Old 02-07-2014, 08:32 PM   #1
FUN BRZ
Drive 2 Eat, Eat 2 Drive
FUN BRZ's Avatar
Drives: FUN SUPERCHARGED 2013 Limited BRZ
A/C Issue?
Has anyone run into a problem with their A/C?
2013 LR BRZ Limited ~ BTW
I'll have the A/C and set at 70-75 but it feels warm... not like the 70-75 I'm used to from my Accord.
Then when I turn off the A/C 70-75 feels more like 85...
Has anyone else had this issue?
Thanks!
FUN_BRZ <--- "Insta-Fun"
FUN BRZ is offline   Reply With Quote
Old 02-08-2014, 12:17 AM   #2
Thanks!
Well, no, mine seems to work fine.
Do you have the recirc button punched .. ??
Does the clutch on the compressor engauge .. ??
Or, it may be low on refridgerant .. ??
Old 02-08-2014, 03:06 PM   #3
FUN BRZ
FUN BRZ's Avatar
I'm sorry but I don't what either of those are....
Old 02-08-2014, 03:16 PM   #4
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
There is something I read somewhere about the fan putting out warm air in summer with the heat off. Something about turning off the fan to reset the system and then turn back on. Don't remember the exact procedure. From what I recall having done it once or twice in the summer, the air was cooler after you did this. The same issue may be play if you just turn on the air without resetting? Just making a suggestion. But you have a BRZ so it may be different than the FRS.
smbrm is offline   Reply With Quote
Old 02-08-2014, 03:23 PM   #5
Well, let's see......hmmm..... your BRZ limited may not have a recirculation button. That feature allows recirculation of the cabin air and doesn't allow outside air to enter the cabin (makes air conditioning more efficient).
The "clutch" on the A/C compressor is located on the pulley on the front of the compressor. When the A/C is "working", the clutch is engauged (goes around with the pulley); when the A/C is "not working", the pulley still goes around, but the clutch part does not.
I hope this helps.
You may wish to take your car to the dealer (if still under warranty) or to a auto shop to have the system checked.
Old 02-08-2014, 03:34 PM   #6
FUN BRZ
FUN BRZ's Avatar
I hope this helps.
Yeah I might just take it in when I get a day off, just picked it up in Nov. so everything is still covered. Thanks!
BRZ Nav MP3 issue TheRipler Electronics | Audio | NAV | Infotainment 5 09-06-2013 03:21 PM
TCS Issue subaruatheart Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-26-2013 02:28 PM
Anyone has the same issue like me? ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 5 04-16-2013 11:23 PM
Cel issue Z06tofrs Issues | Warranty | Recalls / TSB 2 08-27-2012 11:13 AM
Anyone having this issue? zoomzoomers BRZ First-Gen (2012+) — General Topics 11 08-10-2012 12:19 AM
