Old 02-05-2014, 04:07 AM   #15
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
What are the weights and specs?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-05-2014, 09:27 AM   #16
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
17.8 pounds. 17x9 +42.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following User Says Thank You to Mach V Dan For This Useful Post:
mines13 (02-05-2014)
Old 02-05-2014, 11:00 AM   #17
vroom4
Does anyone have a picture or a chop of the 17x9s in gunmetal and/or silver on a silver BRZ?
Also, anyone have 245/40s with max negative camber on crash bolts? Any rub under full compression?
Thanks!
Garrett
vroom4 is offline   Reply With Quote
Old 02-05-2014, 11:20 AM   #18
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by ultra View Post
Love these wheels. So functional.
I second the guy who wants some 17 x 8s with the reat BBK clearance,
Also, what ever happened to Matt Andrews?
He sold his car, focusing on other things but he will pick up some new toy I'm sure.
mines13 is offline   Reply With Quote
Old 02-05-2014, 11:23 AM   #19
mines13
mines13's Avatar
Thanks!
Garrett
This is an excellent combo, I am running silver on silver myself. When I had a 255/40R17 with Swift springs and crash bolts maxed out the tire was probably within a mm to touching on the stock spring seat. With a 245/40 you should have a few mm of clearance. You should have zero issue on the fender clearance with full compression.
Old 02-05-2014, 07:19 PM   #20
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
Originally Posted by Mach V Dan View Post
Photo by Danny Nguyen.
This is BEAUTIFUL! Who is this? Are they on the forums here?
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 02-06-2014, 10:41 AM   #21
mines13
mines13's Avatar
That's me. The picture looks so great because of how well it was taken. I take zero credit for it. Here are some more pictures that are not quite as spectacular showing off the wheels.
The Following 2 Users Say Thank You to mines13 For This Useful Post:
DAEMANO (02-06-2014), red_comet (02-06-2014)
Old 02-06-2014, 01:33 PM   #22
red_comet
Severed Member
red_comet's Avatar
@mines13 - Thanks for such a quick reply! It really does look sweet. What are your tires' model and spec? Also, I read your build thread and I wonder- did you upgrade to coilovers or are you still using the swift springs? The front looks pretty well cambered in... I'm interested in getting the Mach V Awesomes and I know that with their width getting them under the fender will require some negative camber. I guess my general question is... what is your current setup?
13 FRS doriftoooo!
DON'T PANIC
Old 02-06-2014, 04:22 PM   #23
mines13
mines13's Avatar
I am currently on Eibach R2's. The tires are 255/40R17 Federal 595 RS-R. Camber bolts would still be sufficient, especially if you stick with the better 245/40R17 size for a 9" wide wheel. I feel that the tire/size numbed the steering pretty significantly. My next setup with be a 245mm width tire.
The Following User Says Thank You to mines13 For This Useful Post:
Old 02-06-2014, 04:51 PM   #24
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by v1ru5 View Post
Mach V Wicked Awesomes wrapped in 265/35R18 Advan AD08R and hugging Brembo's biggest setup for this car.
More information on the brake setup? Are they from the standard STI swap?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 02-06-2014, 07:22 PM   #25
CrazyWookiee
Drives: Whiteout FR-S
These look almost just like the 5Zigen FN01R-C's.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
The Following User Says Thank You to CrazyWookiee For This Useful Post:
funwheeldrive (08-11-2017)
Old 02-07-2014, 11:42 AM   #26
mines13
mines13's Avatar
This is well established, what makes these better is that the 5Zigen wheels are not available in the more desirable fitments for these cars. You can not get the FN01R-C in17x9 or 18x9.5 with a 5x100 bolt pattern.
Old 02-07-2014, 12:49 PM   #27
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I just love the finish of the 5Zigen. Would be awesome to get a pair of wicked awesomes and poweder coat them with a beautiful matte finish
OjiGeorge is offline   Reply With Quote
Old 02-07-2014, 01:12 PM   #28
vroom4
Instead, will have to settle for the silver which is SLIGHTLY darker than the BRZ silver, since the gunmetal is essentially black.
awesome, mach, wicked awesome
Mach V Awesome wheels Mach V Dan Wheels and Tires 187 11-18-2022 09:18 AM
Wheel Directory: Mach V Wicked Awesome 18x9.5 +42 Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 11-21-2013 10:36 PM
Wheel Directory: Mach V Awesome 17x9.0 +42 / 18x9.5 +42 Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 10:21 PM
FS: Mach V Awesome NIB Silver Socal RiskyTrousers Wheels and Tires 8 03-02-2013 10:54 PM
