Old 09-09-2013, 03:46 PM   #43
ARK Performance
ARK Performance's Avatar
Drives: Subaru BRZ
of course! always here to help
ARK Performance is offline   Reply With Quote
Old 09-16-2013, 02:33 PM   #44
ARK Performance
Drives: Subaru BRZ
Our exhaust is pretty quiet for the most part inside cabin but sound is very subjective..
Old 09-16-2013, 06:29 PM   #45
xxscaxx
Drives: 2013 SWP BRZ
I've had the dt-s installed by itself, with a catted front pipe, with a uel header, and now with the header and catback alone.
This exhaust does not drone.. Loud maybe yes with the header/front pipe combo, but even then there was no drone.
The greddy evo3 I had droned HORRIBLY with just the catback. Maybe you mean it's just loud, or maybe not having that cat in the front pipe really makes that much of a difference. But when I had the header on there I was down one cat and there was no drone.
xxscaxx is offline   Reply With Quote
Old 09-16-2013, 07:34 PM   #46
SigmaHyperion
Drives: 2013 SWP BRZ Limited
My other vehicle is a 400whp GTO, that, for a time I ran straight dumps on, right off the header.
I know the difference between loud and drone
When accelerating under heavy load the car drones; pressing the accelerator down in 6th gear in the dreaded torque dip between 2000-2500rpm. It just does. At least -- again, I stress -- with a test pipe. I've never known an aftermarket exhaust that didn't to some extent and, as I said, this is definitely one of the best I've experienced, and that's with a catless pipe even. I don't doubt that with just the catback, it's not an issue at all. And, besides, it's a good excuse to downshift as the increase in revs drops the drone to almost nil.
I will say that after some break-in time this has improved considerably. And it's not me 'getting used to it' either; as I only drive the FRS once or twice a week. It has genuinely improved by a fair margin. I will still do something to cut down the sound in the cabin, but that was always the plan anyways due to road noise and should take care of the last of the remnants.
To reiterate my original post -- the sound of this exhaust setup is absolutely epic. Even if it did drone badly I would put up with it because it just sounds that good. The fact that it really is minor is just that much of a bonus. I'm currently planning a 4000-mile road trip; if the drone was bad, I'd never consider it. But, to put it in perspective, I won't do it until I cut down the road noise -- so, to me, the road noise is worse than the drone I'm experiencing. So if you're not bothered by the road noise present in a stock vehicle, you surely won't be bothered by the drone; and even less so after it breaks in a bit.
SigmaHyperion is offline   Reply With Quote
The Following User Says Thank You to SigmaHyperion For This Useful Post:
Chad86 (06-03-2016)
Old 02-06-2014, 01:00 PM   #47
ARK Performance
Drives: Subaru BRZ
Thanks for all the reviews and comments guys!!
If anyone is looking to pick up a beautiful exhaust, give me a shout
Erick @ ARK Performance.
Old 02-06-2014, 06:28 PM   #48
86ING IT
Drives: 2013 scion frs
How much for the front test pipe? I'm local. OC.
86ING IT is offline   Reply With Quote
Old 02-07-2014, 12:51 PM   #49
ARK Performance
Drives: Subaru BRZ
Pm'd
Old 02-08-2014, 05:18 AM   #50
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
shot from a recent late night photo shoot
Old 04-23-2014, 10:46 PM   #51
willharp360
So my Ark Grip hangs down on the left side? Anyone else have this problem or know how to fix it?
willharp360 is offline   Reply With Quote
Old 04-24-2014, 10:00 AM   #52
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
DONT MIND THE CAPS.....MY KEY IS STUCK AND I NEED TO FIX IT...
HAVE YOU LOOSENED UP THE MID PIPE-AXLE BACK SECTIONS TO TRY ALIGNING IT? NOT TRYING TO SOUND LIKE A ****, BUT THAT'S HOW I (AND OTHERS) FIXED MINE AFTER MY FIRST ATTEMPT LEFT IT ABOUT HALF AN INCH LOWER THAN THE RIGHT. JUST REQUIRES SOME FINE TUNING
Propaganda is offline   Reply With Quote
Old 04-24-2014, 10:41 AM   #53
Malt
Drives: 2015 WRX
You can hold down your shift key to get lower case letters with a stuck caps lock key.
Malt is offline   Reply With Quote
Old 04-24-2014, 11:07 AM   #54
Propaganda
Fixed it with a restart... was just some glitch. Anyway, holding down the key and typing with one hand would take too long.
Old 04-24-2014, 11:58 AM   #55
willharp360
I'll give it a shot! Hopefully that'll fix the problem
Old 04-24-2014, 11:59 AM   #56
xDJ DUBx
Lurker
xDJ DUBx's Avatar
Drives: '14 Rocket Bunny Monogram FRS
Send a message via AIM to xDJ DUBx Send a message via Yahoo to xDJ DUBx
On my DT-S, the flange at the S-pipe and mid pipe touch the car and makes the worst clunking noise at certain RPMs Need to get under there and attempt to readjust.
xDJ DUBx is offline   Reply With Quote
►►The Definitive LOWERING SPRING Thread◄◄ LOWEST PRICES ON FT86Club & FREE Shipping!! CygnusPerformance.com Brakes, Suspension, Chassis 38 08-05-2013 01:28 PM
►► SUPER PRO ◄◄ Every Single BRZ/FS-R Part They Make IN STOCK NOW with Free Shipping! CygnusPerformance.com Brakes, Suspension, Chassis 30 08-01-2013 06:28 PM
► Styluz Wheels ► 17x7 18x7.5 5x100 ► In Stock ► Free Shipping FM Wheels Wheels and Tires 2 08-01-2013 05:18 PM
►►►► For a Limited Time Only Like Cygnus Performance on Facebook Get $5 FREE!!!* ◄◄◄◄ CygnusPerformance.com Announcements, Contests, Giveaways 1 03-08-2013 07:04 AM
►►Stance Super Sport Coilovers◄◄ Free Shipping - Photos and Video FT-86 SpeedFactory Brakes, Suspension, Chassis 43 01-31-2013 09:17 PM
