Old 02-05-2014, 08:32 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
key FOB not being recognized, not working (keyless start cars only)
(Keyless start cars only)
So 2 days ago, I noticed my car didn't start and the amber key/red lock symbol was blinking every time I tried to push the "push start" ignition.
I thought my battery died on my FOB (purchase date 6/2012) so I brought down my spare, and same issue. Perhaps both battery died at the same time
When I put my keys very close to the Start button, the car recognizes it and starts right away. Although sometimes, the car tries to "look" for the key, and it will flash amber yellow key symbol in the dash if I move the FOB out too quickly after starting the car.
My FOB will not lock/unlock doors, open the trunk any more which sucks because I can't lock my car. I'm scared if I lock it manually, it won't unlock with this FOB issue. Luckily I garage my car.
So has anyone had issues with the FOB all of a sudden dying? Electronic modding I've done that "may" affect this is:
Tapped turn signal/puddle light wires for my Diode Dynamic side mirror covers
OBDII bluetooth thing, although I disconnected this and still the same issue.
Toms tail lights
LED lights interior/exterior.
I've had these mods done quite some time now, and the newest addition of the side mirror cover turn signal light thing has been installed for 2 weeks now.
I will go to the dealer to switch out the battery to see if the 2 FOB's really died at the same time.
Any help will be appreciated!!
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 02-05-2014, 09:15 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
It could be a programming glitch....
The possibility of two batteries dying at the same time could happen... but not for sure.
Why would you go to the dealer to change a keyfob battery?
It's cheaper if you do it yourself.
Old 02-05-2014, 09:38 PM   #3
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
You do know you can unlock your car manually too. That's why there is a keyhole on the drivers door handle. Your physical key is inside your keyfob.
Hope you find out the issue, but at least you can sleep easy knowing your not locked out.
FiRStsc10n is offline   Reply With Quote
Old 02-05-2014, 09:43 PM   #4
BRZPDX
Boosted Member
BRZPDX's Avatar
well if its a glitch I want them to see it too. And I want them to change the battery so they know they did it, and can't blame it on me.
I'll be going in tomorrow, so I will update once I find out more.
Old 02-05-2014, 10:33 PM   #5
HapaHaole
Drives: Grocery cart
The batteries tend to last 1 year, question is does the red light in the key fob work?
HapaHaole is offline   Reply With Quote
Old 02-05-2014, 11:37 PM   #6
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
This has happened to me a few times (car not starting / doesn't sense the key). But like you said, I just take the key out of my pocket and it fires up. I would take it in to the dealership and have them take a look if it persists.
Doctor Who is offline   Reply With Quote
Old 02-06-2014, 10:30 AM   #7
andrew20195
Drives: 2013 Subaru BRZ
Unless you wired one of those accessories into something you really shouldn't have, I don't think they would be causing the problem.
Does your key fob light blink when you hit the lock/unlock button? If so, it's probably not batteries. Do you have to hold your fob next to the switch every time to start it, or did this only happen once? I know if you let your car sit for several days it will turn off the keyless system to conserve battery power, but once you start it again it should reactivate.
andrew20195 is offline   Reply With Quote
Old 02-07-2014, 11:03 AM   #8
IronSean
Drives: 2006 Toyota Camry
It could be the batteries getting weak, I'm not sure what the mechanism is for the FOBs (if they constantly send a signal to the car for the push button start, or if it's an RFID style reading where the FOB doesn't need power to start the car, the car can read it remotely.)
Assuming it needs power to start the car, could be your batteries are going and limiting the effective range of the FOB. Also, since I don't imagine you used your spare often, could be it died long ago(a week, month, or more), and you just didn't know because you didn't try to use it until your other one died. So it's not necessarily that they both died at once, could just be bad luck with which died first.
IronSean is offline   Reply With Quote
The Following User Says Thank You to IronSean For This Useful Post:
Trist0n (03-06-2020)
Old 02-07-2014, 12:48 PM   #9
ZXTT95
Drives: 2014 BRZ Limited 6MT DGM
One other thing, these fobs can be interfered with. I couldn't open the trunk recently and had to hold the fob to the button to start. This coincided with something odd that happens to me and my neighbors occasionally - our garage door openers don't work (at least not from outside the garage).
ZXTT95 is offline   Reply With Quote
Old 02-07-2014, 01:38 PM   #10
kuhlka
Drives: 2013 BRZ Limited AT
Toms tail lights
Do you leave your key fob anywhere near the car overnight after you park? When the fob is in range of the car it continually communicates, which drains the battery. Motorcycles with fobs have the same problem if you leave the key near the bike at night.
kuhlka is offline   Reply With Quote
Old 02-07-2014, 03:37 PM   #11
HapaHaole
This issue drains not the remote battery but the car battery, Due to the control modules all staying awake and not going to sleep.
Old 02-07-2014, 07:15 PM   #12
BRZPDX
Boosted Member
BRZPDX's Avatar
nope, I don't keep my keys in my car over night or anything. I couldn't get to the dealership due to the snow storm in the PNW, but I hope I can find out what's going on soon. Thank you for all your input!
Does the FOB blink red when you push a button even out of range? I see no red light when I push on any button on the FOB. Do you guys see any red light when you push on the FOB unlock/lock, trunk buttons out of range?
Old 02-08-2014, 10:27 PM   #13
kuhlka
I'm clicking my lock button on the fob right now and it blinks red. My car is about 5 miles away. Your fob battery is probably dead. Maybe it was in a pocket with a button constantly getting held down? Did it ever get wet?
Old 02-08-2014, 10:58 PM   #14
BRZPDX
Boosted Member
BRZPDX's Avatar
good to know, thank you for the test. Mine looks like its dead, and the spare must of died sometime along the way. My car was delivered June 2012, so it lasted longer than expected I suppose!
This fucking storm is kicking our asses, will try to go to the dealer on Monday.
Keyless start button: how to put it in ACC mode? JSUB BRZ First-Gen (2012+) — General Topics 124 09-09-2015 06:42 PM
BRZ start button not always working? JSUB BRZ First-Gen (2012+) — General Topics 8 10-22-2013 11:24 AM
How secure is the Keyless Entry and Start system? SeattleJeremy BRZ First-Gen (2012+) — General Topics 31 09-23-2013 12:23 AM
Keyless Entry and Start-up issues taiguochin BRZ First-Gen (2012+) — General Topics 27 01-21-2013 11:15 AM
Keyless Entry Delay/Not Working Dezoris Issues | Warranty | Recalls / TSB 0 11-02-2012 07:57 PM
