Old 02-07-2014, 09:49 PM   #267
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by Fizz View Post
+ 1
But I think a more accurate way to measure would be from center of wheel to fender
I hear you on that, but I'm imagining folks trying to use a tape measurer and eye-ball if they're exactly in the middle of their wheel/hub, so I figured it would be easier if they could put the tape measurer on the ground and read the measurement at the edge of the fender.
As long as the tires are close to stock diameter and properly inflated, it should get me what I'm looking for.
jprice130 is offline   Reply With Quote
Old 02-07-2014, 10:49 PM   #268
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by jprice130 View Post
Would a few of you RCE Yellow users mind providing me with a measurement from the ground to the edge of your fender wells? I know the ideal measurement is from center of hub to the fender, but I'm just looking for a rough measurement and could not find this information with the forum's search feature or Google.
I also know that the advertised drop is 20mm, but if you wouldn't mind humoring me and giving me a few measurements for the front and back fenders, I'd appreciate it. It would be preferable if you were using tires with stock diameter (215/45/17 or 245/40/17). Thanks!
I'm at 25-3/4" (+-1/16") front and rear running 245/40R17 ZII tires @ 32psi.
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
jprice130 (02-07-2014)
Old 03-22-2015, 10:31 PM   #269
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Bumping this thread because I finally had the time to get these on
Still on winter tires, I like the ride on the street. The rear is less "riding a bull in a rodeo", and way more mature with the firmer spring rate.
Drop is subtle, which I also like...
Can't wait for summer tires to go on!
drewbot is offline   Reply With Quote
The Following 2 Users Say Thank You to drewbot For This Useful Post:
D_Thissen (03-22-2015), Racecomp Engineering (03-24-2015)
Old 03-24-2015, 03:39 PM   #270
D_Thissen
D_Thissen's Avatar
Installed these over the weekend. The car feels much more planted than before, especially the rear end, while not being harsh over bumps. Turn in seems to have improved also despite being on winter tires.
After 48 hours, here are some rough measurements (+- 1/8"), I didn't check tire pressure before handand my driveway isn't 100% flat. Sorry I didn't take before measurements
FL 26"
FR 25 7/8"
RL 25 3/4"
RR 25 3/4"
Before:
A few hours after the install:
The Following 3 Users Say Thank You to D_Thissen For This Useful Post:
drewbot (03-24-2015), Racecomp Engineering (03-24-2015), tinma (03-24-2015)
Old 03-24-2015, 04:30 PM   #271
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@D_Thissen lol your write up is exactly what I feel when driving it.
After 48 hours, my fronts got just a tad lower, now the car looks definitely lower. Even with steelies I like it!!!
The Following User Says Thank You to drewbot For This Useful Post:
D_Thissen (03-24-2015)
Old 03-24-2015, 04:53 PM   #272
D_Thissen
D_Thissen's Avatar
Yeah I am pretty impressed by how it handles now with just springs. I also noticed that it is more stable under heavy braking. I cant wait for the summer tires to go on though lol
Old 03-26-2015, 09:05 AM   #273
D_Thissen
D_Thissen's Avatar
Going in for an alignment tomorrow (I've had the springs on for about 5 days and 250km). What specs would you suggest for a car that's used for light auto-x/spirited driving/DD? Also how much toe-in should the rear have? Or will I be fine to just stick with the specs you guys posted here? Sorry for the newbness lol
http://racecompengineering.com/instr...owsettings.pdf
Thanks!
Old 03-26-2015, 09:51 AM   #274
Thanks!
The specs posted in that pdf are good. Did you get the front and rear camber adjustment? (bolts for the front, rear LCAs or the rear whiteline camber bushing)
- Andy
Old 03-26-2015, 10:23 AM   #275
D_Thissen
D_Thissen's Avatar
- Andy
Hey Andy,
No, unfortunately not. Just front camber bolts.
Old 03-26-2015, 02:03 PM   #276
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Since this seems to be the catch all RCE Yellow thread, I'll ask here. I know the yellows work with both stock and Bilstein's, but I was wondering what @Racecomp Engineering believes has the better damping curve for the yellows' 4.5k spring rate, stock or Bilsteins (specifically in the front)?
All I can gather after hours of reading is both are great, but I assume one has to have an advantage over the other; and, if so, why? I'm not concerned about redampening the Bilsteins, but out of the box, are they better suited for the RCE Yellows? I would venture to think they're a bit over dampened for 4.5k.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-26-2015, 03:08 PM   #277
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Doesn't RCE claim the yellows are designed around OEM shocks and the tarmac springs are designed with aftermarket in mind?
I use the yellows on stock dampers. Feels like an OEM stiff and sporty suspension and is very predictable.
2much is offline   Reply With Quote
Old 03-26-2015, 03:16 PM   #278
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Well yes, that's the general consensus, but I have yet to hear(read) it from the horses mouth. And, everything has been wishy washy, not specific claims around dampining curves and the such. I understand that they work very very well, but I was wondering if 4.5K is what RCE considers optimal on the stock dampers.
Old 03-26-2015, 05:45 PM   #279
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I'm not trying to hijack this thread, but I recently bought a set of RCE Yellows myself. If anybody knows a good shop around the Middle Tennessee area for installation, I'd really appreciate a recommendation.
smg1138 is offline   Reply With Quote
Old 03-26-2015, 05:50 PM   #280
2much
I wanna go fast
You might get a better result in your regional forum?
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
