Old 02-10-2014, 01:07 AM   #1135
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by solidONE View Post
Here's a 4th gear pull I logged before switching back to 91 gas:
http://www.datazap.me/u/solidone/2-9...zoom=6861-7250
This was after the computer had about 3-4 tanks of E85 to learn. At cruising and low load and low maf voltages the LTFT sweeps through the 3%-12% range. At high load and high MAF voltages the trims are low, mostly below 1% and AFR is pretty much spot on. Little on a the rich side, but I think that was intended. the OTS tunes are constantly improving. Very nice job Vishnu team!
Looks great. FWIW, we targeting a bit richer AFR no that we used to with the E85 maps. Turns out that running them a bit richer doesn't hurt power at all. So running mid 12s in the midrange, enriching to high 11s by 7500rpm is expected and desired. So I'd say things are running as intended. Glad you are enjoying the OFT ad our tunes
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
solidONE (02-10-2014), Wayno (05-10-2015)
Old 02-10-2014, 01:17 AM   #1136
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Cheers,
shiv
Shiv, curious if you want me to test any of the 1.5 tunes for the phantom that you have developed. Or do you want me to wait until you come down?
Installed Mods:
Old 02-10-2014, 01:39 AM   #1137
Shiv@Openflash
Drives: 2013 FRS
I can send you the new OTS map for the Phantom SC in .dev format. Same one I sending to other Phantom SC owners. And same one I've been running in our own shop car (with the TQ300). Here's what it did on the dyno with the OFT/OFH combo. Higher hp run is with the TQ300. Lower power run is with the TQ250. Still a bit left in there I think. Hoping to squeak out whatever is left on the table when I pay a visit to your school dyno later this month. Would be great to be able to test in multiple cars, on the same day, with no time constraints!
Just email me your original stock file and I'll make a Phantom OTS map for you (.dev format).
Cheers,
Shiv
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (02-10-2014), vynervt (02-10-2014), WRB5titch (02-10-2014)
Old 02-10-2014, 01:42 AM   #1138
Sojhinn
Sojhinn's Avatar
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread
Cheers,
Shiv
Looks great.
Ill send it your way. Do you have e85 too? Also were those runs with the dual pack batteries of standard setup?
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 02-10-2014, 01:48 AM   #1139
Shiv@Openflash
Drives: 2013 FRS
Looks great.
I haven't started developing the new E85 map for the Phantom SC. Probably start next week after I get back from Vortech. And those dyno numbers were with the standard battery set-up (2 12v dump batteries). Will be doubling up as soon as we get our battery relocation kit this week
DAEMANO (02-10-2014), WRB5titch (02-10-2014)
Old 02-10-2014, 01:54 AM   #1140
Sojhinn
Sojhinn's Avatar
Awesome. Looks like you are hitting what the e85/esc was basically doing throughout the low to midrange. Should be neat to see what it can all do together. Let me know if I can help in anyway.
Installed Mods:
Old 02-10-2014, 05:43 AM   #1141
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by Nardi330 View Post
I have a quick question about header and Stage 2 tune (non E85).
I read that your Stage 2 tune is for catless header. Would stage 2 work with aftermarket header with HFC or it's best to stay with stage 1 tune for catted header?
thanks in advance.
I'm actually wondering the same thing! I've got the OFT so I'm hoping one is a better option..
leicaboss is offline   Reply With Quote
Old 02-10-2014, 07:41 AM   #1142
8686
8686's Avatar
Drives: 86
Cheers,
Shiv
The difference between TQ250 and TQ300 looks small on the dyno.
Any noticeable difference in real life driving?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 02-10-2014, 12:00 PM   #1143
JFBRZ711
Drives: 13' BRZ Limited CBS
This afternoon's shipments:
Bunch of OFTs and a surprise present for our 1000th OFT customer.
Shiv and OFT owners, anybody know of any tuners that are willing to use OFT to tune with a dyno in Florida? I'm all for your e-tuning Shiv but I would love to experience a tuning session first hand and try to learn a thing or two : )
JFBRZ711 is offline   Reply With Quote
Old 02-10-2014, 12:13 PM   #1144
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by JFBRZ711 View Post
Shiv and OFT owners, anybody know of any tuners that are willing to use OFT to tune with a dyno if Florida? I'm all for your e-tuning Shiv but I would love to experience a tuning session first hand and try to learn a thing or two : )
Great question!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-10-2014, 02:36 PM   #1145
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by normancw View Post
Will you have a Vortech tune for the OFH as well (on 91)?
Yes indeed. I'll be going down to Vortech later this week. And will be developing our own custom (non-CARB) maps immediately thereafter. With and without OFH.
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
normancw (02-10-2014)
Old 02-10-2014, 02:37 PM   #1146
Shiv@Openflash
Drives: 2013 FRS
I'd imagine any tuner who can tune will be willing to use OFT. Maybe not Ecutek tuners due to conflict of interested but that's ok. More important is to find a tuner that is competent. Perhaps one that has experience with Subarus as the Denso ECU in the FA20 is very similar.
JFBRZ711 (02-10-2014)
Old 02-10-2014, 03:38 PM   #1147
Cross
It's the Mad Cow
Cross's Avatar
@shiv@vishnu
Any update on E85 cold starts yet? I thought you were starting work on that a few weeks ago.
Just wanted to see if there was an update I overlooked I know there are a lot of threads to keep up with.
Thanks.
Old 02-10-2014, 04:00 PM   #1148
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I've been noticing some "cold start" issues lately as well. At first I assumed it was morning temps, but it doesn't get nearly as cold here as people who have legitimate cold seasons. But I had trouble starting yesterday afternoon when the car sat all night and half the day, but ambient temp was warm.
Basically, the first start attempt ends in sputters and the second try starts it right up. This morning I played with the throttle a bit on the first try and did get it to finally catch.
I'm on v1.42. Any thoughts? I think the coldest outside temps I see here are around 40-50 F.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
