Old 02-07-2014, 02:31 AM   #463
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by Tansey86 View Post
Car looks great. Im convinced these wheels make any car look amazing. Solid choice.
Thank you sir.
Originally Posted by switchlanez View Post
Wow that's ballsy. Like really, it takes balls to run square tires that are known to rub even in a skinnier size. Any rubbing, what are your camber/height specs, and what body pieces have you modified (if any)?
They definitely rub without the above mentioned modifications. Camber is -2 all the way around. Ride height, I'm really not sure. I would need to measure it. I honestly wouldn't mind lowering it another 5-7mm just for aesthetics.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following 2 Users Say Thank You to Acree For This Useful Post:
Hicklinc (02-05-2018), switchlanez (02-07-2014)
Old 02-07-2014, 02:35 AM   #464
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You looking at adding some boost soon to push all that meat? Looking at your past rides I suspect you must have plans for that.
Old 02-07-2014, 02:41 AM   #465
Acree
Acree's Avatar
I want nothing to do with a big turbo on a small engine. LS all the way
The Following User Says Thank You to Acree For This Useful Post:
hotpanda1 (02-20-2014)
Old 02-11-2014, 12:50 AM   #466
mswhong
Drives: FT86
first shoot - 17x9+35 wrapped in 245/40 (yes, it needs more low)
mswhong is offline   Reply With Quote
The Following 7 Users Say Thank You to mswhong For This Useful Post:
argonaddict (02-20-2014), gkubed (08-06-2016), hakkoo (03-17-2014), Herndon (03-28-2014), hotpanda1 (02-20-2014), jonzhuxD (02-12-2014), Slipstream (02-19-2014)
Old 02-11-2014, 01:00 AM   #467
mfbmike
Drives: 2013 FRS, 2008 R32
Welcome to the 265/35 Michelin PSS club @Acree
mfbmike is offline   Reply With Quote
The Following 3 Users Say Thank You to mfbmike For This Useful Post:
Acree (02-11-2014), Hicklinc (02-05-2018), hotpanda1 (02-20-2014)
Old 02-11-2014, 01:19 AM   #468
jonzhuxD
Drives: Ultramarine FR-S
Anyone with meaty tires on stock suspension or am I kidding myself asking?
jonzhuxD is offline   Reply With Quote
Old 02-11-2014, 02:59 PM   #469
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I'm looking for examples of 235/45/17 - tough to find. I like the look of the extra sidewall.
Khyron686 is offline   Reply With Quote
The Following User Says Thank You to Khyron686 For This Useful Post:
Norville Rogers (08-27-2016)
Old 02-12-2014, 03:32 PM   #470
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yeah i doubt you'll find it in this thread, 235 isn't exactly meaty.
however if anyone puts OEM 2011+ wrx wheels/tires on their frs then it'll look the same. actually if you go to my build thread you will see how that exact setup looks, i had it for a few weeks.
Jive Turkey is offline   Reply With Quote
Old 02-19-2014, 10:25 PM   #471
shattered_memory
Drives: Satin White BRZ Limited
Has anyone felt a huge difference in gearing and acceleration when upgrading to 255's? Road and track tested a fr-s with wider 235/40/18 dunlop direzza tires (about 2 mph difference in speed from OEM) and saw that the tire setup negatively affected lap times over the 215/45/17 direzza tires.
It kinda makes me think that 255's or wider, and 18 inch wheels are unnecessary for a stock car. any input is much appreciated.
Here is the Road and Track Video as reference: [ame="http://www.youtube.com/watch?v=r_IWa_qlt3g"]2013 Scion FR-S - YouTube[/ame]
shattered_memory is offline   Reply With Quote
The Following 2 Users Say Thank You to shattered_memory For This Useful Post:
Hicklinc (02-05-2018), SuperTom (10-25-2018)
Old 02-19-2014, 10:47 PM   #472
horrorbiz
horrorbiz's Avatar
Drives: ‘22 BRZ Limited
Well they definitely aren't necessary but they can improve handling. Their plus size setup recorded higher speeds in the slalom. That said, I'm putting 215/40-17's on mine so I don't belong in here! Haha
horrorbiz is offline   Reply With Quote
Old 02-20-2014, 01:12 AM   #473
shattered_memory
I guess it's better handling for the sake of overall acceleration, unless you upgrade the gearing in the transmission. I'm also going to stick with 215's also. I think 245/40/17 are best if you want to have more grip without effecting gearing as much.
The Following User Says Thank You to shattered_memory For This Useful Post:
Old 02-20-2014, 01:30 AM   #474
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
What wheels you running
Jmonty is offline   Reply With Quote
Old 02-20-2014, 03:05 AM   #475
mswhong
Drives: FT86
enkei rpf1
Old 02-20-2014, 03:34 AM   #476
mfbmike
I don't think anyone argued that their wide wheel & meaty tire setup was breaking any lap records. lol.
Yes, you will see a slight decrease in overall acceleration and mpg's as a result of the extra rotational mass.
Also, (been a long while since I watched that vid) I think the lap time on the 235's was just slightly slower than the 215's. Lateral grip increased iirc as well. With that being said, yes, 18 inch wheels and 255+ tires ARE unnecessary and probably unreasonable for this car under stock power. Not every mod needs to need an explanation. It's my car. lol.
Still looks awesome. Having grip for days is a blast.
The Following User Says Thank You to mfbmike For This Useful Post:
shattered_memory (02-20-2014)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
