Old 02-06-2014, 09:22 AM   #15
LPC_FRS
LPC_FRS's Avatar
Drives: Scion FRS
What if I run 18x9.5? I'm guessing I will need coilovers then, correct?
LPC_FRS is offline   Reply With Quote
Old 02-06-2014, 09:28 AM   #16
2pt5RS
Berz
Originally Posted by Pete156 View Post
Michelin Pilot Super Sport
You won't be disappointed
This... they may be the more expensive tire, but well worth the money..
2pt5RS is offline   Reply With Quote
Old 02-06-2014, 09:36 AM   #17
Biggins
Drives: Yes
It depends on the offset of the wheels and size of the tires. I would not run such a large and heavy wheel for autocross purposes. If you want to run that large of a wheel, I'd make it your "street" set with all seasons and just run good summer tires on your OEM or 17" wheels if you ever autocross. I just don't know about fitment; some of the car show guys in the Tire/Wheel fitment forum would probably be the better ones to ask since they tend to run larger/wider wheels.
I would want a lot more negative camber in the front for 9.5" wide wheels to be safe (you can get there with bolts, plates, and coilovers). I still want tons more negative camber for my 7" wide wheels.
Biggins is offline   Reply With Quote
The Following User Says Thank You to Biggins For This Useful Post:
LPC_FRS (02-06-2014)
Old 02-06-2014, 06:54 PM   #18
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
Way more wheel and tire than you will ever need on this car. For autocross, you're just carrying extra weight like Biggins said. The twins just don't have enough power to merit all that. Keep light and wide enough for your needs, only go beyond like a 245 or 255 wide tire for the show car thing. These cars are meant to be driven though!
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 02-06-2014, 09:18 PM   #19
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Mach V Wicked Awesomes are still very light and 18x9.5. You only need that much tire if you're putting down close to 400 whp though. And in all honestly it'll be hard as hell to balance the car around that kind of power anyway...
235 was a good spot for stock power IMO. I'm upping to 245 since I have close to 300 whp and I'm going with a slightly less sticky tire. I'd do 255 if Michelin would make PSS in that size on a 17" wheel...
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Seattle Locals w Coilovers, need a favor... NemeGuero Northwest 13 11-21-2013 03:03 PM
Selling a few parts - locals? swift996 Mid-Atlantic 7 08-06-2013 04:13 PM
Houston Locals Chime In!! itsibarra Southwest 12 08-05-2013 11:44 PM
Los Angeles or OC locals with fa20club tune! Gshoxx Southern California 5 03-21-2013 08:59 PM
To All My Locals... Pure Automotive Mid-Atlantic 60 02-03-2013 11:32 PM
