit. E-85 FBM OTS map.
2013 FR-S. FBM Stage2 Turbo kit. Can91 Delicious Tuning map.
2013 FR-S. FBM Stage2 Turbo kit. E-85 Delicious Tuning map.
The three maps for comparison.
Old 02-11-2014, 04:06 PM   #781
Both of the cars just posted were experiencing clutch slip. We had to stop. The clutches cant hold the power. Anything in the 250whp range and the clutches are slipping. Both cars had stock clutches.
Old 02-11-2014, 04:07 PM   #782
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That makes sense then. The stock cluch is definitely no match for an FBM kit.
DeliciousTuning (02-11-2014)
Old 02-11-2014, 04:11 PM   #783
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
May as well add me to the list. Awaiting the delivery of my premium kit.
JordanWho is offline   Reply With Quote
Old 02-11-2014, 04:12 PM   #784
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Adding you now. When did you order and when do you expect to get it?
JordanWho (02-11-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
