Old 01-23-2014, 02:51 PM   #281
mrbbs
Drives: GT86
Can someone supply me with this document? As I was taken offline from the Cusco website:
http://www.cuscousainc.com/jpg/Scion...ed%20Chart.jpg
mrbbs is offline   Reply With Quote
Old 01-23-2014, 02:53 PM   #282
OrbitalEllipses
Drives: Attitude
Learn to first page.....
Originally Posted by ATL BRZ View Post
Old 01-23-2014, 03:05 PM   #283
mrbbs
Drives: GT86
This is not the document I'm looking for.
It was a Cusco document with speeds in mph / kms for Cusco 4.556 / 4.875 and 5.125 and added 1st and 2nd short gears.
If I remember correctly I found it originally in this thread.
Rows where highlighted in yellow.
Old 02-04-2014, 12:27 PM   #284
mrk1
Drives: Sterling BRZ Ltd
@mrbbs I dont know how to post this so its acutally legible. I can email if you want.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-05-2014, 01:47 AM   #285
Racecomp Engineering
History
JUst after we drove the pre-production car exactly 50 weeks ago(Feb 2012) I told one of my guys at RCE " man a shorter final drive would bring that car to life". A year later with 184 whp(158 baseline), 2650 curb weight and a decent amount of suspension mods we installed the Cusco 4.556 final drive gear.
Stock is 4.10. Stock theoretical top speed at 7400 rpm is 168mph. Sure if you have a turbocharged or supercharged FRS/BRZ you will hit that,but most of the "full exhaust and intake crowd" wont hit that not even down hill. The theoretical topspeed with the 4.55 final drive is 148 mph at 7400 rpm. While thats not a speed I regularly hit while on the way to pick up my son....it does mean that corner exit speeds at my local track WILL be up and the motor will be be in a part of the power band that is FAR more willing to rev to redline than before.
So yes I committed to NOT turbo charging my car a month ago. Instead I wanted to take a different path. wanted a 2550lb car, shorter gears, as close to 250 CRANK power (adding headers and carbon drive shaft)and a LOT of suspension and brakes. I wanted this because this is a track "day" car. Drive it to the track , have fun, drive it home. Its NOT going to be a time Attack car, nor a drag car, nor a "bagged" show car. So by now I'm sure I lost MOST of people who started reading this.
So probably whats left are the functional people who might like this approach. This isnt the first time we did this. My old 16valve ITA Golf had a modified 4K box with a rally bolt kit in it. My 944 turbo had a IMSA Firestone Firehawk 944S2 trans in it that was shimmed up to 85% and a shorter final drive. That car hit almost redline at the end of the straight at Summit Point(155mph). The 280Z I had fresh out of high school had a different rear end in it as well. In each case the "geared" cars always had an advantage. Was it the fastest ? NOPE. There's always someone with massive power and in a track setting that means there's always going to be someone who can NOT get that POWER ........to the ground !
Impressions
If I had to guess what this feels like in WHP gain, I'd say 11-15 hp. I base that off of the way the car felt after getting the overpipe back done and tuned. The car for CERTAIN accelerates faster thru the gears. IN EACH GEAR....the response is MUCH improved. 6th gear feels like the old 5th. 4th gear is BRUTAL now. 2nd gear in the rain when going straight, breaks the tires loose at 1500 rpm ! ( I'm on Michelin Pilot Supersports too). 6th gear at 70mph is 3450 rpm. When I go to accelerate no downshift is needed to get a BRISK response. Going back to 5th at that speed means I am sitting at 4600 rpm and thats where my tune REALLY starts to make power. So 4th ( in the rain tonight meant some correction was needed to keep things straight at yes.....80+ mph) really ROCKS !
Hardware
This was a Cusco kit. In the Cusco box is a final drive kit with 3 pieces, ring, pinion, and a install sleeve. The funny thing is the instructions for this actually say " Toyota motor corporation" on it. The parts are Toyota factory parts. In some ways that VERY reassuring actually. I mean you KNOW you are installing factory parts. It tells you all the shims you will need in order to shim the final drive tolerance. I bought all 22 because each car will be different. We only use 1 so that means you will have 21 left over. In this case IAG will reuse these on the next one they do. ( we don't do transmission work so we took this to our closest and most trusted RCE installer in the area IAG performance).
I am told that the way to do this on the cheap is buy a junk yard IS300 or IS250( Limited slip version) rear end which already has this 4.556 final drive in it WITH a differential too. This allows you to swap the entire rear end and presto ! Not sure what these cost at junk yards.
Installation
Be prepared for a 7hr install. I had done my homework on this and STILL was stressed over how it would turn out. So the day of the first install it snowed. The next attempt it snowed also. Then a week later today...it was sleet and freezing rain this morning. I had a roll back on stand by as I was determined to get it done ! I would suggest doing other suspension mods while the rear end is out. Do some differential inserts and access to the rear camber bushings is a little better. Same for some other bushings.
Conclusion
While I haven't tracked the car yet the initial impressions are VERY good. Does it feel like I did a turbo? NO, not at all. Is it a solid modification? YES. Will most do it? NO. Most will spend TONS of money getting their NA car dyno-ed and dyno-ed and dyno-ed until it makes like 205 whp. And thats fine. Its just not for me. I want it to handle very well and have adequate power, lower weight and make full use of its power out of corners. this addition I think...will enable me to do just that. This mod REALLY changes the feeling of the car. Like most reviews....as corny as it sounds....."this is how the car should have come from the factory".
Man oh man a year later and I miss this car like a naked picture of a college ex girlfriend ! Its nice to read my genuine enthusiasm for this project. If the new STi/WRX has as much BRZ borrowed suspension parts( rear is identical) I wont be too far away with my new car !
I hope those who did this found this mod to be as good as I did. I know the person who bought my car LOVES it !
Myles
Old 02-05-2014, 01:11 PM   #286
Captain Insano
Appreciate this review. Thanks for posting the info. Back when you started the thread, because of your thread/post and some other folks, ever since then I've known I'm definitely planning to get a FD at some point when my warranty is gone.
Captain Insano is offline   Reply With Quote
Old 02-06-2014, 02:15 AM   #287
troek
troek's Avatar
Drives: 2012 Toyota 86
i would have already done this if it was just a bolt in thing, but i dont know enough about the measuring/shimming yet to be comfortable doing it my self, and im too cheap to pay a mechanic lol.
troek is offline   Reply With Quote
Old 02-06-2014, 09:45 AM   #288
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I made a pretty detailed DIY that might help you out if you decide to tackle it on your own. Sorry for the thread jack. Thanks to @Racecomp Engineering for being one of the first to do this on this forum. I do believe it was this thread that first peaked my interest with doing this mod.
Dustin is offline   Reply With Quote
The Following 3 Users Say Thank You to Dustin For This Useful Post:
86•BRZ (03-03-2014), Racecomp Engineering (02-06-2014), troek (04-25-2014)
Old 02-06-2014, 10:28 AM   #289
mrk1
setting up gears really isn/t that bad if you have patience, the right tools, and specs to work off.
The Build Thread
Old 02-09-2014, 04:17 AM   #290
RENN Spec
Drives: FRS
Picking up my Cusco 4.556 FD next week. Wonder if they are compatible with OS giken Super Lock LSD?
RENN Spec is offline   Reply With Quote
The Following User Says Thank You to RENN Spec For This Useful Post:
RehabJeff86 (02-21-2014)
Old 02-09-2014, 09:57 AM   #291
Dustin
Twin Screw You
Dustin's Avatar
@RENN Spec
Sent you a PM
Old 02-21-2014, 02:53 PM   #292
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I hv the same question, just got my 4.556 and looking at the OS Giken super lock LSD, dropped an email to OS Giken last month but never hear back.... Anyone had this set up here?
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 02-21-2014, 08:10 PM   #293
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any updates?
Old 03-07-2014, 12:43 PM   #294
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Just had this installed... driven for 2-3 hours since.
If your car is a keeper/or you are a track rat... This is one of those 'must have' mods.
stevo_12v is offline   Reply With Quote
The Following 6 Users Say Thank You to stevo_12v For This Useful Post:
fooddude (03-07-2014), Kronos (03-07-2014), raven1231 (03-07-2014), RehabJeff86 (03-07-2014), suaveflooder (04-26-2014), whataboutbob (07-23-2014)
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
