Old 02-05-2014, 09:53 PM   #57
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Originally Posted by SmsAlSuwaidi View Post
Would it be possible to see more picture of the bar please ?
Sent from my IBrick
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
ATL BRZ (02-05-2014)
Old 02-05-2014, 10:00 PM   #58
smbstyle
smbstyle's Avatar
Originally Posted by hmong337 View Post
Great blogging. Any plans for more power?
Subb'd
Thanks!
Yeah, I've got an HKS drop-in filter about to go in, and am going to trim the OEM snorkel a bit, but I'm holding off on anything further due to wanting to still having the warranty in tact in case an engine issue arises, and wanting to see how this whole DI seal thing pans out and how the engines hold up in the long term.
Later on I'm planning on OpenFlash Tablet and OpenFlash Header, Raceseng Pulley Kit, and a Overpipe/Front Pipe combo.
Depending on how the Jackson Racing S/C cars hold up over time, I'll probably end up going that route eventually.
2013 SWP BRZ
Old 02-05-2014, 11:47 PM   #59
BRZUOENO
Drives: BLACK BRZ
nice parts! digging the brake cooler kit also
BRZUOENO is offline   Reply With Quote
The Following User Says Thank You to BRZUOENO For This Useful Post:
smbstyle (02-06-2014)
Old 02-06-2014, 09:55 AM   #60
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Love the harness bar! I'm putting that on my to-do list.
Old 02-06-2014, 10:12 AM   #61
smbstyle
smbstyle's Avatar
Thanks! Yeah its very simple and love that I can continue to use my HANS device now.
2013 SWP BRZ
Old 02-06-2014, 11:47 AM   #62
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I like this build
F1point4 is offline   Reply With Quote
Old 02-07-2014, 01:39 PM   #63
smbstyle
smbstyle's Avatar
Did the snorkel modification (cut and widened the opening w/ heat gun) and added the HKS filter:
2013 SWP BRZ
Old 02-07-2014, 02:45 PM   #64
zeppy
Drives: subaru brz-limited
how was the bumper to take off? I gotta do mine soon for the perrin oil cooler. I'm not familiar with the snorkel mod? Idea is to get more air in?
zeppy is offline   Reply With Quote
Old 02-07-2014, 08:08 PM   #65
smbstyle
smbstyle's Avatar
Bumper removal was pretty much straight forward, just a bunch of push pins and 10mm screws/bolts. Only tricky part was figuring out how the side markers come out; basically you just push in the metal tab that you can see facing you when you pull the fender liner back while pulling the side marker out and they pop right out. Bumper comes off by pulling it forward gently and comes right off the car.
4-5 hp gain with the HKS filter and snorkel mod, snorkel mod helps richen things up a bit and a bit better flow to the intake. Basically cut the snorkel and flare out the end.
http://www.ft86club.com/forums/showt...hlight=snorkel
2013 SWP BRZ
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
ottoyu34 (01-04-2016), zeppy (02-08-2014)
Old 02-11-2014, 05:19 PM   #66
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by smbstyle View Post
Yeah I'd like to make it up to a Road America event sometime, but that is a 20 hour drive, ugh...
Expo man, I'm driving up. June 30/July 1.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2014, 05:21 PM   #67
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You know it's totally unsafe though right? lol In the event of a real collision/accident I mean.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2014, 09:53 PM   #68
smbstyle
smbstyle's Avatar
I would fall asleep and die at the wheel on a drive that long lol, that takes some serious dedication!!
2013 SWP BRZ
Old 02-11-2014, 09:54 PM   #69
smbstyle
smbstyle's Avatar
What do you mean?
I don't use the harness on the street at all; only the OEM 3 point.
On track I use the Harness bar/Schroth Profi II ASM 4 point. I talked with Schroth and their distributor, HMS Motorsports, and it was recommended for my setup with stock seats to go with a harness bar and Profi II ASM, as a harness bar is required in our cars to get the proper angle of the shoulder belts. The harness bar mounts to all of the factory seat belt mounting locations.
The Profi II ASM is the only 4 point I would consider running because of the anti-submarining technology built into the harness. It's also FIA approved.
http://english.schroth.com/racing/technology/asm.php
http://www.hmsmotorsport.com/store/s...m/profi-ii-asm
Now there are a bunch of arguments each way regarding harnesses/harness bar in a rollover, but the likelihood of a spinal related head/neck injury from contacting a wall is much higher and much more likely vs. a rollover or injuries from a rollover. Not only that, but the BRZs fair pretty well in rollovers.
http://i.imgur.com/vrBJn1I.jpg
(related to this post: http://www.ft86club.com/forums/showp...6&postcount=19 )
http://brzcrash.com/wp-content/uploa...wn-crashed.jpg
http://brzcrash.com/wp-content/uploa...alled-flip.jpg
2013 SWP BRZ
Old 02-11-2014, 11:38 PM   #70
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A buddy of mine wrecked his car and the OEM seat back broke (as it's designed to do). Imagine how friendly that bar will be then.
Some groups will not allow you to run that, including events I help run
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
